10-31-2006, 12:50 PM | #1 |
Member#: 82487
Vehicle:2007 WRX STI Spec C |
will 2.0 water pump, belts fit 2.5 block??
Can i reuse the water pump, timing belt, bearings from EJ205 for a hybrid WRX head on 2.5 shortblock?
10-31-2006, 01:05 PM | #2 |
Member#: 82391
Vehicle:08 OBP Sti |
Ive been told you can get by with the water pump i wasnt recomended it by any means oil pump was a bad ideal you may contaminate the block with old oil gunk debrease.
Timing belt i wouldnt even try to reuse it just sounds like trouble waiting to happen. |
10-31-2006, 08:36 PM | #3 |
Member#: 82487
sorry guys, let me rephrase. i don't mean reusing parts. i mean, are the parts same? EJ205 water pump, belt. same as EJ257 water pump, belt.
"get by"? so they are not the same at all? as in, totally different parts with different part #? |
10-31-2006, 09:22 PM | #4 |
Member#: 82391
I was going to use the wrx tension belt, and a new sti water pump far as i know they will work. Im not sure on the oil pump some say its the same item between wrx and sti ?
I changed my mind as im in no position to break another motor or tranny from all the displacement torque of a 257 beside i like what i have stg2 is just slow. |
11-01-2006, 12:13 AM | #5 |
Member#: 82487
thanks for your input dingo.
anyone knows for sure? |
11-01-2006, 12:35 AM | #6 |
Member#: 25413
Water pump.. absolutely.
Oil pump... absolutely. Timing belt... I don't know I bought a new one. Actually... I bought new parts for all 3 above mentioned but I am sure of what I stated. |
11-01-2006, 12:58 AM | #7 |
Member#: 82487
ok, will do. thanks!!
FS: PA: water pump from 07 WRX EJ255 block | jonpark | Engine/Power/Exhaust | 6 | 12-12-2008 10:32 AM |
Need a new OEM water pump for my 2.0/2.5 hybrid | toomuch | Private 'Wanted' Classifieds | 0 | 12-19-2007 10:25 AM |
2.2 liter Water Pump Question | badsswrx | Normally Aspirated Powertrain | 9 | 09-13-2006 09:47 PM |
Why Upgrade Water pump on Supercharged 2.5 rs? (5psi) | awd4ever | Normally Aspirated with bolt-on Forced Induction Powertrain | 6 | 11-26-2005 10:03 PM |
Water pump belt driven?? | eightballrj | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 09-23-2003 04:45 PM |
