08-06-2007, 06:06 PM | #1 |
Member#: 78696
SCIC
Vehicle:2005 Wingless STI Aspen White |
05 STI, FP Red on dyno log
hey guys after working all weekend on this install i finally finished it. had to grind the block for the lower coolant line, loosen the intake manifold to muscle on the inlet pipe, which may i say does not fit correctly no matter what perrin or FP say.
Got everything done about 2 hours before i was scheduled to get tuned. Mods: FP Red 7cm housing internally gated perring 3" inlet cobb 70mm intake invidia divorced wastegate dp stock up aps 3" single tip exhaust pe 800s with pump ssac fmic core with aps pipes and aps fmic bov OH, and the TGV's are still installed!! had to remove the rear sensor on the passenger side though for the turbo to clear. DYNO: Dynolog (low reading) Numbers before the turbo swap with everything the same but the fmic, inlet and turbo: 228whp, 264wtq Numbers now: 341whp, 303wtq 19psi i gained over 100hp from the stock turbo and it pulls to redline. Problem is with the IWG, i'm having boost creep up to 22-23 psi at redline. my tuner tried to add fuel up there the best he could but the wastegate was 100% open and still building boost. I'll post all the graphs when i get home so you guys can take a look. I'm very impressed with how responsive the car is and i think those are pretty good numbers on this dyno. I believe a stock sti dynos below 200 on this. graphs coming. CJ |
08-06-2007, 06:10 PM | #2 |
Member#: 104200
TXIC
Vehicle:000 WHP BUGEYE Street Proven Performance |
08-06-2007, 06:17 PM | #3 |
Member#: 124593
Vehicle:2007 Sti fp red 346whp 366wtq |
may have been a lil easier to get the inlet on if the intake manifold off
08-06-2007, 06:19 PM | #4 |
Member#: 78696
SCIC
yes it would have been, but with the diameter being what it is and the dogleg left at the end not being aggressive enough, it still got crimped like a motha on the manifold right before the turbo. either way, we got it in.
08-06-2007, 06:18 PM | #5 |
Member#: 78696
SCIC
what problem would that be? if one of those plates isn't open, you'll know it!
08-06-2007, 07:26 PM | #6 |
Member#: 44422
SWIC
Vehicle:2009 G8 GT Cammed, sprayed, stalled |
Sounds like an 8cm hotside might have helped with the creep issue.
08-06-2007, 07:29 PM | #7 |
Member#: 97616
SCIC
Vehicle:2005 AW STi - GONE 2009 Black 135i |
Why didn't you go with the 8cm exhaust housing to begin with? Are you planning on running an external wastegate later on?
09-19-2007, 11:34 PM | #8 |
Member#: 128003
RMIC
Vehicle:2005 STI WR Blue |
I've got an 05 STi fp red as well but with an 8cm housing. I haven't gotten any creep. But those numbers sound about right. Meth is next, more boost and a safer set up.
08-06-2007, 07:42 PM | #9 |
Member#: 114285
SCIC
Vehicle:2006 sti aspen white |
nice, especially since u were able to keep the tgv, post a dyno graph and where did you get tunned at
08-07-2007, 12:11 AM | #10 |
Member#: 115223
MWSOC
Vehicle:2005 Subaru STI silver |
I would look for a vac pre turbo I had the same thing w/ my 7cm red... it turned out to just be a vac leak pre turbo.
08-07-2007, 01:11 AM | #11 |
Member#: 4001
Vehicle:2006 Legacy GT Obsidian black |
EWG will help tremendously.
08-07-2007, 10:47 AM | #12 |
Member#: 78696
SCIC
well, i didn't go with the 8cm because i bought this turbo from a guy here on nasioc, although it was brand new. i do plan on going EWG in the future.
don't think i have a leak, we watched the wastegate open up 100% and the turbo was still building boost. can't hurt to check this out though. I got it tuned at Mavrik Motorsports by Ed (formerly of ESX, Brainstorm...) He hadn't tuned in a while. took him 8 hours and he didn't start till 8pm sunday night. i was there till 4am!! he never gave up though. Here are the graphs. The third shows my old dyno vs. the new. my AFR's go a bit lean at redline due to the boost creep. Ed tried to add fuel up top but wasn't noticing any increase in fuel past 85% duty cycle. He couldn't figure out why. The car feels very responsive and is an animal when it comes onto boost. i love the high pitch whistle the turbo makes as well. |
08-08-2007, 12:31 AM | #13 |
Member#: 103320
Vehicle:1998 swapped Forester L |
08-28-2007, 02:06 PM | #14 |
Member#: 2818
MAIC
Vehicle:2000 2.5RS |
You might be going static on the injectors at that point, even though IDC's are reported at 85%. You could try upping fuel pressure a little bit and pulling out a tad in the lower ranges to compensate.
08-07-2007, 01:50 PM | #15 |
Member#: 103320
nice! Your car is a great candidate for alcohol injection... you could safely run that 22-23 psi number I'd bet.
08-07-2007, 02:07 PM | #16 |
Member#: 126112
TXIC
Vehicle:93.5 Toyota Supra Red |
thats nice since your able to still keep the tgv's
08-07-2007, 02:38 PM | #17 |
Member#: 78696
SCIC
thanks guys. i thought it was a good number on that dyno, especially with the tgvs still in. i plan on removing them, installing an EWG and adding meth hopefully early next year. i'd love to break 400 on that dyno.
got to learn to drive my car before i do that. i have 140 more hp and 100 more tq at redline now so it's a handful for me right now. fun as hell though. |
08-07-2007, 02:57 PM | #18 |
Member#: 12454
Tri-State
Vehicle:10 Toyota Taco K8 SV650SF |
graphs look nice, although its hard to see much definition with those thick lines in that chart. did Ed purposly lean it out up top, looks like it worked well the power just keep climbing.
edit: read your comment nevermind ^ |
08-08-2007, 04:18 AM | #19 |
Member#: 110273
Vehicle:450 whp 30R STI 10.96@126 |
Nice, did ed open a shop up in fullerton now or is he just tuning there?? He tuned my buddies 350Z with APS TT kit and he did a great job, that car was alot of fun.. Also did one of my buddies sti's that came out really well..
08-08-2007, 04:54 AM | #20 |
Member#: 26933
BAIC
Vehicle:2006 STI CGM |
Is this on 91 Octane and do you have an EGT gauge?
-- Ed |
08-08-2007, 07:47 AM | #21 |
Member#: 56321
NESIC
Vehicle:2006 Honda El Camino Green |
Post up a log if you can, specifically with AFR and MAF g/sec. If the MAF limit wasn't upped or if the intake wasn't scaled correctly, this could account for what you are seeing.
08-08-2007, 10:31 AM | #22 |
Member#: 78696
SCIC
Ed is currently working at South Coast Subaru, but will be moving to Irvine Subaru as the shop forman. He is tuning part time at Mavrik.
yes this is on 91, unfortunately i don't have a egt gauge yet. crazymike, these are all the printouts i got. Ed almost finished the tune when he realized he was on the small map for the maf. He bumped it up for the bigger maf and it through off a lot. He had to go back in and take out a lot of fuel in the midrange. |
08-08-2007, 01:25 PM | #23 |
Member#: 6124
MWSOC
Vehicle:2000 NFR AP1 S2000 '07 Honda FIT sport (5MT) |
Now my question is this.
Is he lifting early? Or is the dyno not reading right? By 6600 RPM your power levels are absolutely tanking, as is boost. Now, is the 3.93 correction a percentage? If so sounds like you're making around 250AWHP on an uncorrected dyno. Might be a touch low, but on 91 octane it certainly isn't unthinkable. Other then that, looks good! If he's dialing in fuel up top, and it's not enrichening consider the pump, regulator, or pump controller. Yes, I know you have an aftermarket pump, but believe me, it wouldn't be the first time I've had a similar situation with a "walbro", to swap it, and all of the sudden flood the fuel mixture because I had been over compensating it in vain. Looks great! Jorge (RiftsWRX) www.ProjectWRX.com |
08-28-2007, 04:23 AM | #24 | |
Vendor
Member#: 156189
SCIC
No he's not lifting early, I had a problem with the timing pick up so I had to do the RPM off of wheel speed and got the number off a little. Yes the number before the SAE J607 is the percentage of correction. Each run will have it's own correction factor. The correction factor you are reffering to is off his old run before all his modification, and yes if you subtract the correction factor it came out to 253.6 WHP uncorrected. His run after his modifications has a correction factor of 4.67% for a uncorrected number of 325.7 WHP Best regards, Teddy |
08-28-2007, 08:57 AM | #25 | |
Member#: 6124
MWSOC
Damn, I get pissed off when my dynojet would add in .02% and have simply shut off the factors overall to not inflate the numbers. Jorge (RiftsWRX) www.ProjectWRX.com |
Similar Threads | ||||
Dyno Tune: COBB Tuning makes 350whp/403wtq! 05 STi, Stock turbo on E85! | Cobb Tuning | Proven Power Bragging | 13 | 09-16-2015 08:27 AM |
Agile Tuned 04 Sti - FP Red/Q16 1/4 mile run | 04fpgreensti | Proven Power Bragging | 19 | 07-24-2009 04:23 PM |
For Sale (AZ): 2004 Blue STi/FP Red 500+whp | ride_the_pony69 | Private Vehicle 'For Sale' Classifieds | 4 | 07-10-2007 08:51 PM |
FP Red on a 2.5 | wukindada | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 25 | 09-27-2006 09:23 AM |
FP RED on Stock 2.0, Questions??? | Peeblesmx445 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 10-30-2005 01:15 AM |
