07-08-2009, 02:17 PM | #1 |
Member Sales Rating: (2)
Member#: 188060
Vehicle:2003 WRX Sonic Yellow |
No Longer For Sale! Mods Please Delete
Located in Chesapeak, VA 23322. can ship if need be.
paid $2166 for the coilovers Im asking for a price of $1750 I installed these on the 05 STI back in fall of 08, and then lost the STI in a traggic accident in Feb of this year. I pulled them off the STI and now have no use for them as they will not fit my 03 WRX that replaced the STI. These coilovers are still in damn near perfect condition (minor scratches on paint from rocks/sand and such) and im rather sad they dont fit on the WRX . I have since cleaned em up and they are back in the original box waiting for a buyer. I can take more pics of em all cleaned up later. These coilovers are pretty amazing and at the out of the box height lowered the STI and made it look and drive fantasicly over the stock struts. You can feel a difference in each of the 5 stiffness settings. im sad to depart with them, but like i said, they are useless to me. Rally Sport Direct claims they fit 2002+ WRX/ 2004 STI, but they will not fit my 03 due to the hub bolt spacing being slightly shorter than my 05 STI. Not sure about fitament with 06/07, someone else will have to confirm that. Def will fit 05 STI tho -- Before they were cleaned (rear set) -- a 4 (crappy picture) -- Pulled from the site i bought them from(RallySportDirect.com): "With all the same benefits and features as the Zero-2 coilover, the Zero-2E adds the option to electronically control the shock adjustment from inside the car. Utilizing the E-Con (sold separately), you can select what stage (of 5) you want the shock set at. With great features such as: - Electronically controlled shock adjustment (w/ E-Con) - Pillowball upper mounts - Adjustable shock casing - Independent adjustable spring perch - Stainless steel thread body - Stainless steel case lock nut - Stainless steel spring perch/lock nut - Specially coated lower bracket Fits perfectly for any style driving. The advanced design features 5-stages of shock adjustment that exhibits incredible performance! Create a comfortable ride for your passengers. Too stiff? Comfort is just a button away. No more frustrated passengers! Larger size pillowball used in the upper mounts. Endures through the hardest drives! Height adjustment and spring pre-load are designed to be adjusted independently. Lower your car with the adjustable shock casing while retaining the overall shock stroke. Set the spring pre-load to your desire and feel the difference in driving and traction. Cusco developed a new shock absorber for the Zero-2E that further reduces friction resistance of the dampening force to achieve high performance with the vehicle lowered. Worried about rust? No problem with the Zero-2E’s stainless steel lock nuts, lower seat, and threads. With the external cylinder and threads being stainless steel, adjusting the height will be smooth. The lower bracket/case has a new special coating as well. The internal as well as the external surface has been coated."
07-09-2009, 06:44 PM | #2 |
Member#: 188060
bump for a sweet deal on a perfect set of CUSCO Zero2e's. Never raced in, however i can not deny spirited driving
07-25-2009, 06:26 PM | #6 |
Member Sales Rating: (18)
Member#: 102929
South East
Vehicle:2003 07STi,03,07 STi SWP/ WRB/UGM#239 |
wish I could buy these but it would cut into my funds my daughters first Disney trip. Good luck with the sale
08-14-2009, 11:39 AM | #16 |
Member#: 188060
oh they definately should, but if you wanna check heres what you look for:
Check the spacing between your 2 big bolts that hold your strut onto the wheel hub. Just pop your wheel off and you should be able to check it. From the center of the top bolt to teh center of the bottom bolt should be almost exactly 3 inches. I say center meaning the diameter of bolt. or: 2 & 6/16 inches of space between the 2 bolts. This spacing was why it wouldnt fit my 03 WRX, but your 04 STI should be exactly the same as my 05 STI so it should go right on with no problems. |
08-14-2009, 03:56 PM | #17 |
Member#: 92372
RMIC
Vehicle:2008 Black on Black |
05-07 STi changed the axle/hub design and bolt pattern. so these will not bolt up to a 04 STi. It's all in the hub, clevis design.
hope that helps |
09-02-2009, 01:18 PM | #21 |
Member#: 188060
As you can see in the pictures, these coilovers are in great condition. And your getting em cheap, and practicly getting the E-Con for free (a $500 little piece of equipment)
09-14-2009, 10:48 PM | #23 |
Member#: 188060
Coilovers still available. had a buyer and he backed out after the deal was made, after a week of not getting back up with me.
Similar Threads | ||||
FS NY: GC Cusco Zero2 coilovers with just over 1k miles of use and Cusco front STB | garface | Suspension/Brakes/Handling | 21 | 01-23-2010 02:41 AM |
FS: Cusco Zero2E Coilovers with E-Con EDFC system | eclip5e | NESIC Private Classifieds | 5 | 12-16-2008 12:36 PM |
FS // FT : STI UTEC (new in box, Never Installed) | lcw | North West Impreza Club Forum -- NWIC | 0 | 06-27-2005 05:07 AM |
FS: Cusco Zero2 coilovers with adjustable link bars | Nitro Don | Private 'For Sale' Classifieds | 4 | 04-03-2005 01:43 AM |
FS: OEM rear lip in silver , still in box never mounted | protouring72 | Tri-State Area Forum | 7 | 12-21-2002 12:43 PM |
