12-26-2006, 08:15 PM | #1 |
Member#: 90387
Vehicle:2017 WRX Limited CWP |
Speedometer not working Help!
Code: P0502 (from auto zone obd II scanner)
Symptoms: Dead speedometer, rpm not passing 4500 rpm (limp mode), radiator fan constantly running. I took the car to a dealership and they said it is ECM logic issue The service rep said they checked the speed sensor and it is okay. The service statement said they my car has down pipe and ECM logic has been changed. Therefore, it's not warrantable. No repair has been made. Is this another dealership BS to deny warranty work or something wrong with my AP?
12-26-2006, 09:29 PM | #2 |
Member#: 15607
Vehicle:I'm not the type to make angry |
Umm I think you forgot to unplug your green test connectors?
12-26-2006, 09:38 PM | #3 |
Member#: 90387
It's unplugged. I've been running stg 2 for almost a year w/o any issues and it just happened last week.
It's throwing code P0502(speed sensor low input) and dealer service rep is saying the speed sensor it okay. They gave me a loaner, but I ended up paying for it since the problem was not warratable. Is it really my ECU causing this problem? Could it be speed sensing gear inside the transmission? Do you have any other idea? |
12-26-2006, 10:04 PM | #4 |
Member#: 9436
Vehicle:05 Saab 9-5 Aero |
If the speed sensor is working and the speedometer registers speed when it is spun, then the drive gear inside the transmission (I'm assuming you have a manual trans) is stripped. That could IN NO WAY be caused by modifiying your car, unless your transmission has been disassembled. I'm not saying that is is common, *cough* yes it is *cough* but we have heard of it at Saab...
Oh, and the ECM has absolutely NO control over speedometer function on your car. (again, this only applies to a manual transmission car) There is a direct wire from the speed sensor that branches to the ECM, speedometer, and the cruise control module. If you took the ECM out and threw it away, and towed the car at 50mph with the key on, the speedometer will still read 50mph. The tech who worked on your car probably rides the short bus and has his mama wipe his arse for him. Take the car to a dealer that knows what the Foxtrot they are doing. WHEN the other dealer fixes it under warranty, contact SOA and politely ask them to refund your money spent for the loaner. |
12-26-2006, 10:18 PM | #5 | |
Member#: 90387
The service rep at libertyautocity said that my ECM is not getting any signal from the speed sensor due to the bad software program (blaming ecu reflash) as well as radiator fan issue. If it's not the speed sensor, it could be a gear inside the transmission? I'll try the other dealer around here. Thank you for the information! |
12-27-2006, 04:43 AM | #6 | |
Member#: 86322
12-27-2006, 08:48 AM | #7 | |
Member#: 90387
12-27-2006, 12:45 PM | #8 |
Member#: 15607
I didn't mean to insult, was just making sure.
12-27-2006, 01:08 PM | #9 |
Member#: 90387
12-27-2006, 10:58 PM | #10 |
Member#: 15607
Check the ground strap going from the trans to the firewall (next to the dogbone) sometimes they corrode and get a little wacky
01-09-2007, 12:59 PM | #11 |
Member#: 90387
Waited almost 2 weeks for the speed sensor. The worst part is the problem is not the speed sensor, it's the speedometer gear inside transmission and the dealer won't fix it under warranty due to aftermarket modification. What the f$#*! They knew I had DP and would fix the speed sensor under warranty, but not the speedometer gear!
Just called the SOA and they will get back to me. |
01-09-2007, 02:38 PM | #12 | |
Member#: 6551
Vehicle:'01 GC8 Dinged STM '09 Concours 14 ABS Black |
Sorry but a down-pipe is NOT going to destroy a speedo drive gear in a transmission. Remember if you are lightly modified good luck, SOA is pretty useless. Jeremy Last edited by HndaTch627; 01-09-2007 at 03:00 PM. |
01-09-2007, 02:59 PM | #13 |
Member#: 90387
The dealer service rep was referring to warranty bulletin #01-156-03.
I need to return the loaner and ressolve the issue with SOA. I don't get it why they would replace speed sensor under warranty, but not the speedometer gear???? |
01-09-2007, 05:43 PM | #14 |
Member#: 9436
Fight it out with SOA. They need to prove that your modifications caused the speedometer gear to fail, not just "because we say so". You could put 600hp through your trans, or tow a boat and ever hurt the speedo gear, it does not receive drivetrain load.
It is a known issue, and SOA does not want to own up to it. MANY unmodified 9-2x models are having this concern. Settle for nothing less than 100% warranty coverage. |
01-09-2007, 08:30 PM | #15 | |
Member#: 15607
You are right in your cause, but you're facing a very up hill battle. |
01-09-2007, 09:28 PM | #16 | |
Member#: 90387
This sort of experience makes me stay away from Subaru. Thank you so much for the information! |
Speedometer Not Working | byronchaudoin | Transmission (AT/MT) & Driveline | 11 | 01-21-2006 07:16 PM |
Speedometer not working (Legacy '96 2.0 Auto FWD) | itzik93 | Service & Maintenance | 11 | 07-21-2005 04:20 PM |
speedometer not working | austenf740 | Electrical & Lighting | 6 | 01-02-2005 01:02 PM |
Speedometer Not Working | bradandrose | Electrical & Lighting | 5 | 05-27-2004 03:21 PM |
WRX conversion done but speedometer not working! | subispeed | Subaru Conversions | 8 | 04-21-2003 06:32 PM |
