01-30-2005, 09:43 PM | #1 |
Member#: 23676
NESIC
Vehicle:. |
Drag racers, I seek your input for my motor swap :)
I have an 02 wrx with a wasted motor.
WHich will make me faster? Keep in mind that I am going to be doing an RA gearset, which will basically gear the car down. STI 2.5 shortblock. TON of torque, a couple hp. or V7 budget longblock. Same power, about the same torque, 8000rpm redline. The torque would be great, but I am thinking the ability to spin freely to 8000rpm will make the car faster overall, especially with the RA gearset effectively shortening each gear, the extra 1000rpm will stretch the lower gears back out,for a tremendous gain in acceleration. How far off am I?? |
01-30-2005, 09:48 PM | #2 |
Member#: 45449
Tri-State
Vehicle:93 FDLS1 5.7 liters>1.3 liters |
what turbo are you planning to use?
01-30-2005, 09:59 PM | #3 | |
Member#: 23676
NESIC
Vehicle:. |
I dont have HUGE power goals. S0 the 22 is just fine. |
01-30-2005, 10:04 PM | #4 |
Member#: 9090
Vehicle:09 Forester Gump 02WRX->04STi->09Gump |
~v6 |
01-30-2005, 11:23 PM | #5 | |
Member#: 63218
Tri-State
02-03-2005, 11:27 AM | #6 | |
Member#: 3362
Vehicle:2001 I've wired a Few cars in my day |
02-03-2005, 11:42 AM | #7 | |
Member#: 58647
Tri-State
Vehicle:02 Exedy Carbon clutches SLIP and SUCK $! |
02-03-2005, 06:34 PM | #8 | |
Member#: 42253
Vehicle:2003 RWD WRX Alcohol injected, WRB |
Seriously though, go with the ver7 because if you're dragracing then you have or will think about nitrous and the extra strength of the ver7 will serve you better. |
01-31-2005, 12:02 AM | #9 |
Member#: 12281
Tri-State
Vehicle:08 FSXT Tiger's Blood |
funniest pic ev4r!
01-31-2005, 12:13 AM | #10 |
Member#: 7022
MWSOC
Vehicle:2001 Forester Arcadia green |
v7 is soooo smooth at 8k ;-)
Then again, a 257 short w/ worked heads and a good set of cams would make a screamer... 2 very different paths for speed... |
01-31-2005, 12:25 AM | #11 |
Member#: 12449
SCIC
22 would be teeny on the 2.5. If price is an issue, usdm 2.5. If you want finess, v7
01-31-2005, 12:59 AM | #12 |
Member#: 45516
MAIC
Vehicle:MY04 STi Black |
I would get the 2.0. At the top of 4th gera, at 8krpm, you'll be at about 110-115, which is pretty much where your vf22 is going to be able to take you in terms of trap speed at the MOST. Good luck dude.
01-31-2005, 01:06 AM | #13 |
Member#: 69461
South East
Vehicle:2004 WRB/Sti 11.41 @ 123mph |
what da hell is that a pic of!!!! LOL I might be stupi but I cant figure it out LOL haha
01-31-2005, 02:46 AM | #14 |
Member#: 26876
NESIC
Vehicle:1994 Camaro Z28 383 Black M6 |
Will you get an ecu with the v7 or leave the avcs dead?
I say go with the longblock since theres so many beatdown miles on the heads. |
01-31-2005, 04:56 AM | #15 |
Member#: 524
Vehicle:04 STi White |
uhh... just run the EJ257 with a 8K redline.
01-31-2005, 05:16 AM | #16 |
Member#: 58647
Tri-State
Go with a V7, if ya can look for a Spec-C swap as they seem to be getting cheaper and cheaper
01-31-2005, 06:57 AM | #17 | |
Member#: 37731
01-31-2005, 07:10 AM | #18 | |
Member#: 23717
NESIC
Vehicle:2005 Big red |
Dave I say go the V7 LB I think you will be much happier in the end. TMS |
01-31-2005, 06:21 AM | #19 |
Member#: 9090
Honestly an 8k limit and a 5 speed would be perfect for.
I bet your ¼ mile time would benefit quite a bit too. ~v6 |
01-31-2005, 07:17 AM | #20 |
Member#: 524
would he? Strange... My STi makes peak HP at 7,500, and I haven't gotten the limiter kicked up to 8K yet on it... just 7,500.
Cams would definitely make a difference at that RPM, but just getting a good turbo with plenty of turbine flow is all you need. |
01-31-2005, 07:49 AM | #21 | |
Member#: 23717
NESIC
TMS |
01-31-2005, 07:45 AM | #22 |
Member#: 9090
Yeah, cause theres no chance of blowing an STi motor by over revving it...
~v6 |
01-31-2005, 07:46 AM | #23 |
Member#: 23676
NESIC
Vehicle:. |
WIth the longblock, no ecu, AVCS dead.
with the 2.5, stock WRX cams, stock unworked wrx heads, no money for headwork or cams. I think I am agreeing that the 8k redline will be awesome with the 5 speed, and the thing about putting me at 110-112 at the top of fourth sounds about perfect. I ran JUST shy of 108 with my current setup, I am betting that the extra 1k redline will push me close to that 110-112 (coupled with the RA gearing) And even though the 2.0 wont give me the torque that the 2.5 would, I am still going to effectively be putting a good bit more torque to the ground with the lower gearing anyway.... |
01-31-2005, 07:50 AM | #24 |
Member#: 9090
i think you should sell it, get a third job an get an STi
~v6 |
01-31-2005, 08:42 AM | #25 | |
Member#: 23676
NESIC
Vehicle:. |
Not a chance in hell that is happening. If I wanted a GM product I would buy a camaro. ANd any 04 that I find will most likely have been beaten and who knows how it was taken care of. I will never buy a new Subaru again due to the GM quality. If They go back to Japanese ownership I will. My next subaru will be a used L 2 door with a swap My plan is to fix this, then once its paid off buy a Jeep (with the 4.0ho motor) for a daily driver. Keeping this as a toy |
Similar Threads | ||||
Need your help for my motor ... | darko | Built Motor Discussion | 5 | 01-26-2009 02:07 PM |
Registrars Seek YOUR Input on Event Registration | rallygoddess | Alaskan Impreza Club Forum -- AKIC | 6 | 01-19-2009 12:33 PM |
May I have your Input? : My 1st Tattoo.. | skimmilk68 | Off-Topic | 54 | 06-10-2006 07:40 PM |
looking for a shop to finish my motor swap | 25rstautoxr | Mid West Subaru Owners Club Forum -- MWSOC | 89 | 08-10-2005 02:01 PM |
Need input for my suspension setup...No, really, i need your help... | ChristophWRX | Brakes, Steering & Suspension | 12 | 06-08-2003 11:22 PM |
