03-15-2007, 03:53 PM | #26 |
Member#: 143391
Vehicle:2007 WRX TR R.I.P Paul! :( |
03-15-2007, 03:54 PM | #27 |
Member#: 143391
Repost. Sorry
Later Last edited by Badmunky; 03-15-2007 at 04:13 PM. |
03-27-2007, 09:49 PM | #28 |
Member#: 138676
TXIC
Vehicle:13 STI Limited White |
great stuff, love reading FAQs
03-27-2007, 11:48 PM | #29 |
Member#: 116987
RMIC
Vehicle:02 WRX White |
Sticky This Mofo!!
03-28-2007, 03:33 AM | #30 |
Top Scoob 021
Member#: 115406
NWIC
Vehicle:On to the next... |
^Umm, have you seen this.... http://forums.nasioc.com/forums/showthread.php?t=533787 ....I'm guessing, no.
05-12-2007, 08:01 PM | #31 |
Member#: 118150
SCIC
Vehicle:04 Wagon XPT HTA68 Silver |
Great stuff Unabomber!!
This was very informative and the only place I could find the Stock rim weight (w/out the rubber) after like 20 minutes of Google'ing in everything keyword I could think of for stock WRX parts. Thanks +1 |
11-01-2007, 09:41 AM | #32 |
Member#: 121633
Vehicle:2003 WRX Sonic Yellow |
What are the wheel sizes and lug patterns for the 08 WRX and STI?
12-09-2007, 01:05 AM | #33 |
Member#: 133405
Vehicle:2002 WRX Matte Black |
ok so with all these numbers and offsets....can i put 05 sti stockers on an 02??
please pm me thanks |
12-09-2007, 01:12 AM | #34 |
Member#: 86356
Vehicle:2018 Aprilia Tuono v4 1100 |
Nope. 05+ STI wheels are the wrong bolt pattern, and won't fit.
12-09-2007, 01:13 AM | #35 |
Member#: 140244
Vehicle:2002 bugeye still rippin' hard |
^no. 05+Sti has 5x114.3 bolt pattern.
If you want bbs wheels you need to look for 04 sti since it has 5x100 bolt pattern just as wrx's... |
12-09-2007, 07:58 AM | #36 |
Member#: 133405
I was hoping you guys would say yes, cause i was gonna get them for 400$. oh well thx for the help
03-15-2008, 01:13 PM | #37 |
Member#: 76967
Vehicle:2006 WRX Limited Sedan SGM |
are you saying that subaru was wrong to use the +55 offset tires on the 2006-2007 stock wrx wheels when you said 7.0" wide should equal +50 to +53 offsets? and actually i just noticed it would be wrong for the two types of STi wheels as well.
04-23-2008, 10:26 PM | #38 |
Member#: 158313
Vehicle:2003 WRX PSM |
I just weighed some '04 STI BBS's. I started a thread in the wheels and tires section, but the jist of it was that they weighed 15.7 pounds each. Has anyone else weighed their rims?
05-01-2008, 10:34 PM | #39 |
Member#: 178967
you said if the offset was within 2 in it would be fine well if it is 3 what will happen such as bad. real noob here go easy on me lol
05-02-2008, 02:09 AM | #40 |
Member#: 86356
Can you type that again in english? Are you saying you think an offset within 2 inches of stock is fine? Because that's not even a little bit right.
05-02-2008, 10:14 AM | #41 |
Member#: 89165
Vehicle:Poop Stuck Survivor -=C=- & subari87 FOREVER! |
Data for Unabomber's Wheel FAQ:
2008 WRX Wheel - Mine weighs ~23.2 lbs with the tire pressure monitor sensor and weights on the wheel. The particular wheel I weighed did not have a ton of weights on it. My conclusion is the result from taking Bridgestone's stated weight of a new tire, as found here: http://www.bridgestonetire.com/tires...roduct_ID=1089 and subtracting it from the total weight of the wheel/tire/TPMS assembly as I found here: Just trying to help. Not 100% accurate wheel-only weight, but it is close. Better than ???, I suppose. |
05-02-2008, 10:25 AM | #42 |
Member#: 89165
Whenever you deviate outside the recommended offset range, you are going to increase the stress placed upon the hub and wheel bearing. Increased stress will lead to decreased longevity (life) of the part.
05-02-2008, 01:36 PM | #43 |
Member#: 169223
Update:
Stock 08 STI wheels = ~28 lb Stock 08 STI BBS Wheels = ~21 lb |
05-02-2008, 05:54 PM | #44 |
Member#: 48199
Vehicle:06 WRX WRB |
I wish there was a simple way to explain how 18" wheels can be lighter then 17" wheels if you are keeping the overall stock circumference due to tire weight. I dont think a lot of people understand this...
Good sticky regardless though...Reported to mods... |
05-02-2008, 07:06 PM | #45 |
Member#: 178967
well the thread sai If your wheel width and offset is within this chart or close (+/- 2mm), your wheels have the proper offset and 8in wide in the chart said 43 - i think 45. well i got 18 x 8 with a 40 mm off set
05-02-2008, 10:50 PM | #46 |
Member#: 170790
BAIC
Vehicle:2006 wrx cobb stg. 2 cgm |
Well done!
06-09-2008, 11:13 PM | #47 |
Member#: 151079
Vehicle:2005 2.5RS RBP too many friction losses |
Hey, here's a fix for the how-to-install-the-wheels broken link:
http://www.tirerack.com/tires/tirete....jsp?techid=39 |
06-10-2008, 12:13 AM | #48 |
Member#: 55715
PRSIC
Vehicle:1956 |
good job
06-14-2008, 10:59 PM | #49 | |
Member#: 176748
NESIC
Vehicle:2008 WRX hatch black |
07-01-2008, 02:28 PM | #50 |
Member#: 94615
Vehicle:2017 VW GTI S1+ 2006 STi 341WHP/356TQ |
you say the correct offset for 8.0" width wheel is +43 to +47, yet the OEM '06 STI BBS wheel is 17 x 8 with a +53mm offset??
Gauge FAQ: Read if you are thinking of buying some! | Unabomber | Electrical & Lighting | 208 | 12-31-2021 01:22 PM |
Uppipe FAQ: Read if you are thinking of buying one! | Unabomber | Newbies & FAQs | 396 | 07-09-2020 02:25 AM |
Pulley FAQ: Read if you are thinking of buying one! | Unabomber | Newbies & FAQs | 120 | 01-29-2020 09:15 AM |
Downpipe FAQ: Read if you are thinking of buying one! | Unabomber | Newbies & FAQs | 338 | 10-25-2019 12:04 AM |
