11-22-2014, 10:16 PM | #1151 |
Member#: 405024
NESIC
Vehicle:'15 WRX Limited World Rally Blue |
What did you do to your car today??
Was actually 3 days ago, but I had Pinnacle Ceramic 40% tint installed on the windows.
11-22-2014, 10:29 PM | #1152 |
Member#: 146311
TXIC
Vehicle:Saab '05 HTA68 Built 2.5L E85 6MT > STI :) |
Should be illegal to sell a new car in Texas without a tint
Got my Oswald Performance front subframe today. Hope to have it installed by end of tomorrow |
11-23-2014, 09:34 AM | #1153 |
Member#: 289264
Vehicle:06 WRX STI White |
got new headers and uppipe, but after install and running it a few times my car threw a P2101 code and defaulted to limp mode.... and i cant find much info on that code....
11-23-2014, 01:28 PM | #1154 |
Member#: 174883
TXIC
Vehicle:135i 05 CGM WRX 2006 Yamaha R1 |
^ You get a tune after the install?
11-23-2014, 01:51 PM | #1155 | |
Member#: 207697
International
Vehicle:05MY second SG6 murda-187 |
did you mess with any wiring, at all? perhaps you moved the turbo enough to disturb the engine harness. check plugs having to do with your dbw/tb and the wiring itself. |
11-23-2014, 02:20 PM | #1156 |
Member#: 289264
No not at all, I removed the DP and the heat shield to make the uppipe removal easier (which I had to install the headers and uppipe in a hurry and when I turned the car on it sounded like I had an exhaust leak). This happened last night after one last run. Car limped all the way to my house and wouldn't even make it up my driveway:/... I had to leave it up front... Before I got out I cleared the DTC and left it alone for the night. This morning I went out to see what's up and the car started fine without a problem.... Checked out all the wiring around the TB and nothing looked damaged.... HELP***128557;***128557;***128557;
11-23-2014, 02:32 PM | #1157 |
Member#: 207697
International
well, if it really is just a coincidence, maybe the climate also had something to do with a connection somewhere.
if you didn't get new gaskets, it's highly recommended. a complete oem set from eBay would be a better buy, unless you want a set from GS. |
11-23-2014, 02:46 PM | #1158 |
Member#: 289264
Yeah the new system came with pretty good gaskets, the only one I didn't replace was the dp gasket cause that one is almost new.... Idk I guess come tomorrow I will take it to work and put it up on a lift and see if I can locate the leak and I can check to make sure all the wiring around the new parts isn't busted :/
12-07-2014, 11:29 PM | #1159 |
Member#: 146311
TXIC
Replaced the o ring on my PS pump. Was starting to whine and bubble when it got cold out. No bubbles yet, but real test comes later this week.
12-08-2014, 08:56 PM | #1160 |
Member#: 174883
TXIC
12-08-2014, 10:30 PM | #1161 |
Member#: 93706
SCIC
Vehicle:'15 WRX CWP rip 05 STi OBP |
12-21-2014, 06:09 PM | #1162 |
Member#: 146311
TXIC
Got under the car to find a small coolant leak (did, hopefully taken care of) and found oil coming from driver's side valve cover. Which is just perfect since a shop replaced both of them about a month back due to a (much smaller) leak on the passenger side. le sigh.
12-23-2014, 04:54 AM | #1163 |
Member#: 289688
12-24-2014, 04:13 PM | #1164 |
Member#: 174883
TXIC
12-25-2014, 11:46 AM | #1165 |
Member#: 294622
TXIC
Vehicle:2007 STI - WRB Perrin GTX3076r, Slow |
wrapped downpipe put it back on, removed driver side hub to replace cv boots to find out subaru sent me the wrong ones.
12-26-2014, 08:12 PM | #1166 |
Member#: 146311
TXIC
More or less done with it. Need another bolt to complete the install. Only sad it will all be hidden by the aluminum skid plate
12-27-2014, 12:15 AM | #1167 |
Member#: 174883
TXIC
12-29-2014, 04:08 PM | #1168 |
Member#: 319039
Bought myself a Fumoto QwikValve gift set. And, as a bonus, the discount code that supposedly expired on Dec 27 still worked! Five percent discount when you type "GIFT14".
First time I ever looked forward to an oil change! |
12-29-2014, 04:46 PM | #1169 | |
Member#: 67003
TXIC
Vehicle:2015 WRX WRB |
12-30-2014, 02:05 PM | #1170 |
Member#: 302213
TXIC
Vehicle:2015 wrx premium crystal pearl white |
installed c light harness and 5000k head lights all from subiespeed, also blinker module.
12-31-2014, 10:01 AM | #1171 |
Member#: 167244
TXIC
Vehicle:2k3 WRX MBP Clean & Simple |
Installed kartboy rear shifter bushing
12-31-2014, 02:44 PM | #1172 |
Member#: 403362
Made a pool ball shifter for my subie Sent from my iPhone using NASIOC |
12-31-2014, 02:53 PM | #1173 |
Member#: 409813
TXIC
Replaced the oem grill on my 2015 wrx with a jdm grill and awaiting 6000k low beam bulbs from subiespeed to go along with my led c lights also from subiespeed.
12-31-2014, 06:19 PM | #1174 |
Member#: 84062
TXIC
Vehicle:2008 Forester XT Garnet Red Pearl |
Took ownership of a v7 tmic so my USDM sti tmic will be going away to someone else...
12-31-2014, 07:37 PM | #1175 |
Member#: 167244
TXIC
