07-21-2010, 12:52 AM | #1 |
Member#: 235744
VIC
Vehicle:2000 Forester STi White - JDM yo! |
UEL headers , CEL
i've been researching for different UEL header setups for my07 2.5i and was noticing that people are getting CELs and some dont.
Is there a good setup to avoid getting CEL? if you're not getting a CEL on your 2.5i, can you post your setup? thanks! -JC **my bad, if this has been asked a million times, i swear i searched!
07-21-2010, 09:52 AM | #2 |
Member#: 201277
Vehicle:2008 08 QSM 5MT LGT QSM |
only way to be sure of no MIL is to have it tuned
07-21-2010, 10:57 AM | #3 |
Member#: 243234
Vehicle:2009 Hatch OBP |
For a lot of people it's only because they new UEL headers they bought have thinner walls so they let more heat escape and the CEL the car is throwing is because temp. at the catalytic converter are too low and not high enough for maximum efficiency. If that's the CEL that's being thrown either powder coating or wrapping the headers will prevent this.
07-21-2010, 02:17 PM | #4 |
Member#: 71092
Vehicle:2005 2.5RS Wagon Regal Blue Pearl |
Ceramic coating won't prevent the P0420 DTC. Been there, tried that. Wrapping them will prevent it under some environmental conditions, but not all of them.
07-21-2010, 04:57 PM | #5 | |
Member#: 241216
Vehicle:2000 Outback 2013 SWP BRZ |
I'd have to assume that wrap and having the cat immediately follow the header would be the best setup for these newer cars (07+, right?) |
07-21-2010, 07:37 PM | #6 |
Member#: 235744
VIC
so wrapping the headers fixes the CEL issue?
I'd have to assume that wrap and having the cat immediately follow the header would be the best setup for these newer cars is this true? |
07-21-2010, 09:09 PM | #7 |
Member#: 241216
That last part was supposed to be posted as a question. I was making an assumption, and waiting for someone to confirm or deny that.
I've heard it's the '07+ cars that are finicky with the o2 sensors, so that was another question in there. |
07-21-2010, 09:39 PM | #8 |
Member#: 71092
I think it's a head and flow issue. Controlling the heat does seem to help the situation. However, there's no guarantee that wrapping the header will prevent the DTC.
07-21-2010, 11:19 PM | #9 |
Member#: 231904
RMIC
Vehicle:2007 WRX UGM |
yeah ive got my headers coated, wrapped and then coated again and i got a CEL two days ago and its starting to go on and off!
07-21-2010, 11:57 PM | #10 |
Member#: 235744
VIC
hmmm...
so is the CEL just randomly coming off? do you guys have to reset the ECU to take it off or does it go away on its own? |
07-22-2010, 09:12 AM | #11 | |
Member#: 201277
The is also why you should have UEL custom made for 2006+ cars to have the cat as close to the stock location as possible. |
07-22-2010, 11:44 AM | #12 |
Member#: 235744
VIC
@GEE-OTTO - so basically, wrapping the headers and having the cat as close to the stock location as possible will prevent the CEL?
07-22-2010, 01:35 PM | #13 | |
Member#: 71092
Once you start modding the exhaust there is no miracle cure. You can do some things, such as wrapping the exhaust, that make it more or less likely that you'll keep the ECU happy. There are no guarantees. |
07-22-2010, 02:19 PM | #14 |
Member#: 235744
VIC
ok..
burble with CEL or no burble, no CEL... right? |
07-22-2010, 02:20 PM | #15 |
Member#: 71092
Or you could get a top-quality EL header and disable the DTC in the ECU and have both power and no DTC. Best of all worlds.
07-22-2010, 04:34 PM | #16 |
Member#: 235744
VIC
but i want the rumble though..
07-22-2010, 04:37 PM | #17 |
Member#: 71092
07-22-2010, 05:01 PM | #18 | |
Member#: 235744
VIC
damn people these days.. <---- subie newbie, but not ricer. |
07-23-2010, 09:54 AM | #19 | |
Member#: 201277
however you can get this tuned out the user kero had this done for his 2.5i with UEL setup and he has no MIL's |
07-23-2010, 10:06 AM | #20 |
Member#: 201277
Hey youre not alone in that desire I see both sides EL and UEL this is owner choice. The stock is a great EL header but the other ones work well and give you some bottom end grunt. I think Willitay has a graph showing the gains of the EL over the UEL over stock I want to say there was 5-10 hp gains at high RPMs EL vs UEL but I personally don't drive in the 5K RPm range regularly nor do I consider my 2008 Legacy 2.5i a "perfomance" vehicle it is a sporty one but no way a performance car so I can live with the boxer rumble and without 7 extra ponies up top but some are performance driven and opt for the EL to squeeze ever HP they can out of their EJ251/3. Again owner choice and the EL still comes with the MIL like the UEL |
07-23-2010, 10:15 AM | #21 |
Member#: 235744
VIC
^ thanks! i could live without extra hp as well and get the rumble.
07-23-2010, 10:44 AM | #22 |
Member#: 201277
07-23-2010, 10:58 AM | #23 |
Member#: 235744
VIC
nah, i dont drag or any kind of race.. just dd all day..
thanks for the tips! |
07-23-2010, 12:04 PM | #24 |
Member#: 94299
Vehicle:2000 2.5 RS Sedan SRP |
I had gotten the P0420 cat deficiency cel with my UELs and trackpipe, I had a local tuner edit the ECU MAP to remove that code all together, has never come back up since and it allowed me to pass inspection now and forever, granted they don't check under the car.
07-23-2010, 12:18 PM | #25 |
Member#: 231058
TXIC
It is true that the only way to permanently clear the DTC is to eliminate it via reflash. That's how the track pipe boys do it. Welding a cat in a near stock location is next to impossible because the stock cat is actually integrated into the exhaust manifold. I have a high flow cat in mine, but I'm not running any o2 sensors. I had my tuner take out the codes, and I have not had any issues at all.
Similar Threads | ||||
Possible Complete UEL Header Solution for P0420 CEL | nti_hazard88 | Normally Aspirated Powertrain | 61 | 01-04-2024 07:03 PM |
CEL error after installing Borla UEL headers? | MerrosFox | Normally Aspirated Powertrain | 5 | 02-05-2010 03:25 PM |
FS NY: Heat coated Fujitsubo EL header, Gruppe-S UEL header, STi uppipe | garface | Engine/Power/Exhaust | 27 | 05-07-2009 11:00 AM |
el headers for uel headers | gostdog | Private 'Wanted' Classifieds | 8 | 12-02-2008 10:46 AM |
NJ: GC jet-hot coated borla UEL headers and stock headers | M E R C U R Y | Tri-State Area Private Classifieds | 1 | 05-12-2008 01:58 PM |
