10-22-2002, 11:01 AM | #1 |
Member#: 18466
Vehicle:2003 GT35r Evo VIII 10.402@138 |
Stromung install question
Hey guys just had a quick question about intalling a stromung midpipe and axle back system. The midpipe comes with a gasket. Do i use this gasket on the stock manifold and midpipe connection cuz there is that black donut thing in the manifold. My car seams to sound funny at idle now like bop, bop, bop like i have a exhaust leak maybe. I didnt put the gasket in. should I. i dont think it fits though. Anyone know the answer?
Erik
10-22-2002, 11:09 AM | #2 |
Member#: 10607
RMIC
Vehicle:'17 JKU Rubicon |
you have an RS?
IIRC, the front connection is a spring-loaded type that i don't think has a removeable gasket. i believe that "black donut" thing is the only seal. the gasket i beileve is used btw the midpipe and the axle-back where there should be an old gasket when you remove the stock exhaust. just make sure that if there was a gasket there when you took it off, there is a gasket there when you put it back on. easy. |
10-22-2002, 12:08 PM | #3 |
Member#: 18466
its a 2000. I did have the springs from the stock setup. do i need to put them on?
Erik |
10-22-2002, 12:29 PM | #4 |
Member#: 17446
Vehicle:1996 Honda Civic ex 2003 Kawasaki ZX-6RR |
didn't i tell you last night all you need to do is get a new donut from subaru and i'll put it on for you? the gaskets are all in the right spot, the extra gasket was to be used if you have an aftermarket header which you do not. so go buy a donut and i'll put it on for you when i'm doing mike's exhaust.
-Sean |
10-22-2002, 12:29 PM | #5 |
Member#: 3362
Vehicle:2001 I've wired a Few cars in my day |
OK on the Strömung you do need to either replace the donut or reuse it. I would recommend replacing it since your car is a 2000 and it probably has a few miles on it, you should also replace the rear paper gasket was well. On the install you will need to reuse everything except for the midpipe and and the muffler. The Strömung will also make a nice rumbling sound once it is installed.
If you have anymore questions feel free to IM me. Z |
10-22-2002, 12:36 PM | #6 |
Member#: 3362
Yeah double post
Z |
10-22-2002, 12:36 PM | #7 |
Member#: 17446
-Sean |
Stromung install question | spriggan | Legacy Forum | 1 | 04-03-2003 08:45 AM |
Stromung Install Help Needed | Joncas | Normally Aspirated Powertrain | 7 | 05-05-2001 12:00 AM |
stromung install problems | remarcable | Normally Aspirated Powertrain | 10 | 04-30-2001 06:34 AM |
Stromung installed | Snowman | Normally Aspirated Powertrain | 7 | 04-08-2001 04:46 AM |
Stromung installation question. | ImprezaRS2000 | General Forum Archive | 10 | 08-02-2000 12:00 AM |
