05-25-2015, 10:20 PM | #18851 | |
Member#: 410716
Vehicle:2016 WRX CBS |
What types of modifications are we talking about haha? And that looks great by the way
05-25-2015, 11:33 PM | #18852 |
Member#: 249696
South East
Vehicle:2010 Outback Sport Black |
You need to cut the ends off since they are too long. I also drilled more holes in it to secure it with more bolts. Some heating/twisting/turning of the lip may be needed to properly sit flush.
05-26-2015, 03:21 AM | #18853 | |
Member#: 21542
BAIC
Vehicle:2011 Impreza 2.5i Dark Gray Metallic |
^what he said... I cut both ends about 1.5" & used heat gun to bend it a bit to fit narrow body. It isn't as hard as it sounds... I was nervous at first but it was easier than I thought. Just be patient & take your time doing it. |
05-26-2015, 11:38 PM | #18854 |
Member#: 262503
Vehicle:2008 Impreza 2.5i |
05-30-2015, 09:54 AM | #18855 |
Member#: 416465
NESIC
Vehicle:2009 Impreza 12 WRX |
Very clean. The only thing that I don't get is what is the logo you replaced with the original Subaru logo on the grill? I see a lot of people have it but I have no idea what it is.
05-30-2015, 10:46 AM | #18856 | |
Member#: 236305
Vehicle:2009 2.5i 4dr 5spd Newport Blue Pearl |
https://www.google.com/search?q=impr...w=1280&bih=587 |
05-30-2015, 12:13 PM | #18857 | ||
Member#: 236305
Was on wifi too, with 50mbps down and 6mbps up connection. |
05-30-2015, 02:00 PM | #18858 | |
Member#: 416465
NESIC
So basically it just stands for Impreza. |
05-30-2015, 02:27 PM | #18859 |
Member#: 236305
05-30-2015, 10:40 PM | #18860 |
Member#: 330830
Vehicle:2010 Impreza2.5i 5dr Obsidian Black Pearl |
05-31-2015, 09:52 AM | #18861 |
Member#: 416465
NESIC
05-31-2015, 11:20 AM | #18862 |
Member#: 229726
Vehicle:'09 2.Slow OBP |
Found an abandoned Psych Ward and decided to explore a bit...
05-31-2015, 11:39 AM | #18863 |
Member#: 410716
08 2.5i
Anybody on here ever use eibach springs, a local guy has a set for sale... Also i know that they are kind of cheap as far a coilovers go but anybody use the tein street basis coils before? Im thinking i would be better off with rce blacks, anybody selling a set of those!
Edit: i found a set of lightly used h&r street performance coilovers local... Anybody running these? Anybody know if i drop the rear an inch will i have neg camber? You guys who are on swift or any lowering springs will i be ruining my rear tires if i drop the car an inch? Last edited by Infinite0180; 05-31-2015 at 03:02 PM. |
06-01-2015, 03:50 PM | #18864 | |
Member#: 393555
Vehicle:2010 2.5i DGM |
06-01-2015, 04:09 PM | #18865 |
Member#: 410716
The h&r street performance coils im thinking about can have a minimum drop of about 1 inch... Obviously they go lower but i want to stay as high up as possible, especially for winter and the buffalo roads. Do you ever have a full car, im talking like 4 grown men (including yourself, because i dont count the middle a backseat haha) in your car? Im worried that i will be rubbing on the rears if i do and i often help my friends with rides... Im thinking that the stiffness of the coils could potentially stop that from happening but im nervous... What do you think? Im running 17x8, +53, with 225/45 tires... |
06-01-2015, 04:11 PM | #18866 |
Member#: 410716
Also have an sti 19mm rear sway bar
06-01-2015, 04:19 PM | #18867 |
Member#: 146287
BAIC
Vehicle:2011 Impreza WRX 5D Satin White Pearl |
I technically have Eibach springs...
If I were going for springs, I would want the RCEs. I had Swift springs, they weren't great. I had the softer sport version and they were too soft. Camber wear isn't as damaging as toe wear. A lot of people mistake toe wear for camber wear. Get the car aligned for zero toe and your tires will be fine. |
06-01-2015, 04:22 PM | #18868 | |
Member#: 410716
Those are konis with a ground control kit right? If i had the money i think that would be a sweet set up! And ya im definitely going to align it after i do it, i just dropped $500 on tires soo i would prefer them to last haha |
06-01-2015, 04:29 PM | #18869 |
Member#: 146287
BAIC
Koni and Ground Control. The nice part was that I didn't have to do it all at once. I was driving on the Konis long before I got the GC kit.
06-01-2015, 04:39 PM | #18870 | |
Member#: 410716
I know konis are probably the way to go i just dont think im comfortable installing them my self and i dont want to pay anybody i want to work on it with a buddy of mine and do it myself. Plus i can get a solid deal on these coils, they were well maintained and have only like 15k - 20k on them. So i think i might pull the trigger on them and if its too low ill try another route. |
06-01-2015, 05:11 PM | #18871 |
Member#: 146287
BAIC
The Konis were pretty easy to install.
06-01-2015, 05:30 PM | #18872 | |
Member#: 330830
08 2.5i
Had 3 friends in the car back when I was on lowering springs and 17x9s. Let's just say the lettering on the rear tires was gone within 30 mins of driving. Coilovers on the other hand are not really affected by more weight in the car, unless you have a super soft spring rate for some reason. For consideration: This rubbed And this doesn't Last edited by IllwaukeeNA2.5; 06-01-2015 at 05:52 PM. |
06-01-2015, 05:37 PM | #18873 |
Member#: 146287
BAIC
Never rubbed my 17x9 255. People in the car will scrape the speed bumps though.
06-01-2015, 05:38 PM | #18874 |
Member#: 374919
NESIC
Vehicle:2010 impreza silver |
Any one on here use Prosport gauges
06-01-2015, 05:59 PM | #18875 |
Member#: 410716
Im assuming your on coilovers now right? Which set up did you go with? |
08 2.5i and 08 Sti Suspension | WRXbrother | Brakes, Steering & Suspension | 10 | 08-22-2017 12:30 AM |
Will an 08 WRX intake fit an 08 2.5i? | Racing101 | Normally Aspirated Powertrain | 26 | 01-19-2012 11:57 AM |
08 STI Wing on 08 2.5i impreza | juny102004 | Interior & Exterior Modification | 13 | 01-18-2012 09:46 AM |
Will 08+ WRX gauges swap into 08+ 2.5i? | Simeon Priest | Interior & Exterior Modification | 10 | 03-26-2010 02:17 PM |
08 2.5i mod question | deunique1 | Impreza Forum | 1 | 10-03-2007 02:35 PM |
