02-14-2001, 10:32 PM | #1 |
Member#: 438
W. Canada
Vehicle:2004 STi White on Gold |
Turbo's & Cruise Control==>Compatible?
IIRC, most of the existing aftermarket turbo systems out there that are using intercoolers have to remove the cruise control. Is this correct?
I drive many thousands of kilometers/miles a year and to lose my cruise would completely suck!!! Any of you turbo owners care to comment on what modifications (if any) you had to make to your cruise control in order to make this work? Or did you simply live with the inconvienence? Your input appreciated. |
02-14-2001, 10:46 PM | #2 |
Worst Mod Ever
Moderator Member#: 369
SWIC
Vehicle:19 CTS-V, 18 XC90 17 GTI |
You just have to relocate it. You need to move it more because of where the turbo mounts, rather than the IC. Here is a pic of where I put mine.
<IMG SRC="http://www.azscooby.com/images/Rim00023.jpg" border=0> It is the green/black thing above the air filter (for those who might not know what they are looking for.) Hope this helps, Aaron http://www.azscooby.com |
02-14-2001, 11:58 PM | #3 |
Member#: 524
Vehicle:04 STi White |
Oh, you might want to put on stronger throttle return springs...
My Turbo wa on the highway when a car passed me and pulled back in. Bingo the car accelerates as the air drag decreases ALOT (hmm 4X4 ride hight and areodynaics of a barn). Well this causes the turbo to spool. The turo is spolling faster than the cruise can let off on the throttle. So here I am accelerating hard at 85MPH running 15psi and the boost is holding the TB open, as the cruise is resisting the throttle return spring enough. |
02-15-2001, 12:01 AM | #4 |
over boosted again
Moderator Member#: 1458
RMIC
Vehicle:2017 WRX Limited 15 Forester XT, 21 Ascent |
Here is my relocated Cruise Control near the ABS - Instructions are posted off the mymods section of my website www.ImprezaRS.com. No problems so far.
<IMG SRC="http://www.imprezars.com/images/step160dcp00365.jpg" border=0> Larry [edit] typed a / after the www in the URL instead of period for the picutre [This message has been edited by ImprezaRS dot com (edited February 15, 2001).] |
02-15-2001, 01:25 AM | #5 |
Member#: 610
VIC
Vehicle:2003 Lexus IS300 Graphite Gray Pearl |
Yup, cruise control isn't a problem Markus.
Had I kept my turbo I would've mounted it back somewhere else too...I can't live without my ABS! Fwiw, I think not having the cruise control was what was setting off my AT oil temp light back then. |
02-15-2001, 05:37 PM | #6 |
Member#: 438
W. Canada
Thanks for your input guys. Looks like its a no-brainer modification.
Similar Threads | ||||
Fog light & cruise control switch | smokeone954 | Private 'Wanted' Classifieds | 2 | 04-15-2010 02:18 AM |
06 STI Differential & Cruise control prob from LED tail light bulbs | REDDOG | Drivetrain | 0 | 05-02-2008 06:20 PM |
Aftermarket Steering wheel & Cruise Control? | WAYGONE1 | Motorsports | 5 | 06-04-2007 05:20 PM |
HELP! Check Engine light on & Cruise Control Light Blinking | STiURBO | Southern California Impreza Club Forum -- SCIC | 21 | 03-15-2007 01:54 AM |
Steering wheel & Cruise control | Skeandhu | Interior & Exterior Modification | 6 | 01-23-2001 08:08 AM |
