08-16-2005, 10:45 PM | #1 |
Member#: 7241
Need help with Voicecoil alignment
Hey all, is there an instruction of how to align a voicecoil properly before applying glue so that it wouldn't touch the magnet when the cone is pressed down?
I took the speaker (165V2) apart to reseat the voicecoil because it created a lot of noise at high volume. Seemed as if it was touching/scratching somewhere inside. Thanks in advance.
08-16-2005, 11:37 PM | #2 |
Member#: 33879
SCIC
Vehicle:2003 WRX Sporkwagon Black |
08-16-2005, 11:51 PM | #3 |
Member#: 84114
Vehicle:05 Impreza/STI Black |
whew...boy did u take on a job lol
08-17-2005, 03:34 AM | #4 |
Member#: 10471
TXIC
Vehicle:2000 BMW Z3 sold Outback & ForesterXT |
yes, there are instructions on the net, but you usually need to take off the dustcap first and then use shims between the coil and magnet pole...
08-17-2005, 08:24 AM | #5 |
Member#: 7241
Thanks! Just found out useful info on the site. Looks like I have to crack open the dustcap somehow and reuse it later.
08-17-2005, 08:41 AM | #6 | |
Member#: 18453
NESIC
Vehicle:MY02 WRX Sport Wagon |
Really, no foolin'? speaker |
08-17-2005, 08:48 AM | #7 |
Member#: 7241
Yeah really. Took me literally 3 hours to take apart everything because I had to be careful on what I cut. Dealers told me Focal stopped making reconing kits for this model anymore, so I just wanted to give it a try.
If I mess it up, new CDT EF61 is waiting on the line. So far, I was able to take off the surround rubber 100% without any problem, and spider also with a bit of bad cuts, but still in good shape. The challenge would be removing/cutting the dustcap to insert the shims. |
08-17-2005, 11:37 AM | #8 | |
Member#: 18453
NESIC
The voice-coil became damaged (likely via overdriving it) and banged against the pole/top plate of the magnet. This might have bulged out the voice-coil former and that is what is scraping. Is the former aluminum and is the damage visible? Can your smooth it out? This may be all you need to do for repair. This damaged may have also happened because it was improperly aligned at the factory. To fix, you need to do is align the entire assenbly, not just the voice-coil in the cone neck. The voice-coil does not need to be removed from the neck. You'll need to remove the dustcap & shim between the voice-coil & magnet pole. For shims, you can use sheet brass shim stock. You should be able to get that at NAPA or other hard core auto parts stores. Cut strips & space them at 120-degree intervals. If they don't take up the slack & center, you'll need 3 more strips inserted between the first ones & the pole. You'll need to buy a few different thicknesses in order to get the proper fit. Consider this first exercise a test run. Now, remove everything and run a glue bead around the spider & surround deck. Glue needs to be robust. Cyano is fine but you need to use slow set to allow you to push down the pieces into the glue and clamp them. You can use binder clips from Staples, etc. Lastly, assuming you got the dustcap off in one piece, make a small masking tape handle for it. Cut a strip of tape 3/8" wide & fold it over & make a "T". The top of the "T", the sticky parts, gets stuck to the cap. The non-sticky part is your handle so you can center the cap back on the cone. If the cap is paper/fiber/fabric-based, Elmers glue is fine. If it is plastic, cyano again. Leave the tape in until the glue cures. Once you have successfully completed the above, you are fully qualified to put the wings back on flys, heads back on chickens, build the USS Enterprise inside a Jack Daniels nip, etc. Personally, I'd stake out eBay and find the mate to the woofer you need. I've done the above operation plenty, but only when serious scratch is at stake such as a 50 year-old Altec coaxial and so on. Your time IS worth something. speaker |
08-17-2005, 09:15 PM | #9 |
Member#: 7241
Hi, I put the shims as you instructed after cutting the dustcap off, and finally glued it. Voicecoil had no damage at all. When I push the cone down with 3-4 point equal pressure, it still hits/scrapes something at the bottom. Could it be either the magnet or the coil is not 100% perpendicular and angled slightly?
Oh well, I am ordering CDT today. Thanks for all your advice. It's been a great experience though. |
08-18-2005, 01:11 AM | #10 |
Member#: 10471
TXIC
maybe the speaker has demon spirits trapped in it and it is haunted... Nothing is worse than a speaker haunted with the ghost of some crazy stereo freak who died in a tragic amp install accident!!!
08-18-2005, 01:26 AM | #11 | |
Member#: 18453
NESIC
speaker |
08-18-2005, 03:57 AM | #12 |
Member#: 33879
SCIC
I had the same problem for two reasons:
1) magnet assembly came partially loose and slid out of alignment (presumably related to water damage) 2) basket got bent and put magnet out of alignment. if either of these things are true, nothing you do to the VC is going to get it to line up right. #2 I fixed by beating the magnet with a rubber mallet until the noise stopped. I'm still using that speaker 6 years later. #1 I gave up on. |
08-18-2005, 12:22 PM | #13 |
Member#: 7241
Actually the voicecoil doesn't just hit the bottom of the magnet when pressed down. It starts scraping the sides when it's pressed half way down. It was working fine until some water drops went into the vent hole in the middle of the magnet and started rusting.
I beat the crap out of the speaker everywhere and now it doesn't make that sound when pressed down. I will hook it up to the amp, and see what happens. Those speakers are rated at 75RMS, 150W max. and I am using Phoenix Gold Titanium Ti400 which delivers 100W per chan. Thanks for all the tips. |
08-18-2005, 12:29 PM | #14 | |
Member#: 33879
SCIC
well then... aligning the voice coil isn't going to do anything about the corrosion in the gap that's causing the problem in the first place. |
08-18-2005, 02:19 PM | #15 | |
Member#: 7241
I did take out some chunks of metal / rust out of the magnet though, even tho it took me like 30 min. Since it looks like it's good now (even tho the speaker looks like beat up and missing dustcap), I will hook it up tonight and post the results. Last edited by GOT_WRX; 08-19-2005 at 09:07 AM. |
Need help with something | truenosan | Vancouver Impreza Club Forum -- VIC | 7 | 06-02-2010 09:05 PM |
Need help with an alignment!!!! | vminev | Mid Atlantic Impreza Club -- MAIC | 1 | 09-17-2007 10:00 AM |
need help with engine swap, need clutch alignment tool | simprezl25 | Mid Atlantic Impreza Club -- MAIC | 5 | 06-21-2006 12:37 AM |
Need help with STI suspension/cusco tops alignment | Willman67 | Brakes, Steering & Suspension | 7 | 08-03-2002 12:46 PM |
Need help with alignment spec. WRX sedan. | Chris02WRX | Brakes, Steering & Suspension | 3 | 04-16-2002 11:59 AM |
