04-07-2013, 05:15 PM | #51 |
Member#: 319479
AKIC
Vehicle:2012 WRX Gray |
I think I fixed it.. IDK if I need to use a new link so here is the link that was there. I hope this works guys.
https://docs.google.com/file/d/0Bx1E...it?usp=sharing
04-07-2013, 05:31 PM | #52 | |
Member#: 321409
SWIC
Vehicle:2003 Big Effing Van 7.3L powerstroke diesel |
Engine Speed (RPM) [RR] Engine Load (1 byte) (g/rev) [RR] IAM [RR] Ignition Total Timing[RR] Fine Learning Knock Correction (degrees)[RR] Feedback Knock Correction(degrees)[RR] Throttle Opening Angle(%)[RR] Manifold Relative Pressure(corrected)(PSI)[RR] Primary Wastegate Duty Cycle(%) A/F Sensor #1(AFR)[RR] Mass Airflow (g/s)[AP&RR] Injector Duty Cycle(%)[RR] A/F Correction 1(%)[RR] A/F Learning 1(%)[RR] Vehicle Speed (mph)[AP or RR http://www.wrxforums.com/forums/57-t...mters-log.html |
04-07-2013, 05:49 PM | #53 | |
Member#: 319479
AKIC
Alright sounds good. The roads are still absolutely covered in snow and ice so I wont be able to data log anything for a few days. Ill get on it as soon as I can though. Is there any specific type of pull I should do for it? Or just a third gear pull like I did is good enough? |
04-07-2013, 06:11 PM | #54 |
Member#: 321409
SWIC
Start your wot pull just above 2,000 rpm and hold it to just below redline. In the meantime if you can't get a wot pull in safely you can do a cruise log. Add AF Learning A,B,C,D ranges to your logging parameters and just do some normal driving.
04-07-2013, 06:38 PM | #55 |
Member#: 319479
AKIC
Alright. Ill try to get something in today.
04-10-2013, 09:49 PM | #56 |
Member#: 319479
AKIC
Hey guys, so it hasn't stopped snowing here since over the weekend and it's apparently spring? I can't wait to move next month, haha.
I was reading up on other people's post today an the search wouldn't work for me for some reason, but their article was saying you had to do other things other than just plugging the Tactrix cable into the OBD2 and the laptop? It was showing green plugs and black plugs? Also, I followed romraider's post on how to instal everything properly, and my RomRaider software works obviously to datalog, but my ecu flash won't work? Or atleast I don't know how to work it maybe? I've tried to find solutions but again the search wouldn't work. Any suggestions are great! |
04-10-2013, 10:14 PM | #57 |
Member#: 321409
SWIC
You don't need to worry about the other connectors on the later model cars. With your tactrix cable plugged into the OBDII port and the ignition off can you launch the ecuflash on your laptop? What message is it giving you? If it opens up OK then scroll over the tab on the top left with the arrow coming out of it. It should say Read from ECU. Click on it. It should prompt you to turn on the ignition and to leave it on until completed (don't engage starter though). It should READ the rom on your car. It will prompt you to turn off the ignition when you are done. It may ask you if you want to save it after you turn ignition back off. As long as you followed instructions on romraider on how to install current definitions then it should recognize the ECU CAL ID and Rom (.hex) file. If so you can save a copy of the stock rom on your laptop.
04-10-2013, 10:21 PM | #58 |
Member#: 321409
SWIC
Dude, Since you are using romraider , have you used the application Learning View yet. It's a handy program. It will give you your LTFT's and any FLKC currently stored. It will also allow you to save a screenshot and post it up as a .jpg
Linked here zip file at bottom of the first post: http://www.romraider.com/forum/topic2772.html Last edited by nmlittlebigman; 04-10-2013 at 10:25 PM. Reason: add link |
04-11-2013, 11:23 PM | #59 |
Member#: 319479
AKIC
[quote=nmlittlebigman;39562954]quote]
Awesome, thanks man. Youve been ALOT of help. I should have time Saturday to try to figure all of this out. Ive been thinking about getting a Torqued Performance tune.. thanks for turning me on to them! |
04-12-2013, 09:08 AM | #60 | |
Member#: 339591
Vehicle:2009 STI silver |
https://sites.google.com/site/asubie...gguide/ver-1-0 |
04-12-2013, 09:20 AM | #61 | |
Member#: 319479
AKIC
04-13-2013, 07:44 PM | #62 |
Member#: 319479
AKIC
I just realized that that's the same write up I read already haha.
02-02-2014, 02:02 PM | #63 |
Member#: 319479
AKIC
Hey all.. Ive been away for a while but I am back!
I have been reading alot but could use some help. I hear a loud squeal when I'm under boost. I thought it was coming from my BPV so I replaced the gasket, it worked! For about a week... I went out and did a WOT pull and datalogged it, also just a drive around datalog. I was wondering if theres anyone out there that can check it out and let me know if they see anything alarming? Im looking over it now and dont see anything. The other thing is it feels like I am getting a slight surge or something higher 3k RPM. Thanks in advance all! |
02-02-2014, 02:54 PM | #64 |
Member#: 321409
SWIC
Check your hoses: turbo to intercooler and intercooler to throttle body. Ditch the rubber inserts on the ends of the intercooler to TB hose and reinstall.
02-02-2014, 03:27 PM | #65 |
Member#: 319479
AKIC
I checked what I could. Ive been told that there shouldnt be an issue with them since the car is still stock and I havent messed with the TMIC.
02-02-2014, 04:01 PM | #66 |
Member#: 321409
SWIC
No there shouldn't be but boost leaks can show up on brand new cars. A squealing sound under boost is pretty indicative of a loose hose/ hose clamp.
02-02-2014, 04:18 PM | #67 |
Member#: 319479
AKIC
Makes sense.. im about to get back to my parking lot so I'll get to checking.
Good news. I just bought "How to Tune and Modify Automotive Engine Management Systems". Really excited to get into it. |
02-02-2014, 05:52 PM | #68 |
Member#: 319479
AKIC
Wrong post
02-02-2014, 06:48 PM | #69 |
Member#: 321409
SWIC
As I stated before : http://forums.nasioc.com/forums/show...3&postcount=52
02-02-2014, 07:02 PM | #70 | |
Member#: 319479
AKIC
You are completely right! Thats also the same old datalog, I am very sorry. I clicked the wrong link to share. I apologize. |
02-02-2014, 07:22 PM | #71 | |
Member#: 319479
AKIC
https://drive.google.com/file/d/0Bx1...it?usp=sharing Alright this should work.. I apologize for that again. |
