03-23-2013, 08:48 AM | #1101 |
Member#: 303864
Vehicle:2008 Impreza 2.5i 5d DGM |
I just got a cheap pair of ramps a pepboys, felt safer than jackstands, imho. But gave all the room i needed. Depending on your clearance you may need to jack the car up on them, still not a problem.
Please this is just an option if jackstands work for you and everyone else, thats great, my thought was the wheels where holding the car up and less likely to fall.
03-23-2013, 09:28 AM | #1102 |
Member#: 262188
Vehicle:2009 2.5i DGM |
I've had my header on for about a month now on my 2009 sedan. Love the sound exactly what I wanted. Are any of you with 08+ throwing a cel? I've had mine go on... Anymore info as to how to get around it if possible.
03-23-2013, 10:27 AM | #1103 |
Member#: 271928
Vehicle:2014 WRX Limited Crystal Black Silica |
Delete/permanently turn the code of through an open source tuning program, don't know to much about it my self though
03-23-2013, 11:44 AM | #1104 | |
Member#: 304055
Vehicle:2008 2.5i Rallisport UEL Headers Magnaflow CBE |
With warmer weather I don't get them as much. I plan on re-coating the headers this summer and warping the cat with header wrap so it won't blow codes next winter. |
03-23-2013, 12:21 PM | #1105 | |
Member#: 262188
03-23-2013, 01:24 PM | #1106 | |
Member#: 304055
03-23-2013, 02:01 PM | #1107 |
Member#: 347149
NESIC
Vehicle:2007 impreza 2.5 red |
loudness of the headers
hey everyone!!
I really want to get a set of the headers for my 07! i live in MA though and the cops are pretty strict about loud exhausts ( my car is red so that def draws more attention to it too haha) I have a SPT catback on my car and it is already kinda loud. I was wondering if anyone has an SPT or a similar 3" exhaust? i am curious if the headers made your exhaust louder decible wise?? i know the UEL rumble is def lower pitch and deeper than the EL but does the headers make your car noticeably louder compared to the EL's with an aftermarket exhaust?? Thanks for your help!!! |
03-23-2013, 02:24 PM | #1108 |
Member#: 217257
Vehicle:2008 2.5i hatch Satin White Wrap |
I had just a catback before upgrading to this header. It indeed got louder with the header+catback. A lot of this is the less restrictive, better flowing, high flow cat in the new header.
03-23-2013, 02:35 PM | #1109 |
Member#: 271928
I noticed mine get slightly more quiet if anything
03-23-2013, 03:18 PM | #1110 |
Member#: 347149
NESIC
what kind of exhaust do you have? obx? your username looks familiar i thin ive talked to you before. what size piping is you catback?
03-23-2013, 03:20 PM | #1111 |
Member#: 347149
NESIC
03-23-2013, 03:42 PM | #1112 |
Member#: 271928
I just have a magnaflow 2.5' straight through muffler, almost identical to the spt in terms of decibels
03-23-2013, 04:58 PM | #1113 | |
Member#: 347149
NESIC
my old exhaust was an invidia n1 race so i cant imagine the headers with the spt would be louder than that lol |
03-24-2013, 11:54 AM | #1114 |
Member#: 285405
Vehicle:2013 WRX Hatch WRB |
This concerns me. Is there anyway to prevent this? I live in an area that is heavily salted at the first hint of snow. I hate to have spent hundreds of extra dollars only for the coating to wear off after a while.
03-24-2013, 12:35 PM | #1115 |
Member#: 217257
If the coating is properly applied then it wont just flake/corrode off. as it should a seamless coating with no way for salt/water to get under it. It would normally take an impact to chip the coating which could then lead to salt/water intrusion under the coating.
My header is Cerma Krome coated, and has been running without any CEl's or sign of wear since installation in after xmas. The coating is every bit as shinny and intact as the day I opened the box. And as for the coating working? I would be inclined to say yes as all of february was between -20 to -40 degrees Celsius. |
03-24-2013, 05:11 PM | #1116 | |
Member#: 271928
03-24-2013, 06:05 PM | #1117 | ||
Member#: 304055
I'm not sure if it was heat based or salt that caused the corrosion. Here's a pic from the top of the engine bay, only looking at the top of the cat. And for reference here's how it looked day one. :::::::: not trying to trash on anyone's workmanship. I always thought it might have been due to salt in Canada or my car being rust proofed somehow? :::::::::::::::: |
03-24-2013, 06:08 PM | #1118 | |||
Member#: 200057
Vehicle:2018 Impreza 2.0i 5d RalliSport Blue |
03-24-2013, 06:13 PM | #1119 | |
Member#: 200057
Thank you for the pics, very revealing. Get these back to me as your earliest convenience, and I'll take care of you |
03-24-2013, 07:26 PM | #1120 |
Member#: 309754
Vehicle:2012 Impreza Sport L Ice Silver Metallic |
Maybe the Satin Black is not as Good as CKC?
I am going with the Cerma Krome Coated for my entire system. I get heavily salted as soon as the sign of snow where I live, I travel 50 miles south into NYC and I do not want anything eating up my expensive exhaust.
THIS IS NOT MY HEADER, MINE IS 4 INTO 1. USING IT JUST AS A SAMPLE. |
03-24-2013, 07:34 PM | #1121 |
Member#: 309754
THIS IS MY HEADER. Not coated yet, Cerma Krome Coating is what I want. |
03-25-2013, 01:05 PM | #1122 |
Member#: 347149
NESIC
4-1 headersd
has anyone ordered/ received a 4-1 header? or are they still in the prototype stage? if anyone has some I am curious to hear how you like them!!.... im not a huge car guy but what would be the difference between the 4-2-1 and the 4-1? better flow and probably louder right?
03-25-2013, 06:59 PM | #1123 |
Member#: 285405
I just want to re-iterate how totally awesome it is that you stand behind your work/products so much.
03-25-2013, 07:35 PM | #1124 |
Member#: 293006
SCIC
Vehicle:2015 Subaru WRX WR Blue |
03-25-2013, 08:32 PM | #1125 |
Member#: 200057
OK, so I just had a long talk with the ceramic coater. First off, he has been doing this for 18 years and is the best around. He definitely knows his stuff. He is the only one the local race engine builders trust to coat their headers and other components.
What happened to the cat section on Sellars21's header is definitely not normal and not to what to expect. The black satin ceramic coating can withstand temps three times hotter than these NA engines will ever produce, and is what the guys that run strictly race-only engines use. He showed me a piece he coated for a local foundry with black satin that gets filled with (then used to pour) molten aluminum over and over again. The black satin is also rated to handle the worst salt/liquid-salt spray conditions for 5000 hours. The Cerma Krome is even better yet at fighting the elements! In the future, all headers that are ordered in black satin will have the cat section (and all the way to the cat pipe flange) coated in cerma krome, cured, then recoated in black satin with the rest of the header. This will give the cat a double dose of protection, just to be safe. Anyone looking to have their header ceramic coated to help avoid a cel should be going with cerma krome, as it has better heat retention properties than the black satin. Last edited by blk6s; 03-25-2013 at 08:38 PM. |
RalliSport Racing HF Cat | Kramer3608 | Normally Aspirated Powertrain | 20 | 02-16-2015 01:27 PM |
Support the Rallisport Racing 2.5i build | GEE-OTTO | Normally Aspirated Powertrain | 18 | 02-16-2015 01:25 PM |
It's finally time for the ice racing! | see red | Mid West Subaru Owners Club Forum -- MWSOC | 19 | 11-07-2011 11:35 AM |
i finally cracked opened the motor i blew at the last race... | giveme5bux | Texas Impreza Club Forum -- TXIC | 11 | 07-01-2007 01:27 PM |
Ultimate-Racing 785CC final map impressions | RiftsWRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 07-24-2003 04:18 AM |
