01-07-2014, 12:50 AM | #1 |
Member#: 260153
Vehicle:2005 Baja Turbo 5-Speed |
Control arm compatibility
Was under the Baja yesterday and noticed the front control arm bushings could use replacing and the arms themselves have some surface rust.
Was wondering about swapping them with aluminum control arms from an STI (just wasn't sure of fitment). Any help is appreciated
01-07-2014, 01:41 PM | #2 |
Member#: 260153
Looks like it would take a lot of customization, so I will probably just replace all the LCA bushings with Whiteline or AVO and call it a day.
01-07-2014, 02:07 PM | #3 |
Member#: 229922
Vehicle:2005 F-Inductd BAJA rumble black |
I replaced the bushings with OEM ones and they are expensive, like 120 a set.
01-07-2014, 10:39 PM | #4 | |
Member#: 260153
The OEM ones I found are really cheap http://www.fredbeansparts.com/subaru...-bushings.html |
01-08-2014, 02:24 PM | #5 |
Member#: 229922
I know i got jipped because they were purchased at my local dealer
01-15-2014, 01:09 PM | #6 |
Member#: 322076
Vehicle:2006 WRX WRB |
Here are a couple of photos of JDM aluminum Legacy BE/BH front control arms I bought last May via eBay, had them powdercoated, then installed with Whiteline bushings.
01-15-2014, 07:53 PM | #7 |
Member#: 74489
Vehicle:'04 FXT/‘05 Baja T '71-FF1/14 WRX |
GC aluminum control arms fit directly. That's what I have on my Baja.
01-15-2014, 09:10 PM | #8 | |
Member#: 260153
example http://www.avoturboworld.com/images/...ca/lca_011.jpg |
01-15-2014, 10:37 PM | #9 |
Member#: 14555
Vehicle:1995 Impreza L Baja |
Really?
On my 05 turbo they are horizontal just like the GC, GD imprezas EDIT: Just so you know I am not completely crazy, I just went out in the freezing cold and took some pics. Rear bushing, driver's side front Last edited by Hawk296; 01-15-2014 at 10:59 PM. |
01-15-2014, 10:42 PM | #10 |
Member#: 14555
The one you posted looks like a 2004 and up Legacy control arm (BL,BP). That's a generation newer than the Baja. Bajas are off of the previous BE,BH chassis.
01-16-2014, 07:00 PM | #11 |
Member#: 74489
^ Correct. Like I already posted, the alum. CA's on my Baja came from a GC Imprezza. One way I was able to confirm was that they share the same part numbers for the CA's. The GC arms also fit the SF Foresters (pre -02my).
01-31-2014, 08:09 AM | #12 | |
Member#: 10188
Vehicle:2007 Forester XT |
OP- I have a set of GC STI aluminum control arms ready to go for $250 |
