Welcome to the North American Subaru Impreza Owners Club Saturday March 28, 2015
Old 04-28-2014, 12:02 PM   #176
Bryan82
Member#: 346731
2015 WRX
Ice Silver
Originally Posted by ride5000 View Post
decel only noises with lightweight flywheels are very common.
basically you're hearing the gear lash due to compression braking.
Thanks for the response, I think I'll throw the stock flywheel back in there and see how that goes.
Bryan82 is offline   Reply With Quote
Old 05-20-2014, 12:23 PM   #177
choloman05
Member#: 99359
02 wagon
blackish-blue
I'm so glad I found this thread. Now I just need to live closer to one of you guys so I can pay you to do this for me. Getting this done at the dealer or local shop is $$$ and I never enjoy doing business that way anyway.
choloman05 is offline   Reply With Quote
Old 05-21-2014, 09:34 PM   #178
02whitewagon
Member#: 391510
This seems to be the same issue im having BUT when the clutch is not engaged the noise is gone not faint gone, same as when I let off the throttle the only time its happening is under load 3rd through 5th and very faint
02whitewagon is offline   Reply With Quote
Old 10-07-2014, 02:19 AM   #179
Djicko011
Member#: 403111
2001 impreza TS
Hi guys....any of you have and willing to sell transfer gear and driven gear? I have 2001 subaru impreza 2.2 liter engine...PM please and thak you
Djicko011 is offline   Reply With Quote
Old 10-07-2014, 11:15 AM   #180
Leafy
Member#: 330625
2006 WRX
So I replaced these. Subaru changed the actual the two tapered bearings while keeping the part numbers the same. They physically fit in the same place but the bearings themselves are smaller. At the same time I noticed my driveshaft was pretty much shot. I forgot to put the shim that goes between the gear and the diff in the first time and all the noises were gone except for a random wine going on and off throttle. After I put that back in my wirring noise has turned into a rattling clunking noise in 5th with the car in the air, I need to figure out what the issue is now if I screwed something else up. I'm not sure what could have happened unless the tapered race in the front fell out because I didnt take it all the way apart the 2nd time.
*doesnt make the weird rattle on the ground. I've been driving it without issue.
Old 10-26-2014, 01:37 PM   #181
f_emweball
Member#: 404800
This thread has been lots of help, I plan on replacing the center diff bearing in my subaru . I just have a couple questions
Where is it reccomended I get these bearings from ? Also I have an automatic transmission, does this make any difference ?
f_emweball is offline   Reply With Quote
Old 10-27-2014, 07:18 AM   #182
Leafy
Member#: 330625
2006 WRX
I think they're dealer only and that you should buy the ones that fit your car.
Old 10-27-2014, 10:07 AM   #183
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Bearings are bearings. As long as the size and numbers match that's what matters.I found you won't save a lot at a bearing shop. But avoid the Chinese bearings.
Sent from my SM-G900V using NASIOC mobile app
hybrid gti 2 is offline   Reply With Quote
Old 10-31-2014, 11:11 PM   #184
meinct
Member#: 350408
2012 wrx
dgm
Doing this tomorrow. Any tips or tricks I should know about before I start?
meinct is offline   Reply With Quote
Old 11-13-2014, 11:38 AM   #185
live2ridetahoe
Member#: 31386
2008 WRX Avant
How did it go? Were you replacing bearings on your 2012 or another model year? I have an 08 and was wondering if the part numbers are the same.
Tahoe
live2ridetahoe is offline   Reply With Quote
Old 11-13-2014, 11:59 AM   #186
USLiberty
Member#: 294466
1993 Legacy SS
white
I did R&R about a year ago, stealership qouted me around 375$, they negotiated down to 275$. I said suck it and found them for 125$ shipped on a wholesale Subaru part website. I have a 03 wrx 5spd/diff in my 93 ej20g legacy. Got the transmission from a friend for a 30pack, unfortunately someone had already swapped the center diff bearings with theirs and neglected to install the largest bearing. I drove it for a week like that unaware but definitely feeling something wrong.
The install was relatively easy, had to get one bearing pressed out. After having one bearing missing it felt much more solid, but the constant rollover noise was still there under 30mph. I suspect my center diff is still bad as the transmission only has 100k and shifts great. I ended up buying a very low mileage jdm ej20g/5speed(4.11) out of an Liberty RS for 1000$.
USLiberty is online now   Reply With Quote
Old 11-13-2014, 12:02 PM   #187
Leafy
Member#: 330625
2006 WRX
Honestly $275 from the stealership isnt that bad of a deal at all. Its 125 just for the parts, then another 40ish for fluid, and its still going to take them at least 2 hours to do it on a lift. Really not bad at all. Especially if your car has been rally-x'ed like mine. So much dirt in my eyes the second I touched the shift linkage.
Old 11-13-2014, 12:45 PM   #188
meinct
Member#: 350408
2012 wrx
dgm
Tahoe
It's a 2012 wrx. It went ok for my first time doing it. Took longer than expected but thats usually the case.
All the part numbers are the same. I used the ones a couple pages back that has the picture of all 4 bearings.
Only one of the bearings really looked bad but I replaced all 4 anyway.
The picture of the bearing and a video of the noise it was making are near the end of this thread.
http://forums.nasioc.com/forums/show....php?t=1170285
Noise is completely gone now so if yours is makin a noise like in the video it is most likely the bearing.
Old 11-13-2014, 11:02 PM   #189
f_emweball
Member#: 404800
I have an 2002 automatic subaru impreza and it is making the same noise as indicated. I went to subaru to order 4 overpriced bearings (because its an auto it makes it even harder to find parts like these), an oil seal and a gasket and it came up to $480.. decided not to. Im not sure if the automatic transmission is different, but it seemed like there are only 3 bearings in the center diff, including the one thats on the shaft. Can someone tell me how to post a picture on here so i can specify if these are the overpriced bearings i must buy ?
Old 11-13-2014, 11:48 PM   #190
meinct
Member#: 350408
2012 wrx
dgm
I use photobucket. Its free. Load your pictures to it then click on the picture you want and to the right will be the code you need . Click on it and it will auto copy. Come back here and paste.
Old 11-14-2014, 06:12 PM   #191
USLiberty
Member#: 294466
1993 Legacy SS
white
Wish I could tell you that was the price for labor too, but that 275$ was parts alone! Not calling it a stealership for no reason. I do all my own work, and reused my oil.
Old 11-15-2014, 09:43 AM   #192
f_emweball
Member#: 404800
Here are the pictures. Someone please help, especially if done before.
http://s40.photobucket.com/user/f_em...tml?sort=3&o=1
Old 11-15-2014, 10:25 AM   #193
USLiberty
Member#: 294466
1993 Legacy SS
white
I dont see the center diff in that exploded diagram. I'm pretty sure the automatic is much different than the 5 speed. Automatics are same length as a 6speed which is longer than a 5speed.
Old 11-15-2014, 11:02 AM   #194
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
there is no VC in an AT center diff.
Old 11-15-2014, 11:33 AM   #195
f_emweball
Member#: 404800
Ohhh okay. The picture i posted is of the reduction gear.
I am confused now of what must be done. After i remove the extension case, there is the transfer drive gear, and transfer driven gear correct ? Are the bearings on these the ones that need to be replaced ?
Old 11-15-2014, 11:50 AM   #196
meinct
Member#: 350408
2012 wrx
dgm
Those are the ones I replaced plus one on the center diff itself.
Old 02-08-2015, 04:56 PM   #197
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Awesome thread. Doing this for the first time.
Subscribe.
WTB: center diff / transfer case for my 98 2.5RS MR2fanatic Private 'Wanted' Classifieds 1 10-01-2009 12:52 AM
NEED: Center Diff/Transfer Case MyRuRex Private 'Wanted' Classifieds 7 07-09-2009 11:01 PM
FS: IN: 04 STi 6 Speed With Center Diff And Rear Diff STiGuy46554 Drivetrain 5 09-20-2008 12:10 PM
For sale 02 WRX tranny case,center diff and drive gears felixwankel88 Drivetrain 2 06-06-2007 06:22 PM
Bearing preload for center diff transfer gears. 340Duster Transmission (AT/MT) & Driveline 2 05-21-2007 04:24 PM
