07-11-2006, 05:13 PM | #1 |
Member#: 106888
New Build HELP?????
I am hoping to do a sti shortblock with a stock wrx head, green turbo, PE 750 injectors and Perrin fuel rail, clutchmaster stage 3 clutch and flywheel all controled by a reflash and then upgrade to an AEM. My question is can a 06 sti block work? I am not sure if the short block is the same as i have seen that alot of people use the short blocks from the older model years 04-05? but i am not sure if it has change and that everything will not line up without conversion?
07-11-2006, 06:39 PM | #2 |
Member#: 1714
RMIC
Vehicle:1999 RS-T COUPE Black |
your heads will bolt up to the 06 block-no problems.
07-12-2006, 12:03 PM | #3 |
Member#: 106888
Come on guys i am sure that more than one person has some facts why it will definitely fit or not i need to purchase this SB soon as i dont want to loose out on it but i just want to make sure that it will fit.
07-12-2006, 02:05 PM | #4 |
Member#: 1714
RMIC
There's really no more info needed-the shortblock & your heads will bolt up just fine.
Bret Subaru Senior Master Tech (20 years experience) |
07-12-2006, 06:44 PM | #5 | |
Member#: 23216
Vehicle:2006 949-457-1234 949-457-1234 |
You might want to take a look at what other people are doing on this board. This hybrid is a very popular combo and we've installed and tuned around 10 of these. As Bret already said, this shortblock will definitely work with your heads. If I could make a few suggestions about your setup, I'd skip the Perrin fuel rails because they're not necessary unless you're pushing really really big power. People will tell you that this will help balance out the lean condition in cylinder #3 but we have never had any problems with this and can push 500+ dynojet WHP on the stock fuel rails. Next, I'd go with something like the Helix 264 cams and valvetrain because the flow of the stock WRX heads will limit the potential of the 2.5L block noticeably. You might find this thread interesting: http://forums.nasioc.com/forums/show...0&postcount=45 Also, PE doesn't make 750 injectors so I'm guessing you meant the Pe 650s or 800s? For the Green, you could go with the 650s but I'd actually recommend the Helix 660s since they're basically identical to the Helixes but they're much cheaper. Finally, remember that you'll be producing massive amounts of torque with this setup and going to a stiffer clutch will transfer a lot more shock to your transmission. This will in turn make it more likely to go out. I would seriously start considering a 6 spd swap or RA gears at the very least. I recommend you keep your stock clutch if you don't plan on upgrading your tranny for the time being. If you have any questions, feel free to contact us. Thanks, Geoff |
07-12-2006, 09:30 PM | #6 | |
Citizen Mick
Member#: 27646
NWIC
Vehicle:2003 Sleeved 2.5 Oil Dry Sump Goodness |
- On a side note I would suggest that you drop the compression using a thicker head gasket. Yes, yes I know many on this forum will say that you increase quench leading to detonation but ask them if they have actually done it. I dropped the compression on my block builds and have seen no ill effects. |
07-13-2006, 12:25 PM | #7 |
Member#: 106888
Thanks, for the information from everyone. i would like however to know Gruppe-S what turbo and injectors that you would recommend for this set up seeing that i want it to be a daily driver. i was thinking of using a FP Green and also do you sell the recommendation for the valve tran and cams if so let me know how much?
1.With the cars that you guys have done what was Engine management used? 2. what are the ball park figures (HP) were the cars done on a conservative setups? |
07-13-2006, 04:34 PM | #8 | |
Member#: 23216
1. Our preferred method of EM is the Cobb AP Protune. It has complete control over every parameter of the ECU and allows multiple map capability. 2. With stock heads and a Green on 91, I'd excpect you to make around 380 CHP. With Helix cams, I'd expect that pacakge to make about 410 CHP. Thanks, Geoff |
07-13-2006, 04:51 PM | #9 | |
Member#: 70353
Vehicle:2004 WRX PSM |
From what I've read on here, some people make it seem like there is a huge difference. |
07-14-2006, 03:17 PM | #10 |
Member#: 23216
I'd say that is a pretty big difference when you consider the $ spent per HP gained ratio. Plus the gains are through a very large portion of the RPM band. Also, remember that these gains will only become more pronouced the more power you make (the more air you move through the motor, which is an air pump, the more gains you will see from cams (or most any mod for that matter)).
-Geoff |
07-18-2006, 08:25 PM | #11 |
Member#: 15380
Vehicle:2002 WRX White |
I have been playing with horsepower for a long time and I have to say this: 30HP for a grand in a car is not that impressive to me (if this is just a peak number). WHat do they do for the overall graph? How does the torque and HP look from idle to rev limit? 30hp for a grand on my Yamaha R1 I would jump on it....but in a car.....not so quickly...unless it did things other than peak numbers. Peak numbers mean nothing to me as a street car....table top torque curve and throttle response....now we are talking.
07-18-2006, 08:32 PM | #12 |
Member#: 106514
30hp from cams is good, but more importantly good cams that fit your application will allow you to hold power out closer to factory redline.. and some cam and cylinder head porting options will allow you to hold power even further.
So I agree with Geoff, it is worth the money alone.. having a broad powerband. (of course with the correct cams for your application) |
07-18-2006, 08:39 PM | #13 |
Member#: 15380
OK...I am at work and typed that quickly so what I am asking is do those cams provide that for the engine then? Newermind the peak number....does it carry numbers out and is the torque curve flatter?
07-18-2006, 09:25 PM | #14 | |
Member#: 25413
Scroll down for sonic rx's numbers. He did the helix cams/valvetrain I believe. If those were stock cams with the SR55 turbo, I'm willing to bet the power dropoff would be horrendous. |
07-18-2006, 09:31 PM | #15 | |
Member#: 15380
Now that is beautiful...thanks for the info....they look like they definately are worth it. Asking so many questions because I am getting ready to replace an engine in my 02 WRX.... |
Hey guys im new here, new sti owner, and new build. | e30 gangsta | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 8 | 06-01-2008 01:42 AM |
Need some computer building help. | Guru Imakuni | Off-Topic | 15 | 05-08-2005 03:40 AM |
Computer Building Help/Insight | D'sScooby | Off-Topic | 27 | 02-12-2005 06:07 PM |
Webpage building help needed. easy Q | scarywoody | Off-Topic | 5 | 09-02-2004 08:24 PM |
junkyard turbo build help... | 9 | Normally Aspirated with bolt-on Forced Induction Powertrain | 8 | 07-24-2003 03:11 PM |
