08-25-2006, 09:26 AM | #101 |
Member Sales Rating: (1)
Member#: 7492
South East
Vehicle:No race cars www.tomhoppe.com |
With our calculations and a test fit on 17" wheels, these *should* work on 16" wheels. We have not actually put them on a car with 16" wheels though.
This Sunday we will finally be test fitting them on a 16" wheeled car. -Tom
08-25-2006, 03:44 PM | #102 |
Member Sales Rating: (24)
Member#: 70252
Vehicle:05 STI blue |
sorry for another question. Im on the verge of ordering these.
So with these ball joint extenders what would be the optimal drop with this kit? i believe its be generally agreed that the lowest you would want to drop the front of the gd's is 13.5 from the center of the hub to the fender. With the ball joint extenders would it be better to keep it at that height and have the benefits of less camber loss, or do the ball joint extenders actually make it so that you could drop the front lower and have benefits of a lower roll center and less dynamic camber loss? Thanks in advance. |
08-25-2006, 04:48 PM | #103 |
Member Sales Rating: (3)
Member#: 54304
South East
Vehicle:04 STi TopSpeed-dAng! |
The kit will make 'optimal' closer to 12". however, lowering that much would require some inner and outter fender work. I am currently at 13.25 (on really stiff springs) and will probably only go another 0.5" lower, which will only require trimming the inside lip of the chargespeed fenders.
At that hieght I will still run less than 3 deg camber, where as before I ran close to 3.5. I think most folks will only drop slightly more (especially if they have lips) and reduce their camber. hope this helps, javid (from his cell phone at jfk) |
08-25-2006, 09:53 PM | #105 |
Member#: 67993
Vehicle:2004 sti blue |
so at 14" ride height in front, do you have any recomendations for camber? currently i run -3 but am looking for more front end grip. i plan on testing whith pyrometer. however time and a sutable test site are hard to find. a good starting point is all i am looking for thanks.
08-28-2006, 12:46 PM | #108 |
Member#: 7492
South East
The machine shop had a small issue with the first batch. They broke a couple of saws while machining and lost a couple of days to getting a fancy new one in. Also had a slight delay in the drilling of the material for the through holes.
We are a bit delayed, but should start shipping these mid week. Very sorry about the delay. We built in some "slack" time and ended up using it and more. -Tom |
08-28-2006, 03:57 PM | #109 | |
Vendor Sales Rating: (159)
Member#: 93646
Vehicle:Many Track Records Let us help you go fast! |
-Clint |
08-29-2006, 07:23 AM | #110 | |
Member#: 48773
Vehicle:2004 TiC WRX also '99 BMW M Roadster |
08-31-2006, 02:31 PM | #114 |
Member#: 7492
South East
They are here!
Labels will be printing shortly. I shall do my best to get to UPS today with all the boxes before ground shipping is cut off. If not, they will go out tomorrow My day job already thinks I'm wierd as I have balljoint adapters and tie rod adapters sitting in my work cube. -Tom PS. They are pretty. Pictures will be posted when I get home 7ish |
08-31-2006, 04:53 PM | #115 | |
Member#: 62182
NWIC
Vehicle:2005 STI White |
-Mike |
08-31-2006, 07:30 PM | #117 |
Member Sales Rating: (6)
Member#: 41149
SCIC
Vehicle:09 FXT SSM |
One thing that's been bugging me. There's no way to cotter pin the connection between the tie rod and the tie rod extender, correct? Is that a possible problem?
08-31-2006, 08:47 PM | #118 |
Member#: 37813
South East
It is not a problem. There will be a "taper lock" as the taper 100% matches up the tie rod end. Also, there is a grade 8 allen head "set screw" that is screwed down to lock the extension on the tie rod end. Vice grips will be required for installation to hold the tie rod end while the extender is put on. We have run all this through the engineer and the proper torque can be put on the part and the set screw and taper is more then enough to hold the torque.
-Tom Sorry, left logged in as my roomate. |
08-31-2006, 09:46 PM | #119 | |
Member#: 41149
SCIC
09-05-2006, 07:16 PM | #120 |
Member#: 93646
hey guys - all have shipped except for 1 set. that one set is for the hawaii guy. Yours came to us so we can ship via USPS as you requested. As soon as our sets arrive yours is headed to you.
-Clint |
Installation of the 6Gun Racing Ball Joint Extension Kit | nhluhr | Brakes, Steering & Suspension | 82 | 01-06-2010 01:44 PM |
6Gun Racing Ball Joint Adapters | Turn in Concepts | Suspension/Brakes/Handling | 13 | 10-18-2006 11:08 AM |
6Gun Racing Ball Joint Extension Kit | nhluhr | Car Part Reviews | 119 | 10-02-2006 01:19 PM |
6Gun Racing Ball Joint Extension Kit | kaliformula | Car Part Reviews | 7 | 09-29-2006 12:54 AM |
