09-18-2010, 11:29 PM | #1 |
Member#: 52314
South East
Vehicle:... 02 and 04 WRXs! 2020 G70 3.3T RWD |
Victim of Det?
I read mostly about cracked ringlands on the pistons, or spun bearings. It looks more like a lean condition on the cyl. Trying to figure out exactly what caused the erosion of the piston/ it melting to the bore. Sorry the second pic is from my phone.
09-18-2010, 11:33 PM | #2 |
Member#: 62408
South East
Vehicle:2002 wrx w/ STi guts 174k miles on Mobil 1 |
Were those marks in the cylinder, or it that from you trying to free it up??
09-18-2010, 11:36 PM | #3 |
Member#: 52314
South East
Thats aluminum of the piston melted onto the steel of the bore. The engine was running when I pulled it.
09-19-2010, 09:08 AM | #4 |
Member#: 52314
South East
Nothing?
09-19-2010, 09:14 AM | #5 |
Member#: 70395
Probably. Its not like there are a whole lot of possibilities here. What mods were you running?
09-19-2010, 03:18 PM | #6 |
Member#: 130354
Vehicle:2011 535xi |
Looks somewhat familiar... I'd start by getting your injectors checked out. Looks like cylinder 3???
Here is mine: |
09-19-2010, 06:42 PM | #7 |
Member#: 52314
South East
Thats exactly what I came up with today, I think its an injector failure, but Idk... I suppose #3 is more prone because its probably the hottest running cylinder. I have pictures to add.
09-19-2010, 06:47 PM | #8 |
Member#: 52314
South East
I think it ran lean and melted the piston, but thats my guess, I'm looking for other opinions
It was a Cobb stage 2, then was open source tuned to run 18-19 psi on just a ported TD04. I have a large TMIC, short ram and exhaust. Thats pretty much it for engine mods. |
10-02-2010, 12:05 AM | #9 |
Member#: 64908
Vehicle:10.8 XT+9.2@155 GR+ 9.1/157mph 2015 STI |
Detonation in that cylinder, look at all the pitting on the piston dome. probably cracked a ring land and it was burning oil. When you burn oil with your gas you end up with very little octane, which would cause the cylinder to start to run super hot and melt.
Check your knock correction range, if it was around the stock setting of 6100 and you were revving to say 6800-7k that's about 1k rpms of no knock control, so it would not pull any ignition, or show a knock count. Not to mention it would be in the range were the td04 is pushing some seriously hot air which would tend to detonate a lot. What was your timing and wideband AFR.. Hopefully you had a wideband or were tuned with one at least. Lots of timing or very lean tune or both.. Look at your number 1 piston as well.. Same corner nice and shinny. Your EGTs were probably pretty high when that melted. If it was a bad injector only 1 piston would look like it took some serious heat. |
09-19-2010, 07:18 PM | #10 |
Member#: 149262
Vehicle:03WR rallycarFXTleg PrimerGrey |
Man thats not fun.
09-19-2010, 07:22 PM | #11 |
Member#: 130354
I wish I could give you more info. I just got the results from my injector test last week and they were fine. Mine was a built ej205.
The clean piston top makes it look like the cylinder wasn't getting fuel. But it's possible that after the loss of compression the heat and the fuel washed away a lot of the carbon build up. Injector is the first thing I would check. After that I'm all ears. |
09-19-2010, 07:37 PM | #12 | |
Member#: 52314
South East
Yeah I am right now looking to find someone to flow test them. I'm working on a new build, only the cams from that engine are being reused. I need to figure out what caused this though. Next is to post this to the built motor discussion, people with more engine experience hang out there.
09-19-2010, 07:23 PM | #13 |
Member#: 130354
Here is my cylinder wall too:
My motor has not been broken down yet as I doubt anything in it will get reused. |
09-19-2010, 07:52 PM | #14 |
Member#: 130354
I suppose a bad coil could be an issue, but I would think you would have misfires before it got to that point of destruction.
09-20-2010, 12:11 AM | #15 |
Member#: 52314
South East
Yeah there was no CEL at all or anything other than the loss of power when the compression went to almost 0.
Have you had your tune looked at or the car logged for any issues on that side of things? |
09-20-2010, 12:24 AM | #16 |
Member#: 52314
South East
an interesting article; http://blogs.musclemustangfastfords....ton/index.html
10-03-2010, 04:49 AM | #17 | ||
Member#: 140444
Vehicle:05 Stage Free LGT ATP 3076, 6MT, AVO FMIC |
(I don't think it's possible, but I like to ask questions in cases like this...) |
10-05-2010, 11:45 AM | #18 |
Member#: 32792
Vehicle:2003 GGA MBP 12.9 / 105+ |
09-20-2010, 08:48 AM | #19 | |
Member#: 130354
I have not had the tune looked at by anyone other than the original tuner and no logging as the car was run as little as possible since the incident. Interesting article btw. |
09-20-2010, 12:28 PM | #20 | |
Member#: 52314
South East
Same here, except it was around 19psi, and I had the tuner go over the map, He said all the AFR numbers and timing were within the normal range for the setup I was running. So
09-20-2010, 12:56 PM | #21 |
Member#: 130354
Sounds like we are in the same boat. I'm going to see about maybe tearing down my block pretty soon and see how the skirts and rings look on the rest of the pistons. Maybe something that can show me if it was tuned too rich.
Hopefully some other folks will chime in here with some ideas. |
09-20-2010, 01:34 PM | #22 |
Member#: 52314
South East
No I agree, I don't see how too rich would cause it though? I could see in the case of a bad injector, the AFR was in line with by running 3 cyls rich and one lean. That was my earlier thought.
09-20-2010, 02:42 PM | #23 |
Member#: 130354
The article you linked described how it would be possible in a situation that is overly rich...
09-20-2010, 04:12 PM | #24 |
Member#: 52314
South East
Yeah, I just don't understand the lifting of the ringland, I would think in a cast piston it would simply crack. People talk about tiny amounts of fuel getting combusting and blowing the ring lands all the time.
Where's Soobaviator when you need him? |
09-21-2010, 09:16 AM | #25 |
Member#: 130354
If the ring were to get pinched and allow enough oil to get into the combustion chamber, then there would be detonation. Now, if the oil was to pool a little on the bottom then start to combust (oil burns hot and slow), then I could see it melting a piston in the location we both had it happen in.
Similar Threads | ||||
For those of you that are victims of road rage, I found the solution to the problem! | brucelee | Off-Topic | 78 | 02-15-2008 03:35 AM |
Help! cause of det or knock | DemiSlayer | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 12-23-2007 12:46 AM |
The sound of det | BoomerRS | Newbies & FAQs | 15 | 02-01-2006 08:09 PM |
Another victim of the Long Island Expressway | BlueDevil | Tri-State Area Forum | 17 | 09-06-2002 08:37 AM |
Victim of a driveby | whitewag | Mid West Subaru Owners Club Forum -- MWSOC | 16 | 12-24-2001 01:18 AM |
