07-01-2002, 07:55 PM | #1 |
Member#: 16523
MWSOC
Hesitation @ 2700 RPMs.
Has anyone else noticed some hesitation, when accelerating, @ 2700 rpms? I never noticed it before but now I do. It only happens when I have the A/C on though. I used to have this same kind of hesitation when my old toyota had bad plugs and was misfiring. The hesitation feels like if you let off the gas for a split second while your accelerating.
I'm not sure if it's an A/C thing or if it's a bad spark plug. The weird thing is that, if it was a bad plug, there is no CEL. I'm just looking for some quick suggestions before I go giving the car a complete tune-up. Edit: Sorry...The hesitation happens at 2700 not 3700.
07-01-2002, 08:33 PM | #2 |
Member#: 6630
Vehicle:2001 GC8 black |
try the grounding mod
its pretty common hesitation, almost everyone has it |
07-01-2002, 09:53 PM | #3 |
Member#: 15764
Vehicle:00RS -Dumb all over A little ugly on the side |
My AC seems to suck all the power from my car.
I prefer 2-60 air anyways so i rarely use my AC |
07-01-2002, 10:45 PM | #4 | |
Member#: 16523
MWSOC
http://forums.nasioc.com/forums/show...hreadid=207722 Funny thing is...I never noticed the hesitation until after I did the mod. I also removed the ProECM that same day. Don't know if that has anything to do with it. |
07-01-2002, 11:47 PM | #5 |
Member#: 13394
Vehicle:2001 GC8 Coupe Silver |
I had that hesitation and the ECU recall fixed my problem. Mine was at 3500-3700 though (I think) but it was exactly like you say. It happened with a/c and with no a/c. Take it to your dealer and see if you can talk them into the ECU reprogram recall.
Jon |
07-02-2002, 12:28 AM | #6 |
Member#: 14962
Vehicle:2008 Impreza 2.5i Pearl |
I have been able to get rid of the hesitation with no A/C, or maybe just reduce it enough to negligible, but whenever the A/C is on it is very noticable. For me the reprogram didn't seem to help.
07-02-2002, 02:34 AM | #7 |
Member#: 2236
Vehicle:2000 Audi S4 silver/rally dirt brown |
After the grounding mod....My hesitation is GONE. With new plugs, an oil change, and the grounding mod, My car is smoother now than the day I drifted out of the dealer's lot.
The grounding mod is a MUST do. One guy used old lamp wire and got rid of the hesitation. do the mod now. your heavy foot will thank you later! |
07-02-2002, 11:11 AM | #8 |
Member#: 3851
MAIC
Vehicle:2007 Outback Ltd. Champagne Gold |
Given how easy/cheap it is to do.......I'd surely TRY the grounding mod......
07-02-2002, 01:14 PM | #9 |
Celebrity Guest Star
Member#: 10648
NESIC
Vehicle:2008 Acura TL Wicked Black |
It's less common with the '02s, but we still get it. Grounding mod is your best bet. Look up the "SPG" thread.
-IggDawg |
07-02-2002, 02:02 PM | #10 | |
Member#: 9015
Vehicle:2002 Impreza 2.5RS Platinum Silver Metallic |
07-02-2002, 03:27 PM | #11 | |
Member#: 638
Tri-State
Vehicle:93 L, 00 RS, 04 TS pat + nat |
P. |
07-02-2002, 09:44 PM | #12 | |
Member#: 16523
MWSOC
...I guess no one read my grounding mod adventure? http://forums.nasioc.com/forums/show...hreadid=207722 |
07-02-2002, 10:50 PM | #13 |
Member#: 15543
Vehicle:555 Having a Subaru shop means too many cars |
Not only use the ohm meter to measure the resistance with the key off, but also measure the voltage from two ground points while the engine is running.
07-02-2002, 11:08 PM | #14 |
Member#: 9243
NESIC
Vehicle:05 Nissan Titan 06 B9 (hers) |
Off the topic guys
Uhh, guys? He said it is when he has the A/C on. The hesitation he is getting is when the clutch on the A/C engages and disengages. When you get on the throttle, the clutch reduces the load sent to the A/C system pully to give more power for accelleration. This happens on my car and my fiance's Legacy Outback. I truly don't think the hesitation issue he is having is a grounding problem if it only occurs when the A/C is on and doesn't appear with the A/C off.
07-03-2002, 06:20 PM | #15 | |
Member#: 16523
MWSOC
Re: Off the topic guys
07-12-2002, 09:22 AM | #16 | |
Member#: 11548
Vehicle:'02 OBS silver |
I just did, thanks for the laugh, as in Been there Done that! |
