10-18-2011, 10:14 PM | #2776 |
Member#: 146287
BAIC
Vehicle:2011 Impreza WRX 5D Satin White Pearl |
10-18-2011, 10:29 PM | #2777 |
Member#: 202129
Vehicle:2012 WRX Hatch Ice Silver Metallic |
10-19-2011, 02:49 AM | #2778 |
Member#: 197939
Vehicle:08 Impreza Dark Charcol |
10-19-2011, 06:39 AM | #2779 | |
Member#: 288727
Anyone here know about camber and our cars? I'm know I needs bolts for the rear but how about the front? |
10-19-2011, 09:01 AM | #2780 |
Member#: 146287
BAIC
No bolts for the rear. The multi link design has very dynamic camber so as you go low, the camber goes way negative. You can get either the Whiteline kit (KCA326) or a set of Lower Control Arms. LCAs generally offer a wider range of adjustment.
Most coilovers come with camber plates in the front so you good there unless you want -4* of camber. One of these days I might get more motivated to sell my BC Coils... Last edited by JourdanWithaU; 10-19-2011 at 12:21 PM. |
10-19-2011, 11:27 AM | #2781 |
Member#: 288727
I'll probably never go more than -3 haha. Thanks for the info!
10-20-2011, 03:27 AM | #2782 |
Member#: 197939
Yeah. I got just Eibach springs on mine and the ride isn't too bad right now, but i can tell that my struts aren't gonna last very long.
10-21-2011, 11:46 AM | #2783 | ||
Member#: 277258
BAIC
Vehicle:2008 Hatch 2.5i DGM |
I just put my CAI on and I see now every time I hit the gas the intake rubs against the body where that piece is..so I need one of those!! |
10-21-2011, 12:23 PM | #2784 |
Member#: 236778
Vehicle:08 Impreza SWP |
^^^^ that black sleeve looks like copper pipe insulation
10-21-2011, 03:15 PM | #2785 | |
Member#: 146287
BAIC
I sorta have plans to get the exhaust aligned away from the bumper as well as a rear lip to cover the damage. I also kinda want to get a '09-'10 WRX bumper and go quad tip. I may end up doing both because the lip is part of a kit that has a front and sides. So I'd get all the lips and still get a WRX bumper later. |
10-22-2011, 09:10 AM | #2786 | |
Member#: 202129
10-22-2011, 03:08 PM | #2787 | ||
Member#: 277258
BAIC
Just a few pictures, not sure if I've posted on here yet, nothing special yet.. Rear chrome delete, and debadge (quick snap shot) rear chrome delete by tmangt650, on Flickr New (er) lip, had it for a little while now. front lip by tmangt650, on Flickr front lip outside by tmangt650, on Flickr More to come so far Mod list includes; Small mod list.. Tsudo N1 3" cat back exhaust 2008 OEM Front lip by Seibon Cosmo Racing CAI Window Tint 2 10" MTX Jackhammer subwoofers Powered by 1000 watt HiFonics Amp with a 0ga Amp Kit Currently in possesion waiting for install, Fog lights Rear under spoiler On the Xmas/B-day list (two weeks away from each other) Rear STI Wing Front mesh grill Rota torque hyper black 17" wheels Thule Roof rack Dual Hella Horns (painted red) |
10-22-2011, 08:13 PM | #2788 |
Member#: 298035
Vehicle:2008 Impreza Sedan lightning red |
Hi guys. New to the forums. I recently picked up an 08 red impreza sedan with 1300 miles on it. I was wondering what you all might think the best 5 performance modifications you would make to this car and the best 5 interior/exterior/sound modifications you would make. Thanks.
10-22-2011, 10:38 PM | #2789 | |
Member#: 250295
Vehicle:2010 Outback Sport Black |
As far as performance goes, first on your list should be a rear sway bar, as the 08+ NA Impreza don't even have one. You can pick up a used WRX RSB with endlinks and bushings and everything for less than $100 here on the forums. That's a 15mm bar. Personally, i went with a 19mm Rallitek RSB, which is the same as our front bar, or an STI rear bar. It's up to you what size to go with, but do some research on the handling characteristics. Next, if your car is a 5spd, get a short shifter kit WITH front and rear shifter bushings. I got a full Kartboy setup, and it totally transformed the way the car drives. The bushings can be difficult to install if you don't know what you're doing, but they're worth the trouble. If your car is an auto, well... Then, you might consider springs, exhaust or intake. But keep in mind, most aftermarket exhausts are made for WRXs with 3" piping, which is too big for the NA. Something about back pressure, we end up losing low end torque. If that's ok with you, go for it, plenty of guys here do. But basically, you won't get much power out of the 2.5i without spending tons of money, it's just not worth it. Spend that money on suspension upgrades and you'll have a slow car that handles awesome and is still a blast to drive. I don't have much to say on interior/exterior upgrades. That depends on your personal style. And as far as sound...well, the stereo on the 08-10 Imprezas SUCKS, but i would rather spend that money on performance upgrades. Again, that's just me. Good luck with your new Impreza and keep us updated on your upgrades! |
10-22-2011, 11:28 PM | #2790 |
Member#: 298035
Thanks. It an automatic. Guess I should have said so. I got tired of the stick in my Tiburon. Too many hills around here.
10-23-2011, 08:22 AM | #2791 | |
Member#: 272381
Vehicle:2004 Franky the Forester |
10-23-2011, 08:46 AM | #2792 |
Member#: 298035
Apparently it must have been driving by a little ole couple from Ft. Worth who only drove it to church on Sundays.
10-23-2011, 08:46 AM | #2793 |
Member#: 298720
Vehicle:2011 impreza 5 door silver |
10-23-2011, 08:48 AM | #2794 |
Member#: 288190
Vehicle:2009 Impreza 2.5i Spark Silver |
suspension would be one of the things you can focus on, I've seen some N/A's cream on turbocharged cars on the track. then again, it could be the driver
10-23-2011, 11:11 AM | #2795 | |
Member#: 288727
10-23-2011, 01:42 PM | #2796 |
Member#: 260641
10-23-2011, 02:16 PM | #2797 |
Member#: 262503
Vehicle:2008 Impreza 2.5i |
GrimmSpeeds is nice. Considering I live 20 minutes from them I should get theirs but I have a home-made version lol. Here's a couple shots.
10-24-2011, 09:55 AM | #2798 |
Member#: 277258
BAIC
Little help here guys and gals. Recently (friday before last) installed a Cosmo CAI, (yes after doing a bunch of research) and a week later I see my first CEL (with the green cruise light blinking as well). I thought it could have been because I was driving kind of hard on a hot day. But it just came up again after going about 5-7 minutes to work.
Now I thought that when I bought it the air filter had oil on it and actually looked recently and it doesn't, so I know I gotta spray it down. And I will, but will that get rid of the CELL (think it could be the fact that because there is no oil, its not catching the dirt so it goes into the engine). Lastly, no did not get it tuned, was also mentioned to me that wasn't necessary. Any help would be appreciated!! |
10-24-2011, 08:42 PM | #2799 |
Member#: 1748
NESIC
Vehicle:'09 Outback Sport OBP over DGM |
Go to an auto parts store and have them pull the error code from the ECU. The ECU can't tell if you have oil on your filter or not, so I doubt that's it.
My guess is that you are running lean. Common problem with intakes on the MAF subies. I would get it tuned, or skip the intake. There is a big thread on intakes for the NA cars in the NA forum. |
10-25-2011, 10:21 AM | #2800 |
Member#: 65720
Vehicle:2016 Outback Lapis Blue |
Hi all, new first-time Subie owner (yes, I know I joined seven years ago - been lurking for that long!) Just bought a certified '08 Impreza 5-door for the missus and we're both loving it. Handles great and far quieter than what we traded in ('03 Matrix XRS).
Couple of noob questions: -what is the easiest/best way to de-chrome the buttstache? -we're looking at adding the OEM iPod cable but I'd rather run it to the glove box than the armrest. Is this feasible (i.e., can I just run the cable through the left side of the glove box, or will it get pinched?) Thanks in advance! |
08 2.5i and 08 Sti Suspension | WRXbrother | Brakes, Steering & Suspension | 10 | 08-22-2017 12:30 AM |
Will an 08 WRX intake fit an 08 2.5i? | Racing101 | Normally Aspirated Powertrain | 26 | 01-19-2012 11:57 AM |
08 STI Wing on 08 2.5i impreza | juny102004 | Interior & Exterior Modification | 13 | 01-18-2012 09:46 AM |
Will 08+ WRX gauges swap into 08+ 2.5i? | Simeon Priest | Interior & Exterior Modification | 10 | 03-26-2010 02:17 PM |
08 2.5i mod question | deunique1 | Impreza Forum | 1 | 10-03-2007 02:35 PM |
