02-01-2007, 09:09 PM | #1 |
Merci Buckets
Moderator Member#: 88606
Vehicle:2018 Grand Cherokee Velvet Red Pearl |
Installation of '05 STi gauge cluster into '05 WRX
For those wondering if its possible and how to do it, here it is.
If you aren't able to find one for sale in the classifieds, you'll need to order the parts from the dealership. I didn't know, but apparently the cluster doesn't come pre-assembled. You will need to order the individual components and assemble the cluster yourself. Total cost is close to $560, but I had some subaru bucks and that helped a lot. Pieces you'll need: Main Assembly - P/N: 85021FE170 Window Plate - P/N: 85070FE120 Glass - P/N: 85075FE000 Visor - P/N: 85057FE000 Knob Kit - P/N: 85077FE030 For assembly, you install the knob kit (yes, you have to buy the shift light adjustment knob separately) into the Main Assembly. You then lay the Window Plate over the top. Next, snap the Glass onto the Visor assembly. Once this is done, carefully set the Glass / Visor assembly over the two knobs and then clip it into place onto the Main Assembly. Voila, you have an assembled cluster. From there, follow these instructions to install the cluster. You do NOT need to cut the B28 wire (yellow w/ pale green). Cutting that wire is what causes the ABS light to come on. I reconnected it this morning, drove all day, and saw no other issues arise from it still being attached. You do still need to cut the orange w/ white wire on the right plug. The major difference is the left connector. The directions say to file down the tab on the cluster. Due to the shape and alignment of the connector, I found it easiest to simply use a pair of cutters and remove two of the tabs from the connector...see below. When you're done, you get a working cluster that doesn't buzz / beep. The Rear Diff light is the only one that'll stay on because you have no rear diff temp sensor. For those of us with '05 and newer cars, the exterior temp sensor does function! Hope this is helpful, enjoy. With a set of MadDad Clarity V2 Ti gauges in the center pod. Now that you're done, go back into the kitchen and make yourself a sammich. I recommend one of these: Mmmmmm....grilled chicken, fresh mozzarella, lettuce, and a homemade pesto mayonnaise all on some fresh garlic and cheese bread.
Last edited by Scooby921; 05-12-2009 at 08:16 AM. Reason: B28 wire (yellow w/ pale green) doesn't need to be cut |
02-01-2007, 09:22 PM | #2 |
Member#: 97854
Vehicle:2005 Impreza WRX STi Silver |
Sounds (and looks) like a tasty sammich
02-01-2007, 09:22 PM | #3 |
Member#: 37719
Vehicle:2003 WRX |
You *******! Did you have to post that last pic of that fine crafted masterpiece?!
02-02-2007, 06:22 AM | #4 |
Member#: 139531
damn that looks hella nice
02-02-2007, 08:45 AM | #5 |
Member#: 25039
Vehicle:2005 CGM Stage 2 WRX SQC 275 |
Wait, so what about the mileage count?
02-02-2007, 11:23 AM | #6 |
Member#: 117767
RMIC
Vehicle:2014 Audi S4 DP Stage 2 (~420whp) |
His mileage count will read starting at "0". So now if today he drives for 500 miles. The cluster will read "500". Not the actual mileage he had on the car.
02-02-2007, 11:32 AM | #7 |
Member#: 25039
So isn't that technically illegal?
02-02-2007, 02:28 PM | #8 |
Member#: 117767
RMIC
Yes, unless you get the mileage changed professionally by a company such as tacomaspeedometer.com.
- You send them the new cluster and have it set to the mileage to match the actual hours on the engine. And in order to make it legal they give you stickers (to put in the doorsill I believe) indicating the cluster change on the car. Otherwise if you buy the new cluster from the dealer and have them install it I believe it's legal because the installation is done by the certified dealership and the changes will be documented. |
02-02-2007, 04:11 PM | #9 |
Member#: 25039
So what, do we buy the parts and assemble it ourselves and then bring it to the dealer and have it installed to make it legal?
02-02-2007, 04:30 PM | #10 | |
Member#: 117767
RMIC
When you buy new wheels/tires from discount tire or belle tire do you buy them, take them home and mount the tires yourself then take it back to have the wheels put on the car? Come on.... |
02-03-2007, 12:26 AM | #11 | ||
Merci Buckets
Update on install - the B28 wire that is supposed to be cut (yellow w/ pale green) does not need to be cut on an '05. Cutting that wire is what makes the ABS light come on. I reattached the wires, the light went off, and I have yet to see any other malfunctions from it. |
04-26-2007, 01:12 PM | #12 |
Member#: 97352
SCIC
Vehicle:2005 6MT 35R Wagon Full STI drivetrain |
Sorry to bring this back from the dead, but from what I read in your initial post, the external temperature function will work on the 05 wrx without having to connect a sensor?
05-14-2007, 01:02 PM | #13 |
Merci Buckets
Correct. Part of the automatic climate control setup on the '05 and newer models is an external thermometer. No need to fabricate / install a separate one.
05-14-2007, 05:51 PM | #14 |
Member#: 85635
VIC
Vehicle:'05 2.5RS CGM |
where would i go to get a temp sensor for this install?
05-16-2007, 12:59 PM | #15 |
Merci Buckets
You might try subarugenuineparts.com. They are based out of a Subaru dealership, so I have a feeling Jamie can get you the temp sensor unit. Where you connect it or how you wire it up are questions I can't answer. Hopefully you can figure those ones out.
05-16-2007, 03:14 PM | #16 |
Member#: 85635
VIC
im still trying to find a place where i can get a used cluster or new for cheaper than retail. 550US is a little steep in my perspective. any ideas?
05-16-2007, 08:53 PM | #17 |
Member#: 138747
try ebay...or the for sale forums on here. good luck.
05-16-2007, 08:54 PM | #18 |
Member#: 138747
04-02-2010, 02:59 PM | #19 |
Member#: 221140
RMIC
Vehicle:2005 hybrid=fun :-D 93 L 2.5rs rally preped |
so does the shift light/beeep beeep beeep still work on the cluster?
04-02-2010, 07:50 PM | #20 |
Member#: 126614
SCIC
Vehicle:2006 WRB WRX TR OS Stage 2 |
you will need the auto HVAC on the newer wrx for the outside temp to work. If you have manual HVAC (ex. TR models) the outside temp does NOT work. Ppl are still working on fixing that, but haven't been figured out yet. Other than that, everything works perfectly.
04 STI Gauge Cluster into 04 WRX - Brake light? | Craigster05 | Electrical & Lighting | 4 | 01-11-2010 12:49 PM |
2008 STi gauge cluster into 04 WRX | whatishe | Interior & Exterior Modification | 0 | 09-02-2008 10:22 AM |
Swapping STI Gauge cluster into a 07 WRX | 07BlueWRX | Interior & Exterior Modification | 5 | 05-14-2008 01:43 AM |
STi Gauge Cluster into a 2002 WRX, fuse problem | MTR_Suby02 | Newbies & FAQs | 2 | 03-24-2007 09:32 PM |
Swapping 06 STI gauge cluster into 06 WRX | faheyr12 | Interior & Exterior Modification | 1 | 02-24-2007 10:30 PM |
