10-09-2013, 12:53 PM | #501 |
Member#: 158544
you my friend, have some talent. beautiful work.
08-21-2014, 03:17 PM | #502 |
Member#: 292225
Vehicle:08 WRX (16g) OBP |
08-21-2014, 07:59 PM | #503 |
Member#: 204765
SCIC
Vehicle:2008 STi OBP |
Dude thats sweet, how is your battery life? I've ben thinking about doing a V2 using a current gen N7.
08-26-2014, 01:29 PM | #504 |
Member#: 199059
TXIC
Vehicle:08 STi Wagoneer White/Gold |
Care to share your parts list and cost? What ROM are you running? How are you handling navigation?
10-09-2014, 12:23 PM | #505 |
Member#: 380240
Vehicle:2014 WRX Dark Grey Metallic |
sorry to bring this back from the dead but does any one know the model jvc head unit used?
10-10-2014, 09:44 AM | #506 |
Member#: 398138
I just started an iPad mini install in my 2015 wrx. iPad will be removable amd still charge.
10-10-2014, 12:04 PM | #507 |
Member#: 301692
10-10-2014, 02:02 PM | #508 |
Member#: 398138
At first I really wanted to keep my climate controls in the dash but after some testing/cutting it just isn't going to happen. Going to have to move them. Have some ideas on to where to move them to. Nothing permanent yet. My car right now is a disaster. Everything is out, the dash the whole center console the whole trunk.
02-03-2015, 10:09 AM | #509 |
Member#: 292225
http://imgur.com/a/hlNuo
So I upgraded my Nexus 2012 to the Nexus 2013, and I used Timur's PAID kernel for the 2013. Suck it up an buy it. It rocks.
I created a double din sized Acrylic box from 1/4" sheets cut to size by a local shop... Here are the outer dimensions if you are interested in making a similar box to hold all of this. [OD] - 4" x 7" x 5.75" [x 1] - 4" x 7" [x 2] - 6.5" x 5.5" [x 2] - 4" x 5.5" Last edited by onsit; 02-03-2015 at 11:24 AM. |
02-04-2015, 07:02 PM | #510 |
Member#: 185910
Vehicle:2007 FSXT |
Onsit, I am new to this; so pardon me if this is a stupid question. I thought that a dac was for two speakers not four?
02-05-2015, 09:30 AM | #511 |
Member#: 344521
Vehicle:2013 STi DGM |
Going to make an assumption here, but he also has an amp. He will use the dac as volume control and slight amplification and then convert to RCA to plug into the AMP. It is what I did minus the dac. I'll be posting my setup soon once I finalize everything. I'm currently finishing the audio and waiting on the JDM trim.
02-06-2015, 07:00 PM | #512 | |
Member#: 140919
Vehicle:2002 Wrx Asssspen White |
http://www.amazon.com/gp/product/B00IJBVQEQ/ref=ox_sc_sfl_title_4?ie=UTF8&psc=1&smid=A17Y7218I8U3RT |
02-07-2015, 08:26 PM | #513 | |
Member#: 185910
Vehicle:2007 FSXT |
02-11-2015, 09:41 PM | #514 |
Member#: 412966
nice work
02-11-2015, 11:51 PM | #515 |
Member#: 204765
SCIC
lookin good onsit! I need to to upgrade to the 2013 N7 also, I'd like to have full time LTE without my phone in hotspot.
How are you controlling the volume level? On screen software volume control? |
02-12-2015, 09:39 AM | #516 | |
Member#: 344521
3.5mm cable plugged into tablet > Headphone Amplifier > 20 ft Stereo Cable > Stereo to RCA Adapter > Ground Loop Isolator (Reduces static from charging tablet) > RCA Splitter. The RCA Splitter (Now four RCA connections) plugs into the amp. Amp powers speakers. Hope this helps. Let me know if you'd like more information such as branding and parts. |
02-12-2015, 09:41 AM | #517 | |
Member#: 344521
This is what I'm currently using for volume control. It works pretty well, but sometimes if music isn't currently playing there will be some feedback from my mobile hotspot. I'd make an assumption that if you have a 2013 nexus maybe the LTE would make it not have static but I'm not sure. I tried on screen volume for a while but it got annoying. onsit would use the DAC for volume control most likely. |
02-12-2015, 10:34 AM | #518 | |
Member#: 185910
Vehicle:2007 FSXT |
02-12-2015, 10:42 AM | #519 | |
Member#: 344521
02-12-2015, 10:48 AM | #520 |
Member#: 185910
Vehicle:2007 FSXT |
Yeah, that's what I was thinking. No way around it at this current time around it I guess.
02-12-2015, 10:48 AM | #521 |
Member#: 31519
Vehicle:2022 Oversized Load 2020 Lotus Evora GT |
What did you do to actually attach the N7 to that box?
02-12-2015, 01:39 PM | #522 |
Member#: 344521
Sorry I'm answering everyone elses questions today haha. Slow day at work. Some people have used sugru. I used this:
http://www.homedepot.com/p/Scotch-1-...4-DC/203405976 EDIT: I used about 9 inches worth with is about a holding force of 18lbs. |
02-14-2015, 10:07 AM | #523 |
Member#: 292225
Steering wheel controls are done with a Joyconn micro controller. You wire in the resistance wires, and then connect them to your USB hub. From there its detected by android as a keyboard. Allowing you to map your steering controls to any thing in android.
My amp took a RCA 2 line input, which then gets split to 4 car speakers. Some DACs do exist that give you 4 line output... But I'm not an audiophile. As far as mounting the tablet to the box. I used an old case that was easy to remove the tablet from. Then I used double sided mounting tape from my box to the case. |
