04-10-2016, 07:25 AM | #1 |
Member#: 158864
Vehicle:2003 SOHC destroker |
Getting air conditioning working with different compressors
Ok so, I've been looking at swapping an ez30r into an NA GD. However, for it to be totally DD'able, I NEED the air conditioning to be working.
The ez compressor has two plugs, each with two wires. The EJ has a single plug with a single wire. Simply connecting the wire to any of the connections on the EZ compressor doesn't work, but we have in the past "jumped" the connections at the fusebox so that the compressor is always on, but this obviously isn't how the system works. Having little knowledge of how the systems decide to go on/off as necessary, I'm wondering how I can get the EZ compressor to work on the EJ body harness/dash/system. Anyone help?
04-11-2016, 04:49 PM | #2 |
Member#: 71665
South East
Vehicle:1994 Impreza White |
I'm sure you thought of this option already but what about using the EJ compressor on the EZ engine? Fitment issues? I'm not familiar with the EZ stuff at all but my recollection of the GD compressor wiring is that it is controlled by the ECU and not the dash/body harness stuff (the heat/ac "head unit").
