03-19-2008, 03:01 AM | #1 |
Member#: 149568
RMIC
Vehicle:2001 Turboed OBS Silver |
A/C bearing
So I am pretty sure my AC bearing is shot. Is it better to replace the whole AC compressor or just the bearing. I would like to just replace the bearing but I can find the part number for it or a DIY.
03-19-2008, 09:09 AM | #2 |
Member#: 1714
RMIC
Vehicle:1999 RS-T COUPE Black |
subaru ac compressors are not serviceable. if the noise is your compressor, you'll need to replace it as a unit.
03-19-2008, 11:13 AM | #3 |
Member#: 149568
RMIC
Ok thanks. I am guess that is something I can do rather than taking it to a shop
03-19-2008, 11:29 AM | #4 |
Member#: 149568
RMIC
What about the Idler pulley in front of the compressor. Can that be replaced
Similar Threads | ||||
Driveshaft/carrier bearing worn out? (car bounces) | Speedwagon | Transmission (AT/MT) & Driveline | 0 | 06-04-2010 05:24 AM |
are front wheel bearing on Impreza'a press in bearings? | Homemade WRX | Transmission (AT/MT) & Driveline | 7 | 10-22-2004 09:33 AM |
T/O Bearing + Wear on input shaft collar (T/O bearing surface)? | nils | Service & Maintenance | 0 | 07-22-2004 07:07 PM |
Ball bearing vs plain bearing | thng | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 06-21-2003 12:45 AM |
Noise! throwout bearing? pilot bearing? | Wellhung | Transmission (AT/MT) & Driveline | 16 | 11-03-2002 01:42 AM |
