10-08-2005, 11:42 AM | #1 |
Member#: 75986
Vehicle:2005 Subaru STI WR Blue 529whp 471wtq |
Having Tilton Clutch Issues........Please help
I just got a Tilton twin disk installed on my 05 Sti. I've got alot of weird sounds coming from the clutch. Sounds like a soft BOV when I press the clutch in....almost like one of the disks is still spinning. Also, when either I'm in 1st or Reverse....ever so often I hear aloud pop against the fire wall but, I'm not for sure that's where the sound is coming from cause its hard to track down. At 1st it was bought for my STI but it was filed away to try and fit a WRX but it would not work or fit for some reason so, it was installed on my STI...now I'm having these problems........please help!!!
10-08-2005, 01:07 PM | #2 |
Member#: 36792
Vehicle: 2018 BMW M2 2016 FRS RS 2.0 #661 |
That pop might be from a missing/loose bolt on the pitch mount. As for the weird noises, they just may be the common characteristics that plague most twin disks.
10-08-2005, 01:13 PM | #3 |
Member#: 75986
Is the car safe to drive.....how can I fix the problem?
10-08-2005, 01:32 PM | #4 |
Member#: 486
Vehicle:2014 BMW 328i xDrive F31 Sport Wagon |
The discs are splined to the input shaft of the transmission... they spin up and down with the action of the gearset, that's what makes the clattering sound when you have the clutch in... they decelerate and the clutch cover keeps spinning where it's attached to the flywheel.
As for the other noises, the Tilton hydraulic throwout system may have some air in it or something that's making that noise. Try bleeding the system via the bleed tube coming up out of the bellhousing and see if that helps. Just a shot in the dark... it could be anything. I hope they didn't "file away" anything on the clutch... the only thing that has to be modified is the bell housing. The clutch itself is a balanced rotating assembly, very bad things can happen if it is out of balance. Think 7000rpm and things wobbling... not a pretty picture. Good luck getting your troubles straightened out! IBamodmovesthistothetransmissionforum |
10-08-2005, 02:54 PM | #5 |
Member#: 75986
Could the front or central diff. be broken? How about axles?
10-08-2005, 03:45 PM | #6 |
Member#: 13617
Vehicle:2001 Legacy GT back to stock is a project too |
that bov sound is normal to the twin plate clutches, i have heard it on the exedy also, i think it sounds cool personally, as far as the pop I am not sure, I would talk to Brad at Titan motorsports, he can probably help you.
Ben |
10-08-2005, 05:30 PM | #7 |
Member#: 75986
Hey guys I just wanted to thank you for all your help. I just don't know where to go to get this problem fixed. Please keep your tech advice coming....I'll let you guys know later when the problem is solved...thanks again
10-11-2005, 02:34 PM | #8 |
Member#: 78884
Vehicle:Go faster at TopSpeed |
How is the clutch slave cylinder mounted... if its not in correctly it can move causing the noise your hearing.
I Think I Have A Clutch Issue | onebadwrx | Transmission (AT/MT) & Driveline | 8 | 09-12-2009 06:44 PM |
FT: Tilton Clutch Setup | jet2686 | Drivetrain | 5 | 06-10-2008 12:54 PM |
TILTON twin plate clutch issue | tino | Built Motor Discussion | 6 | 02-08-2008 10:20 AM |
Tilton Clutch Review | STi_Guy04 | Transmission (AT/MT) & Driveline | 3 | 12-24-2006 10:23 PM |
To those with Tilton Clutches | greysave | Transmission (AT/MT) & Driveline | 1 | 09-02-2006 11:10 PM |
