12-07-2005, 10:45 AM | #1 |
Member#: 102416
Vehicle:1995 Legacy L red |
lowered Legacy w/ Wrx wheels fitment issues?
Hello,
I noticed there are very knowledgeable people on this forum when it comes to subarus and I need some help. I currently have 215/35/18's on my 95 Legacy L lowered by 1.5" using B&G springs and KYB GR2 struts. I need to get wheels for winter so I am thinking about getting stock 02 WRX wheels with 205/55/16 tires. Will I get perch/tire interference with my KYB struts and the 205/55/16 tires? I would like to know if anyone has tried this combination and knows if it works.
12-07-2005, 10:51 AM | #2 |
Member#: 55541
Vehicle:05 325ciC 98 Legacy Wagon |
I would find it hard to believe that if you're going from a 215 to a 205 you'll have any rubbing issues. Not to mention the wheel width on the stock wrx wheels is probably at least a half-inch narrower.
12-07-2005, 10:55 AM | #3 |
Member#: 12588
SCIC
Vehicle:Four Count 'em GF5,BDA,BD5, BP5 |
No issues whatsoever. That would probably be my choice too.
12-07-2005, 10:59 AM | #4 |
Member#: 102416
When I use a tire and wheel offset calculator, it says tht with the WRX wheels, the diameter of the wheels will be 1" bigger and the inside of the tire will be 5mm closer to the strut.
The calculations also show that the wheels will not rub against the fenders, but just by visually inspecting the clearance now with my 215/35/18 tires and the kyb strut perch, it looks like it will be a very very close fit. It would suck to buy the wheels and then they don't fit |
12-07-2005, 11:44 AM | #5 |
Member#: 5039
South East
Vehicle:2007 Outback XT Grey 5-speed (sold) |
If the 16" WRX wheels wont work, no 16" will. They are THE ideal offset for our cars and identical to the Legacy GT wheels in size and offset.
ss |
12-07-2005, 12:09 PM | #6 |
Member#: 102416
The 16" WRX wheels with 205/55/16s will fit on my Legacy with stock struts.
I have read this in many forums. However, I remember when I changed the stock struts to KYB GR2's, the KYB seemed a bit shorter. This is why I am wondering if the WRX wheels will fit and the inside of the tire will not rub on the strut perch... If someone can confirm that the stock and KYB GR2s legacy struts are identical then I will have no problem. |
12-07-2005, 12:56 PM | #7 |
Member#: 12029
I have 225/40R18 on +48 7.5" wheels on my wife's '97 GT. It's not lowered, but I've never had any clearance problems, even with a full load of passengers.
--Dan Mach V FastWRX.com |
12-07-2005, 01:25 PM | #8 | |
Member#: 73684
NWIC
Vehicle:2012 4Runner |
12-07-2005, 01:30 PM | #9 |
Member#: 16874
NWIC
Vehicle:2008 2008 Audi RS 4 2014 Audi S Q5 |
At this very moment my car is riding on KYB GR2s with WL control springs and the stock GT wheels w/ 205/55/16 Blizzak Revos. NO PROBLEMS.
End of story. Jared |
12-07-2005, 01:47 PM | #10 | |
Member#: 5039
South East
As an extreme, Steve is running 225/40-18 Kumho 712s(taller and wider) on 18x7 +55mm wheels on his wagon: http://forums.nasioc.com/forums/show...highlight=spec The problem with Steves setup for comparison is that hes running a quasi-oem strut and not a KYB. You may be right in that the rear perches are closer on the KYBs, I have about 1/4" of strut/tire clearence in the rear now and these tires are beat. There's little doubt in my mind that if I tried to put on Steve's wheels/tires that I would be rubbing on the rear strut spring perches. I still think you would have enough room for the 205/55-16s on 16x6.5" +55mm rims though. ss |
12-07-2005, 04:24 PM | #11 | |
Member#: 102416
How many inches is your car lowered? Last edited by Trin_Starr; 12-07-2005 at 04:53 PM. |
12-07-2005, 04:31 PM | #12 | |
Member#: 102416
I think you are right - it should work! Last edited by Trin_Starr; 12-07-2005 at 04:52 PM. |
12-07-2005, 06:06 PM | #13 | |
Member#: 16874
NWIC
Jared |
12-07-2005, 06:13 PM | #14 | |
Member#: 5039
South East
ss |
KW coilover owners w/stock wheel fitment issues? | JDM Junkyard | Brakes, Steering & Suspension | 12 | 04-25-2010 02:55 PM |
Bilstein Pss9 & Wider wheel fitment issue | SuBart | Brakes, Steering & Suspension | 2 | 06-19-2009 02:24 PM |
2.2l n/a with wrx manifold? fitment issue... | legacydreamz | Normally Aspirated with bolt-on Forced Induction Powertrain | 6 | 04-13-2009 12:15 AM |
2004 STI wheel fitment issues on my GF | MeanEditor | Tire & Wheel | 5 | 06-06-2008 03:50 AM |
Legacy tire & wheel fitment | kingpumba1 | Newbies & FAQs | 3 | 11-19-2003 02:22 PM |
