09-11-2006, 09:40 AM | #1 |
Member#: 56133
Vehicle:2004 Euro spec Sti Black - Rotated gt3037s |
Can't change VVT map's angle
Hi guys,
I can't change the angle of the 3D VVT map. Is this normal ? (I have the 2.50r12 software) Thanks
09-11-2006, 08:21 PM | #2 |
Member#: 56468
Vehicle:04 Improved STI Dirty White |
You need to have that map unlocked. Much care should be taken when changing that map especially at low RPM. Contact Phil if you wish to make changes in that map.
09-12-2006, 12:13 AM | #3 |
Member#: 56133
I think it is unlocked because i can make changes on the VVT map.
09-12-2006, 04:34 PM | #4 |
Member#: 56468
Maybe it's a software glitch. I'm able to rotate it in 2.14v11--wish it helped me tune it ;-)
09-13-2006, 11:30 AM | #5 |
Member#: 27108
Vehicle:2004 STi 2004 A4 |
I am unable to rotate PWM 9 or 11 in version 2.17r6... picking "View" and "Angle" from the menu does nothing. Other maps, like the base fuel and timing maps, rotate without a problem.
The Hydra software not exactly the best. Many common features (e.g. multiply, add, copy/paste) are just not there. |
09-13-2006, 07:42 PM | #6 |
Member#: 54918
Vehicle:673 WHP Element Tuning Pro Comp Engine |
The Hydra software is the best ever! You guys just don't know what to do with it
Seriously I have used them all and by far the most practical and functional software available. Simple pull down menus that are in a logical order. Just enough graphical interface but not too much. It's suprisingly similar to Motec. Don't get me wrong improvements can and will be made over time. |
09-13-2006, 11:30 PM | #7 | |
Member#: 27108
09-13-2006, 11:58 PM | #8 | |
Member#: 56133
Any solution for us ? |
09-13-2006, 11:58 PM | #9 |
Member#: 56468
09-14-2006, 10:59 AM | #10 |
Member#: 54918
Anything is possible if the customers are willing to pay more. I’m really hard on Hydra EMS to maintain the price point we are currently at. Also you must keep in mind that companies have to decide where to spend their development resources. For Hydra EMS it’s not a priority to add some of these items you seek but instead to develop new plug and play drive by wire applications, CAN interfacing software, USB conversions, fully closed loop AVCS, VVTI, and MIVAC software. What other stand-alone have those features in a plug in application? None of them do.
This is where the resources are going so you understand that development continues just not always on the things that offer a little convenience to the end user. For many of you there wouldn’t even have be a stand-alone EMS to offer suggestions for. For the record going to the Hydra EMS forums and offering up suggestions helps the most as it’s put in front of the engineer’s eyes. They don’t visit Nasioc and unfortunately I don’t really have time to visit those forums either. I had customers get what they wanted where I had little success. Thanks, Phil http://www.elementtuning.com |
Similar Threads | ||||
BC Racing Coilovers changed the axle angle a lot in the rear is this normal? | spoolinsti05 | Brakes, Steering & Suspension | 10 | 06-04-2008 05:13 PM |
Changing seat-back angle. | Subahaulic | Interior & Exterior Modification | 4 | 02-07-2004 01:00 PM |
I can't change my oil | 03WRX83 | Service & Maintenance | 9 | 07-07-2003 03:07 PM |
I have a problem (@ 4am)...can't change pads | Hyper | Brakes, Steering & Suspension | 8 | 06-10-2003 09:41 PM |
Can't change tranny oil anymore??? | dada21 | Normally Aspirated Powertrain | 28 | 05-19-2001 12:58 AM |
