01-30-2014, 12:04 PM | #1 |
Member#: 68118
NWIC
Vehicle:2014 BRZ Ltd Satin White Pearl |
AWD Auto alignment woes
Has anyone else had issues with AWD Auto and their alignements? I had my car aligned 13 months ago and have put a little over 10k on its since there. My alignment specs were 1.6 degrees camber in the front and 1.4 degrees in the rear. I had them set my car to 0 degrees toe. As I went to rotate my tires yesterday my front tires were toast and all camber wear. I called AWD Auto and they told me the only cause is not getting an alignment 1-2 times a year and not rotating my tires enough. I called BS on that as my car has not had any accidents or incidents with the curbs. I figured since Russ and AWD Auto had such a good rep and I was referred there by so many NWIC members they would take care of me and see what happened with my settings. Instead, I was told the only thing they will do is charge me for another alignment at my expense. I do not understand how my tires can be so worn with so little miles at the settings I have and how the shop who performed that alignment will not assure there work. I do not expect them to pay for tires, but I would expect a legitimate shop to take care of its customers with issues like this.
Rant over. |
01-30-2014, 12:24 PM | #2 |
Member#: 233407
NWIC
Vehicle:2004 Aspen White STi PIA Tune 347whp 327tq |
Did you install new coilovers and had the alignment specs set to that right after install?
01-30-2014, 12:28 PM | #3 |
Member#: 68118
NWIC
01-30-2014, 12:37 PM | #4 |
Member#: 333099
NWIC
Vehicle:2013 WRX STi ISM |
I don't really see how you should be expected to get your car aligned 1-2 times a year. It shouldn't just go out of spec on its own. Camber doesn't usually do that much damage, improper toe does. Especially -1.6 degrees, that's hardly anything.
01-30-2014, 12:51 PM | #5 | |
Member#: 113496
Vehicle:... (V) (;,,;) (V) |
I am sorry to hear about your frustrations with the car. There are a few things that I am curious about over the last year... Were the tires rotated anywhere between, or is this the first rotation after 10,000 miles? Was the air pressure maintained? Is it possible that a pothole, expansion joint or some other road surface imperfection knocked the toe out of spec over the last 10,000 miles? Is your steering wheel still straight? In any case, I am happy to recheck your alignment at no charge for you, to see what has happened, even though we are beyond the warranty time. Let me know when you are ready to bring it in. Please make sure to ask for me when you call... -Ryan @ AWD |
01-30-2014, 01:21 PM | #6 |
Member#: 233407
NWIC
01-30-2014, 01:38 PM | #7 |
Member#: 97460
NWIC
01-30-2014, 01:48 PM | #8 |
Member#: 63767
NWIC
Vehicle:2009 OXT 5-spd 2011 STi hatch |
I am also curious if this was your first tire rotation since the alignment. Unfortunately there was many things that can pull the alignment out of line.
Tire rotation is one of the best ways to start seeing an issue along with hands off the steering wheel steering. I look at my tires at full lock between when I rotate them to look for issues. Tire pressures can flux a bunch between seasons, too. Dunkin asked some appropriate questions. From my own experience with alignments, I would get my alignment re-done after every two track days. And each time the alignment was off by a touch to over a full degree depending on how high on the curbs I got that session. I have never considered alignments static but then again I am not an expert. I realize track racing is not comparable to street driving. |
01-31-2014, 05:45 PM | #9 |
Member#: 4562
NWIC
Vehicle:2014 Electric Datsun 2005 Adventure van |
01-30-2014, 01:41 PM | #10 |
Member#: 233407
NWIC
01-30-2014, 01:45 PM | #11 |
Member#: 97460
NWIC
01-30-2014, 01:51 PM | #12 |
Member#: 68118
NWIC
Gotta thank Ryan for taking care of this. Appt already setup and all taken care of. Much appreciation to Ryan and AWD Auto for their help and handling of the situation.
01-30-2014, 02:18 PM | #13 |
Member#: 63767
NWIC
I'm glad they are taking care of you. Still curious about the above questions from people.
01-30-2014, 02:36 PM | #14 |
Member#: 68118
NWIC
Steering wheel is straight, air pressure is regularly checked, and rotated them about 5000 miles ago. I rarely drive through downtown and only put about 10 miles round trip to work. Other than that it's mostly drinking around everett/lynnwood area and the roads are pretty good up this way. The odd thing is they are both worn evenly. I could see if only one tire wore off and that could definitely e a result if a pothole or something from the road throwing it out if whack.
01-30-2014, 03:15 PM | #15 | |
Member#: 113496
Many things are possible, as we live in a dynamic world. However, I am glad to hear that this is not the first tire rotation and the pressures have been maintained. We will see you this afternoon, get the heads set up on the car and see what has changed from the previous alignment. Sadly, Russ has moved on to Portland, Oregon, but we do still have Tim the Magician here. |
01-30-2014, 03:26 PM | #16 | |
Member#: 97460
NWIC
01-30-2014, 06:43 PM | #17 | |
Member#: 63767
NWIC
Cool.
Please follow-up with this thread once it is back on the rack. I am interested to see what is found. Quote:
01-30-2014, 02:53 PM | #18 |
Member#: 181783
International
Vehicle:MB S55 AMG Sleeper Renntech Equiped |
I had an alignment from Russ years ago. All my tire sets have even tire wear.
01-30-2014, 07:03 PM | #19 |
Member#: 182577
NWIC
Vehicle:2013 sti ISM |
I get my car aligned 2-3 times a year. Usually every other oil change. Firestone does life time alignments for $179, you can take your car in every day if you want. Just a thought.
03-11-2015, 04:27 PM | #20 |
Member#: 377557
NWIC
Vehicle:2014 SJ XT Premium Crystal Black Silica |
Any updates to this? What was the issue?
03-11-2015, 05:39 PM | #21 |
Member#: 97135
NWIC
03-11-2015, 08:37 PM | #22 |
Member#: 331773
Vehicle:2012 WRX Premium DGM |
I had the same issue with mine! Tires were toast after 10K miles and rotated at 4K! The camber wear in the front is just insane. Guess we have to get re-alignments every oil change.
03-12-2015, 10:44 AM | #23 | ||
Member#: 377557
NWIC
I wanted to find out details since the OP stated this... Quote:
03-12-2015, 10:58 AM | #24 |
Member#: 97135
NWIC
Just saying what that post states - still looks like toe out of spec. Even small degrees on our cars can cause aggressive tire wear.
