12-07-2008, 11:47 PM | #1 |
Member#: 90357
Vehicle:2006 Corey's EVO & 1993 Mazda RX7 |
Please Help: Looking for an STU car to run @ El Toro ProSolo and San Diego Nat. Tour
ProSolo El Toro (3/28 - 3/29) and San Diego National Tour (3/21 - 3/22).
Any west coast STU'ers out there want to offer me a co-drive at either or both of these events. Your car needs to not fully prepped either. Just looking for something with 245 width tires, stiff springs/coilovers, and lots of negative camber. If you're not sure your car qualifies as STU class PM me and I can help you determine its class. I can offer the following compensation: -Beer -Use of my STU WRX STi at some east coast '09 ProSolo or National Tour events -Monetary compensation Please post or PM me if you can help. Thanks! Regards, Jake My Car Set Up 1. Intake: OE Airbox with the Home-Depot-Special Ram Air Ducting 2. Exhaust: Grimmspeed Uppipe, COBB Downpipe, Custom Magnaflow High-flow Catalytic Converter 3. Suspension: H&R/Bilstein/Perrin Coilovers Spring Rates - 457F/336R, Group-N Rear Top Mounts, Cusco Front Camber Plates, Whiteline 29mm FSB, Cusco 24mm RSB, Whiteline Steering Rack Bushings, Hotchkis Endlinks F&R, Front Strut Tower Brace 4. Alignment: -2.75 F Camber, -1.2 R Camber, 0 Toe 5. Tires: TBD 6. Wheels: Rota DPT 17x9 +42et 6. Brakes: Technifit SS Lines, ATE Blue Fluid, Hawk HP+ F&R 7. ECU: Stock 8. Other: Group-N Transmission Mount, Group-N Motor Mounts, TIC Race Differential Mount Bushings, CG Lock Seatbelt Tensioner, Hawker Odyssey PC680MJT Lightweight Battery 15 lbs My Autox Resume (not comprehensive, but you get the idea) -Trophied at '08 DC ProSolo -Trophied at '08 Devens National Tour -'08 STU Champion NNJR SCCA -'07 A Class champion NASA/MotorsportsNE -5th Place Overall '08 PAX Season Championship NNJR SCCA References available upon request.
12-08-2008, 08:05 PM | #2 |
Member#: 4096
Vehicle:noun [ ve·hi·cle ] a carrier,as of infection |
You might try posting to the SCIC chapter...
SLR- |
12-08-2008, 08:30 PM | #3 |
Member#: 90357
I'll give it a try, but I have a feeling STU people check here more than local boards.
12-10-2008, 04:31 PM | #4 |
Member#: 90357
Note: Other compensation = $$$
12-10-2008, 06:38 PM | #5 |
Member#: 47448
SCIC
Vehicle:1999 FP BMW Elitetint.com/ChaseCam |
STU competitors in So-Cal have dwindled significantly for '09.
12-10-2008, 06:51 PM | #6 | |
Member#: 90357
Bummer. Too bad. STU is one class that never ceases to have a large turnout of fun, cool, down to earth competitors.
In another post of mine, a member said I should post some of my "qualifications" and some references. Here is what I wrote. Quote:
12-10-2008, 07:22 PM | #7 | |
Member#: 47448
SCIC
Well, you can try: Cal Club http://Forums.solo2.com & Sand Diego http://www.sdsolo.com/forum/index.php |
12-10-2008, 11:34 PM | #8 |
Member#: 31821
SCIC
Vehicle:2015 DS WRX |
Good luck - I hope you get a ride. Unfortunately my old car is is now commuting with a baby seat in the back
12-11-2008, 02:58 AM | #9 |
Member#: 103068
SCIC
Vehicle:11 STI sedan SWP |
I am open to you running my wagon, but I'm not sure if it falls within STU.
17x8 RPF-1 245/35R17 R1R JIC FLT-A2 Cusco rear adjustable sway bar KB rear end links Cusco rear stiffening bar STI diffuser Cobb AP stage 2 91 oct CA map Titek catless DP Greddy SP2 exhaust DBA 5000 XS front rotors Project Mu HC+ front pads Rotora lines (all 4 corners) Last edited by littlewhitewagon; 12-11-2008 at 03:03 AM. |
12-11-2008, 03:14 AM | #10 | |
Member#: 61077
SCIC
Vehicle:1993 WRX Silver |
12-11-2008, 10:48 AM | #11 |
Member#: 90357
Thanks! but I need an stu legal car. You ecu map is illegal too. But that's a quick fix.
12-11-2008, 12:20 PM | #12 |
Member#: 31821
SCIC
Jake - I don't think the local STU people, other than Rick Jung, really know if they will be signing up yet. STU has been dominated by two cars here which has lead to some apathy on the part of the other drivers. You should also post on the solo2 forums, since that is the LA region.
Closer to the time, I'll do all I can to get you a ride - the more in STU the better! |
12-11-2008, 12:37 PM | #13 | |
Member#: 90357
http://forums.solo2.com Doesn't have a registration link nor a contact information for the admin. How do I get on this forum? Last edited by S1MPSONS; 12-11-2008 at 12:44 PM. |
12-11-2008, 12:50 PM | #14 |
Member#: 101199
Vehicle:2013 BRZ Black |
BlackWRXWag = reighning ProSolo champ, and his accent is quite intimidating!!! Ha ha
12-11-2008, 12:57 PM | #15 | ||
Member#: 90357
I just check the ProSolo '08 season STU results. Does anybody know Aaron? Is he a NASIOC member? He ran really well this year and also ran El Toro. Maybe he would be interested. |
12-11-2008, 01:09 PM | #16 |
Member#: 101199
If you look closer, Aaron was Max's pit boy
12-11-2008, 01:13 PM | #17 |
Member#: 90357
Haha. Right then, that makes sense. So is this STU car still around? What does all that baby-seat commuter-car talk mean? Street driven autox cars is what STU is all about.
12-11-2008, 01:45 PM | #18 |
Member#: 31821
SCIC
Aaron is aufaber and has posted in this thread. He is also the admin for forums/solo2
12-11-2008, 01:55 PM | #19 |
Member#: 90357
Thanks! PMed Aaron to set me up on solo2forums. So Max, are you running STU next year?
12-11-2008, 03:58 PM | #20 |
Member#: 31821
SCIC
12-11-2008, 05:13 PM | #21 |
Member#: 101199
People who are observant will figure out who's car it is pretty quick
12-11-2008, 11:44 PM | #22 |
Member#: 89528
Vehicle:2005 sti crystal grey |
12-12-2008, 12:53 PM | #23 |
Member#: 47448
SCIC
12-12-2008, 12:57 PM | #24 |
Member#: 101199
12-12-2008, 01:17 PM | #25 |
Member#: 71634
Vehicle:In hibernation... |
^Wait?! Do you still have the '09 WRX Annie???
