08-24-2012, 06:19 PM | #1701 |
Member#: 273054
Vehicle:2012 Impreza CVT HB |
Heat finally dropped off to upper 70's. This is from a 40 mile commute on 2-lane county roads, with a bit of 4-lane and a bit of city. Avg speed is 43 mph. CVT.
I hoped to get over 36, but got 37!
08-24-2012, 08:56 PM | #1702 | |
Member#: 323103
Vehicle:2018 WRX Pure der |
^ whats the mat on your dash?
Yep cvt. Same here, 60-65 probably the best mpg on flat road. Downhill, sky's the limit. Last edited by myrt1987; 08-24-2012 at 10:23 PM. Reason: grammur |
08-24-2012, 09:41 PM | #1703 | |
Member#: 302491
Vehicle:2012 Impreza 2.0i Pr Dark Grey Metallic CVT |
08-24-2012, 09:59 PM | #1704 | |
Member#: 316190
I know it was a short trip and 100% highway, but it's only shown about 35-38 when I have done this before not drafting. It was still climbing as I got off the expressway. Can't believe what a difference it makes. I think I might have found a new hobby. |
08-24-2012, 10:06 PM | #1705 |
Member#: 322264
Vehicle:2012 Impreza Sp 5sp Obs Blk Prl/Drk Gray Mtl |
08-24-2012, 10:15 PM | #1706 |
Member#: 273054
08-24-2012, 10:22 PM | #1707 |
Member#: 323103
08-25-2012, 08:24 AM | #1708 |
Member#: 329819
Vehicle:2012 Impreza Premium Silver |
2012 Impreza premium non pzev 5 speed Manual
@80mph 30 mpg constant Highest was 32. That is after being corrected by pump math. Seems the gauge on the dash is 2 mpg high. It would get more mpg at slower speeds I am sure. That was from me making my 90 mile round trip commute to work. Thankfully I do not do that anymore and have found closer employment. |
08-25-2012, 08:34 AM | #1709 |
Member#: 327440
South East
Vehicle:2012 IMPREZA SPT LTD DARK GRAY METALLIC |
Got 34.3 mpg on a 1-1/2 hour drive on highway doing 65mph with the A/C going. So far im pleased with my MPG. My sport limited has 2200 miles on it now.
08-25-2012, 02:52 PM | #1710 |
Member#: 314216
Vehicle:2012 2.0i Sport 5MT DGM |
Ok, did a long trip this morning, looks like for sure my odometer error is 2.8%. Gps tracked 266.5, car was over 259.2 but not yet to 259.3.
Forgot to look at mpg, but should be around 30-31 indicated, haven't filled up yet, indicating 1 bar less than 1/2 |
08-25-2012, 05:29 PM | #1711 |
Member#: 316190
08-25-2012, 07:43 PM | #1712 |
Member#: 315883
E. Canada
Vehicle:2012 IMPREZA Silver |
That's too close for me!
08-25-2012, 10:25 PM | #1713 |
Member#: 316190
I will get out and measure next time. Same following distance as I would a regular car. Couple second rule.
08-26-2012, 01:48 AM | #1714 | |
Member#: 322250
Vehicle:2015 WRX Premium Ice Silver Metallic |
Trip down during the day, temps were in the mid 70's, limited AC use, averaged 32.7 MPG, with average of 63 MPH (entire trip down). Return trip in the overnight hours, temps ranging from mid 50's to mid 60's, no AC use, averaged 29.7 MPG, with average of 63 MPH (entire trip back). Split MPG's were roughly the same for both directions for the Thruway-only portions of the trip, with the average speed running closer to 67 MPH. Considering it's downhill going east and south, and uphill going north and west, no big surprises with the differences in MPG. This is with a CVT, PZEV, 5 door, just shy of 6000 miles on the odometer... |
08-27-2012, 10:44 PM | #1715 |
Member#: 314216
Alright filled up today, 383.4 miles, 12.2 gallons, 31.4 mpg, car indicated 31.5. Not to bad for 72mph for 250 of those miles, and the rest was driving around Minneapolis for the last 3 days.
5sp sport. |
08-28-2012, 07:39 AM | #1716 |
Member#: 316756
Yea not bad , but my 10 Outback gets that with a bigger motor and my sons 10 prez gets 30 on the highway at those speeds with the 4at. I guess my point is as much emphasis as Subaru put on MPG with the new car it falls a little flat. I have never gotten over 22.8 city only with my car and it seems you have to drive 65 or below on the highway to get 36+ mpg
08-28-2012, 08:16 AM | #1717 |
Member#: 323103
^ Yea, looks that way
Looks like 27 mpg city was a little bit of an over-estimate |
08-28-2012, 08:19 AM | #1718 | |
Member#: 322264
If we, as owners, want to match the EPA numbers, then we need to match those driving conditions. Driving 75 mph on the highway is not matching those conditions, so it should be no surprise that MPGs will suffer. This article provides an idea of how complex the EPA tests are: http://www.caranddriver.com/features...-mpg-estimates There's no way that we, as consumers, can match the EPAs test conditions. But that's OK. The point is that all manufacturers are tested the same way, so we as consumers can make a relative comparison of the fuel economy of the cars we're considering buying. How close does the Impreza come to the Mazda3 or Ford Focus in terms of fuel economy? The window stickers should provide that comparison. |
08-28-2012, 09:12 AM | #1719 |
Member#: 317014
Vehicle:2017 Crosstrek ISM |
Been avg. 31-32.5mpg with the AC running on my daily commute 60-65mph on highway. My co-worker just gave me his Aero crossbars and I see the mpg needle below fluctuate more when I put some weight on the gas pedal. With the drag I've been avg. just above 30mpg the last two days. I expect the it to go back up when I remove the bars and turn off the AC (probably 34ish+)
08-28-2012, 10:46 AM | #1720 | |
Member#: 314216
I'm happy with this car, especially since i was just hoping for 30ish average |
08-28-2012, 10:51 AM | #1721 |
Member#: 328167
Vehicle:2012 Impreza MT PZEV Silver |
Got my 5MT Impreza hatchback from the dealer on 8/16/2012. We've driven it 1700 miles since then.
My last tank averaged 34 mpg. My current tank (I've only got about 1/8 tank left) is averaging 40.5 mpg according to the trip computer. My driving has been almost entirely freeway so far, although a good chunk of the current tank has actually been city driving as well. Overall, pleased with the car and its performance. I'm coming from an old 1.5 liter Civic. Pretty much anything is going to get worse mileage than that thing, but for an AWD car with a 2.0L engine the Impreza has been competing well. EDIT: I'm especially pleased considering that these numbers are with a passenger and a lot of luggage in the car with the A/C running. |
08-28-2012, 11:14 AM | #1722 |
Member#: 323103
Wow, that is good. 5mt, a/c, passnger and cargo weight, 40+mpg? nice
avg speed? |
08-28-2012, 12:53 PM | #1723 |
Member#: 328167
08-28-2012, 11:50 PM | #1724 |
Member#: 314216
On my trip home tonight i averaged 31.8mpg over 330.9 miles! Not bad for 72 mph for a good part of it. The first 37 miles of the tank were stop and go with a ton of idling going to and from the baseball game. Oh and this was an e10 crapahol fill. I'm not complaining!
08-29-2012, 11:18 AM | #1725 |
Member#: 330076
Vehicle:2012 Impreza Sport Ice Silver |
So I am about to crack my first 1000 miles and almost all highway but I'm getting only 27mpg... seriously? Someone please say this is temporary. I drive pretty easy going, though I notice that when you first accelerate with this car verses our outback its really quick to 30mph even when you don't try. It's a 5d Limited Sport. Oh, and I have the pzev on there, which I've heard affects it too...
Similar Threads | ||||
New Impreza owner, low mpg? | stuffedcabbage | Newbies & FAQs | 36 | 08-28-2017 07:10 AM |
2012 Impreza Reviewed - Whytecliff to Seymour | brendan_mac | Vancouver Impreza Club Forum -- VIC | 16 | 12-23-2011 01:12 PM |
NJ Impreza owners - sighting | Dan G | General Forum Archive | 76 | 10-06-2000 12:24 AM |
Md or Va Impreza owners - I have an Impreza related question. | Snoopy | General Forum Archive | 1 | 06-05-2000 08:08 AM |
