03-07-2005, 08:05 AM | #1 |
Member#: 10831
TXIC
Vehicle:1995 Firehawk #456 2009 FXT VF52/E85 |
so if my steering wheel shakes like a monkey passing persimmon seeds when I brake...
...over 50 mph, do I need to get my rotors turned?
there is no shaking whatsoever when I cruise over 50. thanks
03-07-2005, 08:26 AM | #2 |
Member#: 11926
Vehicle:2011 Outback Limited Dark Grey |
rotors need to be turned.
03-07-2005, 08:44 AM | #3 |
Member#: 22290
TXIC
Vehicle:2002 STI Ver 9 Spec C Wagon |
Maybe change your anti-shudder-under-braking fluid?
03-07-2005, 08:49 AM | #4 |
Member#: 64073
TXIC
Vehicle:2004 WRX STI Aspen white |
Quite feeding your car persimons?
Also had this problem on my BMW, turned out it was the control arm bushings giving the shakes between 40mph-55mph. |
03-07-2005, 08:58 AM | #5 | |
Member#: 10831
TXIC
did it shake at cruise or just when braking?
this is on the forester, btw Quote:
03-07-2005, 09:03 AM | #6 |
Member#: 4800
TXIC
Vehicle:1990 Legacy & OB XT AWD 6MT EJ22T AWIC Swap |
If it shakes only under braking, more then likely it's the rotors. You may just have uneven pad deposits, or the rotors may not be true any more.
If the rotors look like they have sporadic splotches of brake pad material on them, you can try sanding them down to remove the deposits, and then rebed the brake pads. |
03-07-2005, 09:07 AM | #7 |
Member#: 82333
Vehicle:2003 Impreza WRX Silver |
Sounds like me 8 months ago...I bought some slotted drilled rotors and replaced the stock ones.
03-07-2005, 09:08 AM | #8 |
Member#: 10831
TXIC
will I lose any credibility here if I just take it to brake check?
03-07-2005, 09:10 AM | #9 |
Member#: 82333
If you mean take it and have someone else do it....prolly not.
If you do it yourself you may gain some. |
03-07-2005, 09:11 AM | #10 |
Member#: 10831
TXIC
what I would *like* to do on that car is put in rear disks, it has rear drums now
03-07-2005, 09:20 AM | #11 |
Member#: 39575
TXIC
Vehicle:2005 WRX STi WR Blue |
get it fixed before it eats up your tires!
03-07-2005, 09:20 AM | #12 | |
Member#: 50142
TXIC
Vehicle:2002 2.5TS MBP |
Do not go to "just brakes". |
03-07-2005, 09:32 AM | #13 | |
Member#: 64073
TXIC
It would shake at those speeds and when you attempted to brake at thos speeds it REALLY shook! |
03-07-2005, 09:51 AM | #14 |
Member#: 19674
TXIC
I had the same thing happen on my car after I cooked the rotors at a track day... Getting the rotors turned solved the problem.
03-07-2005, 10:26 PM | #15 |
Member#: 10831
TXIC
it was the rotors
it brakes great now man, those techs at goodyear downtown are bored, this one dude kept talking to me about how cool the forester sounds I don't think they had ever seen a modded subie before |
03-07-2005, 10:44 PM | #16 |
Member#: 54294
Vehicle:2001 *RIP*BRP 2.5 RS |
get the rotors machined they are probably warped probably happened after applying the emergency brake to hard after they had gotten hot, had the problem last year took them to NTB had them machined and it was all good.
03-07-2005, 10:45 PM | #17 |
Member#: 10831
TXIC
they turned them
03-07-2005, 10:49 PM | #18 | |
Member#: 26361
TXIC
Vehicle:My shenanigans are cheeky and fun |
03-07-2005, 11:57 PM | #19 | |
Member#: 10831
TXIC
I'm not a miracle worker |
03-08-2005, 12:19 AM | #20 |
Top Scoob 024
Member#: 56364
International
Vehicle:RIP stompr :( bagged vulvva |
mine shakes while braking too...
03-08-2005, 08:32 AM | #21 | |
Member#: 10831
TXIC
you may need your rotors turned
you can save a bit of money by DIY (taking off the rotors, getting them machined and then putting them back on) Quote:
03-09-2005, 12:32 AM | #22 |
Top Scoob 024
Member#: 56364
International
would this be a good excuse to upgrade?
03-09-2005, 01:11 AM | #23 |
Member#: 71959
Vehicle:2002 Subaru WRX World Rally Blue |
How much did that cost to get your rotors turned if u dont mind me asking, I have the same problem every now and again....
03-09-2005, 01:23 AM | #24 |
Member#: 26361
TXIC
BTW the problem probably came from the pads not being bedded in properly, so make sure you bed them in right or it could reoccur easily.
03-09-2005, 07:21 AM | #25 | |
Member#: 17580
TXIC
Vehicle:2002 Impreza WRX Platinum Silver Metallic |
1234 --David |
Steering wheel shake when braking at speeds over 30mph or so | kaisersouse | Brakes, Steering & Suspension | 53 | 10-13-2009 02:06 PM |
Steering wheel shakes when brakes are applied? | Xanthinuria | Brakes, Steering & Suspension | 8 | 02-08-2007 09:45 AM |
My steering wheel shakes during hard braking? | adrive43 | Brakes, Steering & Suspension | 11 | 08-01-2005 04:22 PM |
my steering wheel shake over 60mph...help!!! | darkmist2k1 | Tri-State Area Forum | 22 | 07-24-2004 08:13 AM |
Steering wheel shakes when braking | k_thaosta | Brakes, Steering & Suspension | 11 | 08-13-2003 07:48 AM |
