12-15-2007, 12:57 PM | #1 |
Member#: 165212
Vehicle:2002 WRX Blaze Yellow |
DIY Perrin Rear Differential Cover Installation
While changing all of the fluids on PERRIN Project 15K we decided that we would take advantage of the situation and not only change the differential fluid but also add a little style and functionality to the rear end. Our rear diff cover is made from high strength, heat-treated cast aluminum. We've incorporated cooling fins into the design helping to reduce oil temps, in addition to looking good and cooling the oil better we've also increased the oil capacity more than 30% over stock. For a little more info click here.
Needed tools and gear: 1) New differential gasket (Can be purchased from any local Subaru dealer) 2) 1/2" drive wrench 3) 17mm wrench or socket 4) 14mm socket 5) Jack and jack stands This is a very straight forward installation that can be done on either a commercial vehicle hoist or floor jack. Step 1) Raise vehicle to desired height allowing you enough room to move freely. For this you will want to use jack stands to support the vehicle while removing and installing the differential cover. NEVER WORK ON A VEHICLE SUPPORTED ONLY BY A JACK. Step 2) Once the vehicle is raised to the desired height you will want to use the 1/2": drive wrench to remove the lower "drain plug". You will also want to remove the upper "fill plug" at this time as well. Place these two plugs aside to be reinstalled later. Step 3) Time to remove tension from the differential, this will allow you to remove the studs connecting the differential to the cross support. You'll need to get a floor jack for this next step. Placing the jack under the differential you'll want to raise the differential roughly .5". Step 4) Using a 17mm socket remove the 17mm nuts securing the differential to the cross support. Remove the studs from the differential and the cross support by using the "Jam-Nut" method. (this is where you "jam" 2 17mm nuts together on one stud. Then you can remove the stud by unscrewing the nut closest to the differential). Repeat this process on the remaining stud. If this method doesn't work you'll have to use a stud-extracting tool. Step 5) Once the two studs are removed from the differential and the cross support, its time to lower the differential. If needed you may want to remove or lower the exhaust system allowing yourself more working room. Because our vehicle had a differential skip plate we had to remove the exhaust. You now should see and have access to all 8 14mm bolts securing the differential cover to the differential. Using a 14mm socket remove the bolts. (NOTE: WHILE REMOVING THE DIFF COVER THERE WILL BE ADDITIONAL OIL THAT WILL BEGIN TO COME FROM THE BOTTOM OF THE DIFFERENTIAL). Once the cover is removed you'll want to wipe out as much excess oil from the differential as possible. Step 6) Once everything is clean you can place THE NEW DIFFERENTIAL GASKET to the PERRIN differential cover. Using the 8 14mm bolts remove earlier loosely place the cover back into place. Starting at the top two bolts tighten the bolts to 21.7ft-lbs. Step 7) Raise the differential back into place using the floor jack. Once the differential is in place (you'll be able to tell because the differential nut holes will line up with the cross support holes). With everything lined up you'll want to place and tighten the two bolts/nuts removed earlier to 52ft-lbs. Before doing this thread studs into differential cover until they are bottomed out. Step 8) Reinstall the lower drain plug into the newly installed PERRIN differential cover. Tighten this drain plug using the ½" drive wrench to 36.2ft-lbs. Step 9) Fill differential with proper high quality gear oil until oil starts to drip from the upper fill hole. Install the upper plug and tighten to 36.3ft-lbs. Step 10) Lower vehicle and take it for a test drive. Check for oil leaks after the test drive. Ken Jubb Sales PERRIN Performance***8482; AIM: altaperrinsales4 1-503-693-1702 Ex. 113 [email protected]
12-16-2007, 08:43 PM | #2 |
Member#: 147972
Vehicle:2004 wrx hybrid 18g 11.9@117 dd |
Thats looks mean, now I just need to go out and get an STI rear diff
12-16-2007, 10:57 PM | #3 | |
Member#: 165212
Have a good one Ken Ken Jubb Sales PERRIN Performance***8482; AIM: altaperrinsales4 1-503-693-1702 Ex. 113 [email protected] Last edited by PERRIN_Ken; 12-23-2007 at 12:33 AM. |
12-16-2007, 11:01 PM | #4 |
Member#: 3782
South East
Vehicle:02 WRX WFC#040 Clean on 19's |
12-17-2007, 07:19 PM | #5 |
Member#: 82949
South East
12-18-2007, 03:16 AM | #6 |
Member#: 165212
Nope we have a diff cover that works on the STI and one for the WRX. PSP I dont know what I was thinking I ment S.L.S. (Subframe Lockdown System). It is a really simple install. It helps firm up the rear end. Sorry for the typo.... Ken Ken Jubb Sales PERRIN Performance***8482; AIM: altaperrinsales4 1-503-693-1702 Ex. 113 [email protected] Last edited by PERRIN_Ken; 01-12-2008 at 12:09 PM. |
01-10-2008, 11:57 AM | #7 |
Member#: 6776
Coupon Code And Details Check It Out!
The same cover won't work on both STi and WRX. The rear end is different. BUT we do offer both styles.
WRX Style Click HERE! STi Style Click HERE! Also as a special deal for our NASIOC friends, order direct form PERRIN either of the styles above and receive and addl. 15% off the purchase price! During checkout use coupon code COOLDIFF (must be caps) for 15% off. Price good for 30 days! Thanks again everyone! [email protected] |
01-29-2008, 12:03 PM | #8 |
Member#: 41024
Vehicle:2004 wrx WR Blue |
ordered this and the lock down kit. Look forward to the install.
01-29-2008, 12:15 PM | #9 |
Member#: 93667
Vehicle:'03 Build'n a 2.12L 331whp/331wtq |
Very nice cover. I swapped to an R180 and used your cover. Looks freakin' killer
Also made my own magnetic alum. plug from the factory magnet. Rivited and J B welded. It can't ever fall off and makes the diff look even more trick. |
01-29-2008, 01:42 PM | #10 |
Member#: 3782
South East
nice plugs!
01-29-2008, 03:07 PM | #11 |
Member#: 41024
that came out nice, excellent work.
01-29-2008, 05:43 PM | #12 |
Member#: 165212
Looking good and I love the plugs
Ken Ken Jubb Sales PERRIN Performance™ AIM: altaperrinsales4 1-503-693-1702 Ex. 113 [email protected] |
01-29-2008, 09:08 PM | #13 |
Member#: 104878
TXIC
Vehicle:02 wrxbastardchild aw, MPS 2.34 breaking in |
this isnt really related but could be. How do you tell the difference between the 06 sti r180 and the others from the outside? Mine just came in and I want ti be sure.
01-29-2008, 09:11 PM | #14 |
Member#: 93667
You have to take off the cover and get the tooth count numbers off the ring gear and they should be a 3.54 ratio. Divide the larger number by the lower. I don't remember what the numbers are off hand.
01-29-2008, 09:17 PM | #15 |
Member#: 104878
TXIC
I dont know what you mean but divide the larger# by the smaller#, It should be 3.54, I just dont want to take it apart as if its wrong Ill be shipping it back. Are there any #s on the outside? Sorry jeff for mudding up your thread.
01-29-2008, 09:59 PM | #16 |
Member#: 6776
acby rex: No muddy issues here! We like a nice interchange of information.
They covers are different sizes as well. The holes are different etc. Maybe we can get Ken to take a side by side, so you folks can see better. Thanks again! [email protected] |
01-29-2008, 10:04 PM | #17 |
Member#: 104878
TXIC
ok I just put this in my thread, but I have a 06 sti rear diff and is has this on the bottom
ND1058 o2 56D layed out like this on the bottom, Adam do you know if this is a 06 for sure and not a 05 or 07? Thanks. Last edited by scby rex; 01-29-2008 at 10:07 PM. Reason: wrong person |
01-29-2008, 10:17 PM | #18 |
Member#: 93667
R160 and R180
01-29-2008, 10:24 PM | #19 |
Member#: 104878
TXIC
do all r180s have the 21 stamp on them like the r160 have the star?
01-29-2008, 11:01 PM | #20 |
Member#: 81659
Vehicle:2006 STI / 2010 FXT Aspen White / Silver |
01-29-2008, 11:03 PM | #21 |
Member#: 104878
TXIC
nice^
01-29-2008, 11:16 PM | #22 |
Member#: 140712
SCIC
Vehicle:2008 WRX STI White |
yea, that green one is nice looking
01-29-2008, 11:17 PM | #23 |
Member#: 95840
Vehicle:sold to a good bud awaiting next car |
yellow FTW!
01-30-2008, 12:55 AM | #24 |
Member#: 140712
SCIC
01-30-2008, 07:35 AM | #25 |
Member#: 93667
Thread size is 3/4" NPT and not 1/2" NPT sorry if I screwed anyone up
The plugs that I used were 3/4"" NPT incase anyone is interested. Nice work on the painted ones guys. I was also going to use SS allen bolts on my cover, but decided to skip it. Looks good. I did do the SS bolts on my bearing caps . Almost all bolts under my hood are SS allen bolts. 90% are including all the bolts for the intake mani including the long 8mm ones that bolt it down to the head. All the ones that can be seen are SS allen. Last edited by Crazykev; 02-01-2008 at 07:20 AM. |
Similar Threads | ||||
DIY Perrin Rear Differential / Subframe Lockdown System | PERRIN_Ken | NASIOC Project Cars | 168 | 09-30-2017 02:39 PM |
perrin rear differential cover | arrowscooby | Drivetrain | 2 | 04-05-2009 02:04 AM |
Perrin Rear Differential Cover | JSC Speed | Drivetrain | 2 | 12-22-2008 05:45 PM |
Will ProDrive rear diff cover fit Perrin rear diff cover | subbiedo04 | Transmission (AT/MT) & Driveline | 5 | 04-01-2007 09:30 AM |
