08-29-2005, 03:38 PM | #1 |
Member#: 30367
South East
Vehicle:2005 Legacy GT NASA SE PTB Champ |
Hydra question (1st of many)
Is there a special version I need to buy or will the STi or WRX version work? I'm asking because I may buy a used system.
08-29-2005, 03:41 PM | #2 |
Member#: 6971
NWIC
Vehicle:2008 WRX STi SSM |
STi has an electronic throttle, so you should buy a specific Hydra for your application.
08-29-2005, 03:57 PM | #3 |
Member#: 30367
South East
oops, I meant to say I am using a ej207 v7. It has AVCS but not electronic throttle.
08-29-2005, 05:31 PM | #4 |
Member#: 54918
MAIC
Vehicle:673 WHP Element Tuning Pro Comp Engine |
You will need a WRX Hydra if have a WRX chassis and wiring harness regardless of your engine. All of the new Element Hydras are setup with AVCS for the WRX but some of the older ones are not.
You will only need an STI Hydra is you have a DBW STI engine and harness. Thanks, Phil www.elementtuning.com |
08-29-2005, 05:41 PM | #5 | |
Member#: 30367
South East
Thanks Phil. How can I tell if it's a new or old one. Can an old one be upgraded? I wish I could afford new, but oh well.
08-29-2005, 06:11 PM | #6 |
Member#: 54918
MAIC
With the serial number I should be able to tell if it has AVCS and what flash version it is. It can be upgraded since it's only adding a few wires to the harness.
08-29-2005, 07:03 PM | #7 |
Member#: 30367
South East
Thanks again. I'll get the serial number.
Similar Threads | ||||
sti swap and hydra question | rooobaru | Other Engine Management | 4 | 08-12-2008 08:12 AM |
some gen hydra questions | gthurin | Other Engine Management | 10 | 06-08-2007 09:53 AM |
hydra question | Paintballguy | Other Engine Management | 3 | 12-29-2006 04:52 PM |
Hydra questions | swordmaster | Other Engine Management | 15 | 08-08-2006 09:52 AM |
Hydra Question. | STiTuner | Other Engine Management | 2 | 11-28-2005 07:19 PM |
