12-07-2004, 03:47 PM | #1 |
Member#: 44292
NESIC
Vehicle:..: F-15 Eagle ..: |
Anyone know how to recover date from a CD-RW?
I thought iwas doing something good by moving my files to a cd-rw, but everytime i try to move the files back to the PC it fails!!!
saying the file is read-only and cannot copy is there any fixing to this or can i kiss those mp3's and mpg's goodbye?
12-07-2004, 03:50 PM | #2 |
Member#: 27231
Maybe you don't have the rights on the PC you are using? Dunno...I've never had that issue. FWIW... cd-rW is the debbil's work. cd-r ONLY for me.
12-07-2004, 03:53 PM | #3 |
Member#: 44292
NESIC
I know but eve my cd-r says make sure the the disk is not full or right protected
12-07-2004, 03:57 PM | #4 |
Member#: 16350
Vehicle:2018 M3 1971 521 2018 GLA45 AMG |
You try rebooting your computer
12-07-2004, 03:59 PM | #5 |
Member#: 44292
NESIC
yep did it 2 times and still get the same message ....
12-07-2004, 04:06 PM | #6 |
Member#: 17974
SWIC
um dont move just copy?
try xcopy too |
12-07-2004, 04:13 PM | #7 |
Member#: 44292
NESIC
negative on both... it keep give ,me and error even on cut and paste style.
12-07-2004, 04:17 PM | #8 |
Member#: 17974
SWIC
try a different PC? maybe a mac even?
clean the disc? |
12-07-2004, 04:18 PM | #9 |
Member#: 44292
NESIC
no way to try a different pc and not way to get hands on a mac.
12-07-2004, 04:20 PM | #10 |
Member#: 44292
NESIC
It tells me the disk is either corrupted or using a format not known to windows.
12-07-2004, 04:39 PM | #11 |
Member#: 5659
NWIC
You can't MOVE files from the CD...you can only copy them. It looked like you tried this already, but worth mentioning. When you perform a move, it attempts to remove the file from the source at the end of the operation. Since you can't remove from the CD, it fails.
If it still fails after a copy, try the disc into a different CD-ROM device and see how it works. -* |
12-07-2004, 04:42 PM | #12 |
Member#: 44292
NESIC
i tried in a different cd rom and it says it cant read it it might be corrupt.
12-07-2004, 05:29 PM | #13 |
Member#: 23003
If its saying read only, you have to format the disk. Same thing happened to me a week ago
12-07-2004, 05:52 PM | #14 |
Member#: 36712
Vehicle:2003 WRX Wagon WRB |
Double click an MP3 file while its on the CDRW. If your system has an MP3 player accociated with MP3's, it might play. If it does, you have a permissions or attributes issue, or maybe you are out of disk space. If it opens winamp or media player or similar, but doesn't play, you have a CDRW issue.
You can usually get at least some data back from a foobar CD by opening your burning application and using a command like "save track as *.ISO". Might also be called "save disc image". |
12-07-2004, 07:46 PM | #15 |
Member#: 44292
NESIC
I tried buring the cd again but keeps giving me an error thats bad.
*If it opens winamp or media player or similar, but doesn't play, you have a CDRW issue. * that happened. |
12-07-2004, 07:49 PM | #16 |
Member#: 75768
Vehicle:2006 Mazdaspeed 6 |
Just to make sure it's completely clear.
You cannot just drag the files, that will attempt to move them, which you cannot do. And there is a difference between cut and copy. Cut will not work. |
12-07-2004, 08:45 PM | #17 |
Member#: 44292
NESIC
So what can i do than? i need the files.
I tried burning a copy of the cd into a cd-r no good i tried ripping the files onto my drive no good |
12-07-2004, 08:59 PM | #18 |
Member#: 11271
NESIC
i think your SOL
-SF |
12-07-2004, 09:00 PM | #19 |
Member#: 33442
Vehicle:2/4 ModsWantToBanMe IBBARNED |
i think your SF
12-07-2004, 09:28 PM | #20 |
Member#: 36712
You can attempt to save an image of the CDRW to your hard drive as an ".ISO" type file, then use a program called ISOBUSTER, or similar, to recover the files from the .ISO image file.
If you can't save the image file to the hard drive, then you probably are, in fact, SOL. |
12-07-2004, 09:47 PM | #21 |
Member#: 44292
NESIC
I think i am SOL.
Anyone know how to recover the wagon bench? | whatishe | Interior & Exterior Modification | 1 | 10-13-2008 11:39 AM |
Anyone know how to get pics from a txt to my pc? | dickpainter | Off-Topic | 19 | 05-14-2007 11:06 PM |
anyone know how to remove shielding from TB speaker? | ironfinger | Car Audio, Video & Security | 3 | 04-07-2007 12:19 AM |
Anyone know how to access aim from work? | wReXeRw | Off-Topic | 17 | 07-06-2005 06:46 PM |
anyone know how to remove toolbar from browser? | ImprezaTs | Off-Topic | 11 | 11-08-2004 02:19 AM |
