10-25-2007, 01:19 AM | #1 |
Member#: 145936
BAIC
Vehicle:06 STi Aspen White |
how to replace the OEM roof vane to a CF?
i wanted to know how to take the OEM one and install the CF. Im sure you have to take the pillar off. Any1? thanks
10-25-2007, 09:05 AM | #2 |
Member#: 25039
Vehicle:2005 CGM Stage 2 WRX SQC 275 |
You have to remove the end caps of the roof vane and then you'll see the bolts that hold the center vane.
10-25-2007, 10:52 AM | #3 | |
Member#: 94706
TXIC
Vehicle:1995 Miata |
The end caps are held on by a plastic fastener. Look at the back of the mount and you'll see a plastic piece slotted for a phillips head screw driver. turn it to the left to loosen it and pop it out with a flat head or a pocket knife. Then push up and to the rear of the car on the body colored end cap (the direction you'll need to push is approximately parallel with the leading edge of the end cap) and it should pop off. the first time you do it, it takes a good bit of effort, but it should be fine. once you get that off, you'll be able to figure out the rest. |
FS (OH): 2007 STi oem roof vane, CGM end caps, complete! | coolblue05 | Exterior/Styling | 11 | 12-08-2008 08:36 AM |
How easy is the OEM security system to defeat ? | Sausage | Car Audio, Video & Security | 7 | 05-06-2007 10:05 AM |
what do you need to modify to fit the oem WRX lip to the RS front | scobaru | Interior & Exterior Modification | 1 | 12-31-2004 10:12 AM |
Is it hard to replace the OEM fog lights? | balajc | Interior & Exterior Modification | 4 | 07-07-2003 11:07 AM |
what's a replacement boost gauge to replace the oem one? | ldivinag | STi Forum Archive | 4 | 06-25-2003 01:17 AM |
