02-07-2006, 05:54 PM | #1 |
Member#: 7022
MWSOC
Vehicle:2001 Forester Arcadia green |
Green users. Whats your spool like?
When ya hittin full boost, when does your turbo "come online". ETC ETC.
Just looking to gauge what I am getting againsts others running the same turbo. |
02-08-2006, 12:38 PM | #2 | |
Member#: 37938
Vehicle:02 WRX Blue Mica |
02-08-2006, 01:13 PM | #3 |
Member#: 4718
VIC
Vehicle:I gotz a Subaru again |
On the 2.5 STi that I drove with the green, it hit hard at around 3800rpm. I can't tell you exactly when or where in the rpm range, because it hit so hard that I had to pay attention to the road.
Imho, the green is the best street turbo for the STi. |
02-08-2006, 01:54 PM | #4 |
Member#: 7022
MWSOC
3800 eh? Alright, sounds about right with what I am getting. Thanks
02-08-2006, 02:05 PM | #5 |
Member#: 105797
Vehicle:2005 05 Wrx STi Black |
300 whp at 3k... i am VERY close to stock spool
02-08-2006, 02:09 PM | #6 |
Member#: 27108
MWSOC
Vehicle:2004 STi 2004 A4 |
From recent logs (20-50degF ambient air temps)...
All on a 6-speed... 5th gear: >1bar @ 2900rpm 4th gear: >1bar @ 3200rpm 3rd gear: >1bar @ 3600rpm Last edited by x99percent; 02-08-2006 at 03:06 PM. Reason: more accurate, more info |
02-08-2006, 02:26 PM | #7 |
Member#: 62221
it spools sooner in 5th gear rather than 4th??
02-08-2006, 02:55 PM | #8 | |
Member#: 27108
MWSOC
Don't confuse RPM with time. It's definitely not "faster" in 5th versus 4th. |
02-08-2006, 05:12 PM | #9 |
Member#: 62221
oh, thanks for explaining.
02-09-2006, 01:11 AM | #10 |
Member#: 31997
MAIC
Vehicle:08 QSM Spec Bizzle 96 XJ Beater |
Question: Theoretically, an 06 WRX could get pretty dag on close to spool like that on a green?
02-09-2006, 01:31 AM | #11 | |
Member#: 39301
BAIC
Vehicle:STi 05 8cm FPRed WRX 06 Blue FP20G |
02-09-2006, 11:48 AM | #12 |
Member#: 4718
VIC
good call on the compression. I wonder if the heads would limit it's spool on a standard 2.5L? |
02-09-2006, 05:34 PM | #13 |
Member#: 84912
SCIC
Vehicle:2003 2.5L bugeye now with 6 spd 20g! |
^ I would say it would limit top end power.
I just called FP trying to order a 20g and they started talking about the green. I had to hang up. they have me all confused now. dammit. Last edited by the_colombian; 02-09-2006 at 06:07 PM. |
02-09-2006, 07:49 PM | #14 | |
Member#: 23300
Vehicle:1996 Talon TSi AWD Black |
I was looking at the green and they were talking about a 20G for me. |
02-09-2006, 06:45 PM | #15 |
Member#: 62221
why? the td06-20g and green are identical turbos save for one having a larger compressor wheel than the other.
Similar Threads | ||||
ap users what are your volts? | g3ninfinite | Newbies & FAQs | 1 | 06-15-2007 04:06 AM |
What are your oil pressure and temperature readings, what do you like to see? | 02R6 | Built Motor Discussion | 4 | 10-23-2006 07:10 PM |
Big Turboe'd STIs...Whats your spool/boost onset like? | MARKGSTI | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 25 | 03-14-2006 08:09 PM |
At what psi are you green users maxing the map at 5v? | kenlee | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 30 | 11-03-2005 10:37 PM |
COBB AP users w/ laptop... whats your USB-->DB9 "bits/second"? | Max Umbarger | Engine Management & Tuning | 4 | 07-11-2005 12:19 AM |
