07-10-2014, 11:32 PM | #8226 |
Member#: 395905
07-10-2014, 11:55 PM | #8227 |
Member#: 204421
NWIC
07-14-2014, 04:03 PM | #8228 |
Member#: 329049
Vehicle:04 sti PSM (unfortunately) |
Which woul be a better idea for 600+hp:
1- in tank walbro 465 with an inline Bosch 044 in the engin bay Or 2- intank walbro 465 with a kenne bell boost a pump? |
07-14-2014, 04:57 PM | #8229 |
Member#: 76785
Vehicle:2000 700Whp The RSTI SRP |
2012 STI heads?
did you just run non AVCS cams, or cap the DAVCS cams? |
07-18-2014, 12:02 PM | #8230 |
Member#: 296411
Vehicle:2011 4dr STi / GR86 SWP |
Made 340 390wtq on e85 with a catless turboback and a 20 psi tune. Car feels incredible
07-18-2014, 12:14 PM | #8231 |
Member#: 349361
Vehicle:2013 STi SWP |
[quote="joewrx628;42269369"]Made 340 390wtq on e85 with a catless turboback and a 20 psi tune. Car feels incredible[/QUOTE
Where you get tuned |
07-18-2014, 05:55 PM | #8232 |
Member#: 296411
08-23-2014, 04:26 PM | #8233 |
Member#: 253442
Not sure if this has been asked, I'm sure it has and I apologize, I just can't seem to find an answer.
So I'm running e85, built motor, etc. Everyone that drives behind me says that they can smell it pretty decently. I am catless and would like to know if replacing my downpipe with a catted downpipe would help the smell. Sent from my iPhone using NASIOC |
08-23-2014, 04:57 PM | #8234 |
Member#: 145658
Vehicle:On my 10th scoob and lovin it |
yes. like I told you
08-23-2014, 05:06 PM | #8235 |
Member#: 253442
Lol. You said "maybe"
08-23-2014, 05:07 PM | #8236 |
Member#: 395731
SCIC
Vehicle:2015 WRX Premium DGM |
Are cats really necessary when you're running e85, since it isn't a carbon based fuel? Running regular gas without cats is incredibly bad for the environment. I'm curious how emissions from e85 are, does anyone know?
08-23-2014, 05:13 PM | #8237 |
Member#: 204421
NWIC
really? No, not really.
You are carbon based, I am carbon based, Sugar is carbon based and alcohol is carbon based. Ethanol Molecule The base gasoline molecule: Gasoline has additives in it, so what you're actually burning is a little bit different. Regardless, this shows the difference in the amount of carbon per molecule and the added Oxygen in ethanol. This is why you need approx 30% more ethanol than gasoline. So yes, cats are still required. |
08-23-2014, 05:39 PM | #8238 |
Member#: 395731
SCIC
I thought the primary byproduct of burning ethanol was H2O, whereas for unleaded fuel it's CO?
08-23-2014, 06:31 PM | #8239 |
Member#: 204421
NWIC
It is. H2O and CO2. However, you aren't burning just ethanol. E85 ranges from 60 to 82 percent ethanol. The rest is gasoline.
Sent from my SAMSUNG-SM-G900A using NASIOC mobile app |
08-23-2014, 06:42 PM | #8240 |
Member#: 395731
SCIC
What if I were to run e100? I guess what I'm getting at is, at what percentage do cats become necessary?
08-23-2014, 06:55 PM | #8241 |
Member#: 131568
Vehicle:2006 WRX to 2015 WRX OB Swirl / DGM |
Is E-85 any more corrosive than gasoline? IE. how does it affect durability and longevity?
08-23-2014, 08:31 PM | #8242 |
Member#: 270482
Vehicle:2011 turbotek fxt 11.85@117 4eat xt record? |
ethanol draws alot more moisture in which will be much more corrosive and yes it will take its tole on things alot quicker then gas will. I have been on nothing but e85 for over 2 years now and have seen no negative affects other then a blown motor from to so much powa!!!
08-27-2014, 05:15 PM | #8243 |
Member#: 305107
Vehicle:2016 GT 5.OHH DIB |
so whats everyone in here running for a clutch..looking at an act or southbend..
08-27-2014, 07:57 PM | #8244 |
Member#: 94097
Vehicle:2004 WRX Hybrid GT35 [email protected] |
Running act for over 3 years now no problems. 580hp
Sent from my SM-G900V using NASIOC mobile app |
08-27-2014, 09:10 PM | #8245 |
Member#: 170097
South East
Vehicle:2007 WRX STi PTE6266 OBP |
08-27-2014, 11:15 PM | #8246 | |
Member#: 340639
BAIC
Vehicle:2013 WRX STi Sedan WR Blue Pearl |
I have about 3500 miles on it, and it still chatters and shudders when warm, and doesn't like to be slipped. At the track it's perfect; it's just as a daily driver in stop-and-go it really sucks. It's also substantially heavier than the stock (I'd say as much as 50% heavier clutch pedal). I'm actually going in on Friday to get it swapped out for a Southbend Stage 3 Endurance. I had a chance to test one out, and it's perfect; a little heavier than stock but way lighter than the Exedy, and no shuddering to speak of. |
08-27-2014, 11:26 PM | #8247 |
Member#: 324845
NWIC
Vehicle:2012 impreza WRX PBP |
Hated the ACT 6 puck.. Went to the extreme full face and love it.
Sent from my SCH-I545 using NASIOC mobile app |
08-28-2014, 06:47 AM | #8248 |
Member#: 170097
South East
Ya. That's what I had originally at 500 wheel tq. It was at the edge and I don't think it would hold 690 wheel tq Soni swapped to the 6 puck. I definitely don't love it starting out. But it does hold the power.
08-28-2014, 07:07 AM | #8249 |
Member#: 327511
Vehicle:13' WRX 6 Speed 11sec VF52 EL-EWG-E85 |
also running an exedy stage 1 HD, won't buy another. It is different than the push style "stage 1" though, for the 5mt cars. Two friends have one without any issue. The "HD" version is only available for the pull type 6mt application it appears.
08-28-2014, 10:59 AM | #8250 |
Member#: 172698
Vehicle:11 STi BW 8374 E85 02 v8 Spec C E85 |
I'm a big fan of the Competition Stage 3 clutch. Its a segmented ceramic design so it holds power, sheds heat but its still not bad to drive IMO. Its rated for 500 torque and it held up well to a lot of abuse with my Dom 3.5 turbo setup at full boost.
I'm switching to an EFR 8374 turbo so I needed something stronger so I went with the Competition twin. The price is right on it and I drove it in a friend's car and was impressed how drivable it is for an un-sprung small disc twin. Like any strong clutch, it will suck in stop/go traffic but my car doesn't see a lot of that. |
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY | Motion Lab Tuning | Proven Power Bragging | 125 | 04-12-2010 02:57 AM |
jid2 Track Car - e85 ARMY | jid2 | Member's Car Gallery | 38 | 01-22-2010 10:44 PM |
The Honduran army is the bravest in the world... | wrxcelent | Off-Topic | 36 | 07-07-2009 08:21 AM |
Spacific E85 Tuning thread Here ? | discopotato03 | Engine Management & Tuning | 1 | 09-09-2008 11:01 AM |
Did anyone hear the one about the Italian army and the IRAQI satiation? | Asinine | Off-Topic | 3 | 09-20-2005 07:06 PM |
