04-17-2007, 03:47 AM | #1 |
Member#: 114101
SCIC
Vehicle:93 Impreza L Swap |
help me pass smog!
Ok so I bought an 02 wrx with an ej207 longblock swap and I need to smog it. I'm going to be putting back the stock airbox, uppipe, turboback, intercooler, turbo, injectors, etc. so it will look completely stock. My main concern is the ecu. I plan on using a stock 02 usdm wrx ecu and clear the tgv codes with my tactrix cable and then getting smogged, completely legit. Does this sound like it'll work?
04-17-2007, 02:27 PM | #2 |
Member#: 114101
SCIC
bump for an answer.
04-17-2007, 04:06 PM | #3 |
Member#: 64485
SCIC
Vehicle:2004 GGA |
sounds like a plan...would it work???? i dont see why not
04-17-2007, 09:39 PM | #4 |
Member#: 81058
Vehicle:05 impreza wrx sti white/gold |
to pass the smog, all you need is stock turbo and stock intake and stock exhaust.
04-17-2007, 09:41 PM | #5 |
Member#: 114101
SCIC
so if I go in with a jdm ecu, it won't matter?
04-18-2007, 12:23 AM | #6 |
Member#: 142785
SCIC
Vehicle:2006 Ford Fusion Charcoal Beige |
There are certain contacts that could smog it for about $200-$250... Would save you the hassle of swapping everything over.
04-18-2007, 12:32 AM | #7 |
Member#: 103674
SCIC
Vehicle:97 gf8 white |
jdm ecu will not work b/c there is no evap system in japan so it will show as not ready when connected to the computer...but it sounds like it will work as long as u can keep the tgv codes from coming up...
04-18-2007, 01:28 AM | #8 |
Member#: 77908
SCIC
Vehicle:2020 911 S/ 2017 M3 RIP 11, 09, 06, 03 STI's |
I reset my ECU and took my car in for a smog and the computer freaked out. The shop dude said to go drive 30miles and come back. I did that and then the smog computer worked fine.
I realize this isnt the same deal. But I would think that with the codes not showing up at all, would cause the smog computer to freak out too. I dunno though. Best of luck to you man! |
04-18-2007, 01:36 AM | #9 |
Member#: 114101
SCIC
I'd rather swap everything out than pay an additional $200-250.
So I guess I HAVE to use the usdm ecu then, right? But I don't think it'll be safe to run the stock settings, so I'll need a tune too? so djennison... you're saying if I clear the codes, that'll mess up their smog computer? |
04-18-2007, 02:05 AM | #10 | |
Member#: 84912
SCIC
Vehicle:2003 2.5L bugeye now with 6 spd 20g! |
they also noticed the mods and this was a citacion smog. as long as your smog stuff is in place, like cats, intake being legal and stock exhaust you should be ok. Car needs to idle properly hold rpms as well. stock boost controller is important as well. Your jdm ecu is going to mess you up though, it might or not might read. best of luck though. |
04-18-2007, 02:09 AM | #11 |
Member#: 114101
SCIC
Ok so the REAL question is:
Jdm ecu? or Usdm ecu w/ cleared tgv codes? |
04-18-2007, 05:58 AM | #12 |
Member#: 84516
SCIC
Vehicle:'12 Tony Kart EVRR '99 E36 M3 Estoril Blue |
JDM ECU= HELL NO
USDM w/ cleared codes= more than likely |
06-11-2007, 04:57 PM | #13 |
Member#: 114101
SCIC
Just wanted everyone to know that I passed with everything stock except the longblock and tgv deletes. I used enginuity to get rid of the dtcs and it worked like a charm.
06-11-2007, 05:10 PM | #14 |
Member#: 64485
SCIC
Vehicle:2004 GGA |
cool. enjoy!
kthnksbubye |
06-11-2007, 10:33 PM | #15 |
Member#: 88676
BAIC
Whats your reason for getting smogged? Did you get a notice from DMV to be smog tested?
06-11-2007, 11:14 PM | #16 |
Member#: 114101
SCIC
no, transfer of title. I just bought the car w/ an ej207 already in it.
Help me pass CA smog | revcor632 | Service & Maintenance | 9 | 01-16-2009 03:30 PM |
Help me pass CA smog | revcor632 | Normally Aspirated Powertrain | 2 | 01-13-2009 11:50 PM |
Out to sea, help me pass the boredem... | WRX_scott | Mid Atlantic Impreza Club -- MAIC | 5 | 08-21-2006 09:29 AM |
help me pass emissions!! | wowthatisrandom | UTEC | 15 | 03-15-2006 06:01 PM |
need help to pass smog | qax | Southern California Impreza Club Forum -- SCIC | 58 | 10-11-2005 08:48 PM |
