09-17-2005, 07:31 PM | #1 |
Street Racing Instructor
Moderator Member#: 110
Vehicle:1989 1989 XT6 |
Warning for 2.2ltr Single Exhaust Port and Borla
The Borla single port exhaust header does not fit the 2.2ltr automatic trannied Impreza properly. It is really really tight and one of the holes did not mate up properly. The last hole had to be drilled out out to make it fit. It was not a direct bolt on. That is all!
09-17-2005, 07:33 PM | #2 |
Member#: 82259
BAIC
Vehicle:1999 impreza 2.2L Brilliant Red <4EAT Club> |
whats funny is when you go to their site, you pick out your car and everything, then it asks what tranny you have, but either one you click gets you the same part #
thanks for the info btw |
09-17-2005, 07:41 PM | #3 |
Member#: 52202
MWSOC
Vehicle:2001 2.5RS |
Did you try contacting Borla at all about this? And what generation header is it? That was a problem they had with older generations. My 2 port 2.5 header mated up quite nice.
09-17-2005, 07:48 PM | #4 |
Member#: 64528
Rallispec installed a single port borla on my 2.2L and did not report any problems
09-17-2005, 11:35 PM | #5 |
Member#: 6486
MWSOC
Vehicle:00 Impreza 2.5 RS Blue Ridge Pearl |
Most of the borlas fit a little tight on the head exhaust studs. They don't have any expansion joints. I think that's also why the tend to crack.
09-18-2005, 03:07 AM | #6 |
Member#: 78118
Tri-State
Vehicle:2002 Corvette coupe 05 Legacy |
my borlas sucked i say this evrytime im in a header thread, well they rattled to say the least
09-18-2005, 10:23 AM | #7 |
Member#: 64528
----- Thats why Rallispec puts in a flex-link on borlas |
09-18-2005, 06:04 PM | #8 |
Member#: 20998
Good info man, thanks.
09-18-2005, 08:35 PM | #9 |
Member#: 65036
Vehicle:2013 WRX |
Yeah i had to bore mine out. My second set though, the first went straight on.
09-18-2005, 10:00 PM | #10 | |
I never tried to slide it on with all the studs in place. One of my studs came out with the nut so I tried to put the stud on 'after' I installed the header and the stud would not screw in. I should've taken the header back off but I had to bang it in place in the first place. Time was little and I wanted it on NOW. I haven't had the time to deal with it since. Part of the problem is that I have 3 other projects going on as well (Both Subaru XT6s and Subaru RX turbo), hence little time. Last edited by Kevin Thomas; 01-19-2006 at 11:59 AM. |
09-18-2005, 10:20 PM | #11 |
Member#: 52202
MWSOC
Yeah, I didnt mean try to get Borla to replace it or whatever. I was just sayin maybe they could document it and if enough people complained, maybe something would be done. Or they might be able to say how many other people have seen the same thing.
Similar Threads | ||||
3rd-FS Borla headers for 2.2L single port | Legend STI | Scammer Central | 8 | 12-26-2008 11:45 PM |
2.2 Single exhaust port - enlargment | cjfike | Normally Aspirated Powertrain | 6 | 08-24-2004 10:59 AM |
Headers for 2.2L single port | G.Subramaniam | Normally Aspirated Powertrain | 1 | 07-08-2004 02:03 PM |
When did the 2.2L heads change to single exhaust ports? | subysouth | Normally Aspirated Powertrain | 2 | 09-06-2001 12:25 AM |
Does MRT make a single exhaust port header for the 2.2L? | 96Lconversion | Normally Aspirated Powertrain | 4 | 03-14-2001 12:38 AM |
