04-15-2005, 11:40 PM | #1 |
Member#: 26876
NESIC
Vehicle:1994 Camaro Z28 383 Black M6 |
what would happen if you had a 5 inch
thick titanium cube, completely full of water, and you heated it up to 1000F?
04-15-2005, 11:42 PM | #2 |
Member#: 82259
BAIC
Vehicle:1999 impreza 2.2L Brilliant Red <4EAT Club> |
the titatinium would expand...the water would expand very little.
04-15-2005, 11:42 PM | #3 |
Member#: 18647
you'd spring a leak
04-15-2005, 11:43 PM | #4 |
Member#: 51358
RMIC
Vehicle:2007 FXT Once a month its blue. |
Thats a helluva water balloon.
04-15-2005, 11:45 PM | #5 |
Member#: 27986
The water would boil.
04-15-2005, 11:45 PM | #6 |
Member#: 56615
Kabooyeeeeeeee! Prolly nothing much, Titanium melts at 3020*F, so you are a third of the way there. How about the dimensions of the cube?
04-15-2005, 11:47 PM | #7 |
Member#: 2307
Vehicle:2018 KTM500EXC Orange |
5 inch thick. Is this solid? Wall thickness of Ti? Who ya gonna call?
04-15-2005, 11:48 PM | #8 |
Member#: 26876
NESIC
5 inch thick walls, inside open area of a square foot completely full of water.
04-15-2005, 11:49 PM | #9 |
Member#: 7977
Vehicle:100% Abuse |
I dunno.
But if you squeeze it just as you heat it up, it'll shoot further. |
04-15-2005, 11:51 PM | #10 |
Member#: 19111
water would turn to steam...increasing the pressure....making it more difficult for further steam to be produced. system would equalize.
just a guess. |
04-15-2005, 11:53 PM | #11 | |
Member#: 7977
It won't turn to steam, no space. |
04-15-2005, 11:53 PM | #12 |
Member#: 5778
South East
Vehicle:09 135i Jet Black |
what would be the water temp? if its completely sealed the water would expand and increase pressure inside the cube....
04-15-2005, 11:54 PM | #13 | |
Member#: 67803
Vehicle:Get busy living, or get busy dying. |
04-15-2005, 11:56 PM | #14 | |
Member#: 19111
ahhh...but the titanium hast expanded. |
04-15-2005, 11:56 PM | #15 | |
Member#: 7977
04-15-2005, 11:59 PM | #16 | |
Member#: 26876
NESIC
04-16-2005, 12:00 AM | #17 | |
Member#: 19111
ahh...screw it |
04-16-2005, 12:09 AM | #18 |
Member#: 41012
E. Canada
Vehicle:1998 Legacy L |
Im betting it would explode. As rogue mentioned, pv=nrt. If n,R stays the same and V stays relatively the same while temp increases then Pressure would increase. Really depends on what type of titanium were talking about i guess since it has a variety of tensile strengths
04-16-2005, 12:18 AM | #19 | |
Member#: 41589
Vehicle:Suff erer Club Founder (RGSSC) |
Probably it'd be mostly water, and whatever small amount of expansion the cube offered would allow a small portion to vaporize to saturated steam, at equilibrium with the water's dew point at that temp. I'd be more concerned with the tensile strength of a 5" thick cross-section of titanium. Thin metal is more likely to expand like a balloon than thick stuff which usually just cracks. With a thick piece, the temperature gradient across the outside (which would be at the flame's temperature) vs. the inside which would remain a constant 100*C (or more if the steam/liquid 2-phase equilib. The temp difference would probably cause the titanium to have a thermal fracture...like when a windshield stone chip turns into a crack when you're blasting the defrost on a bitter cold morning. Compound that the fact that thick metal is less "forgiving" than thin stuff, as mentioned earlier...and looking at the pressure of the steam at its super heated spot on the steam table...It would blow, and BIG!!!!. Most (all?) gases are stored in cylinders at cold, cold temps (a product of both the P vs. T graph and the fixed volume from PV=RT...n is constant)...think how thick normal gas cylinders are. If you tried to store water vapor (gas state) at that high of a temp, the P vs. T graph would have pressures so rediculously high (factors of at least 100)...5" thick wouldn't be close enough... Then again, I'd have to run the numbers and my Thermo book with the explosion/high pressure section is in storage, and *pop* *crackle* *fizzxxzxxzxzzxzxzxzzz* ...hey, where am I? Oooooooooh look, I got a pimple on my ass, I'm gonna' take a video of me popping it DRum |
04-16-2005, 12:29 AM | #20 |
Member#: 26876
NESIC
Thanks Doc.
04-16-2005, 12:34 AM | #21 |
Member#: 42177
Vehicle:2005 STi WRB |
the water would be in a superheated state, under huge pressure. It also depends on if its distilled or tap water. Tap water would boil because of impurities, but distilled water will stay liquid. What made you think of this anyway?
04-16-2005, 12:37 AM | #22 |
Member#: 9401
NESIC
Vehicle:. Truth is a pathless land... |
sounds like a great anal dildo....to use on a women...
04-16-2005, 12:38 AM | #23 |
Member#: 26876
NESIC
Sorry wrong thread.
04-16-2005, 12:38 AM | #24 |
Member#: 75768
Vehicle:2006 Mazdaspeed 6 |
But wouldn't the titanium expand equally in all directions and therefore actually leave less space for the water and not more?
04-16-2005, 12:39 AM | #25 |
Member#: 41012
E. Canada
You cant compress a liquid, so no
What would happen if you dropped a flying squirrel out of a plane? | Jard | Off-Topic | 63 | 04-19-2011 03:09 PM |
What would happen if you ate a spoonful of yeast? | Guru Imakuni | Off-Topic | 30 | 03-12-2005 04:43 AM |
what would happen if you drank a gallon of red bull? | RaceCarRiot | Off-Topic | 15 | 05-24-2004 01:45 PM |
What would happen if you just replaced the front springs? | AdmireWantWillLove | Brakes, Steering & Suspension | 22 | 04-06-2004 05:54 PM |
