08-10-2007, 07:00 PM | #26 |
Member#: 74916
AKIC
Vehicle:2000 2.5rs Coupe SRP 13 Jeep JKU |
Can you do OBD1 GMC's? If so, can you burn memcal chips for, oh...lets say a 1991 GMC Syclone?
08-10-2007, 07:01 PM | #27 |
Member#: 135785
AKIC
Vehicle:2006 Impreza WRX LTD Cloaking Device Gray |
What do you mean, sticky throttle? Does it respond really sluggishly or does it just take a while to stop spinning after full throttle input?
08-10-2007, 07:15 PM | #28 |
Member#: 129905
AKIC
Vehicle:2005 WRB WRX 2003 F-350SD, 7.3PSD |
I've talked to the creator of that map, and a few other people, and there is nothing that would make the throttle "stick". I'll look at it, but the other cars ive tuned w/ this exact map have had absolutely no problems with it. Henry, PM me so we can set up a time to log, that will tell is if its truely sticking or not.
08-10-2007, 07:16 PM | #29 |
Member#: 129905
AKIC
08-10-2007, 07:17 PM | #30 |
Member#: 129905
AKIC
He says that when he lets off of WOT, it feels like the throttle is still on the floor for a second after the throttle is off the floor. Gabedude gave a real good explanation on what it probably is. I'll post it here in a few.
08-10-2007, 07:23 PM | #31 |
Member#: 129905
AKIC
Me - Okay so I flashed my buddy's 07 TR. Everything has been fine since the flash (2 weeks ago) until Saturday. He did an autox event and he said the throttle is sticking.. Not just a noticable stick, but a scary stick. I was wondering if it could have ANYTHING to do with the dbw mapping, or if it might be a mechanical failure? I haven't got to log the car yet to get an actual log showing 0***37; pedal and an elevated tb opening percentage.. but if he can feel it, im pretty sure its gotta be doing what he says it is. He had another guy drive it as well and he also noticed it..
Gabe - Sticking as in he had to shut the car off? The DBW cars have some lag in them when you let off the throttle. If you push the throttle in and let off real quick, the rpms will climb for a split second (like the throttle is sticking), but will soon come down. It is by design. Me - Not having to shut down, but felt like it was still WOT for a moment or 2.. Gabe - It may be a mechanical issue. When you let off, it should only rev about 200-500 rpm more then drop or so. If it keeps revving for more than a second, then worry about part failure. Once the accelerator angle is at 0, then everything should start to shut down. The maps really have little effect on this, and it is not changed from stock that much. Me - Thats what i was thinking, i just wanted to make sure i was correct.. Gabe - Yeah that DBW behaviour is normal. If you look up "gabedude" you will see that he is a very well known open ecu tuner, and he has created more than half of the open ecu maps that people are using. |
08-10-2007, 07:37 PM | #32 | |
Member#: 135785
AKIC
Yeah Henry, my map does the exact same thing. It is call POWER! (and drive by wire >>) Get used to it and learn to not punch it every chance you get, that is exactly what I have to learn on the auto-x course |
08-10-2007, 07:44 PM | #33 |
Member#: 114704
Vehicle:1990 Mazda Miata BRIGHT ASS RED |
It wasn't so much Henry having a problem with it, as much as me. I never expreienced this with my friends moderately modded STi, so I guess I will just have to let off the gas way before I enter a corner. I'm used to going into a corner, letting off the gas, mashing the brakes, rotate the car, and get back on the gas without the worry of having this lagging.
08-10-2007, 07:53 PM | #34 | |
Member#: 135785
AKIC
Yeah, I had an incident the other day because of this same issue on the street. |
08-10-2007, 07:57 PM | #35 |
Member#: 32993
AKIC
Vehicle:vf39 Best trap 110 Best ET 12.51 Dale tuned |
i'm so glad my throttle is done by cable
08-10-2007, 08:16 PM | #36 |
some old guy
Moderator Member#: 112225
AKIC
Vehicle:1985 78 HP of Rage! Blue |
I haven't had a similar problem.
08-10-2007, 08:34 PM | #37 | |
Member#: 132030
AKIC
Vehicle:2007 obp STI broken again |
08-10-2007, 08:39 PM | #38 | |
Member#: 114704
I don't know its just me, I like to be in 100% control of the car I'm in. |
08-10-2007, 08:53 PM | #39 |
Member#: 129905
AKIC
well we are stil gonna datalg it, but its a normal occurance in the new 2.5 rex's, especially tuned ones. ill look at the map and see if there is anything i can do about it. call me sometme henry so we can set up atime to meet.
08-10-2007, 09:21 PM | #40 |
Member#: 132030
AKIC
tell you the truth tom its not going to happen before the auto x i got the kid tonight and all day tmro . jeff if you dont feel comfy racing the car dont, i dont mind it and i drive the car the most hell it is my car and hadnt really had much of a problem with it
08-10-2007, 10:16 PM | #41 |
Member#: 129905
AKIC
if you have someone you can trust to drive ur car, lemme know and ill meet up with them if u want. if not we can wait til sunday night (if ur available)
08-11-2007, 02:27 AM | #42 |
Member#: 132030
AKIC
08-11-2007, 04:13 AM | #43 | |
Member#: 114704
08-12-2007, 07:48 AM | #44 |
Member#: 115511
AKIC
Vehicle:2005 wrx /w babyseat 2015 Legacy |
yyyaaaarrrr!!! why cant you be in the fairbanks vicinity? yyyaaarr!!!1
me needs datalog for better tune |
08-12-2007, 03:12 PM | #45 |
Member#: 135785
AKIC
Alright T4nk, I will take you up on your offer for datalogging when I get my turbo in.
08-12-2007, 03:27 PM | #46 |
Member#: 129905
AKIC
lol if its worth a drive down here then come on down
and what turbo justin?? |
08-12-2007, 03:38 PM | #47 |
Member#: 135785
AKIC
08-12-2007, 03:55 PM | #48 |
Member#: 129905
AKIC
ah, was the old one P&P?
u need a cripple map til your new one gets here?? |
08-12-2007, 04:13 PM | #49 | |
Member#: 135785
AKIC
It was somewhat ported. The compressor housing was chewed up in the past and Dale cleaned it up. The wastegate was ported too just to prevent any kind of boost creep issues. No, I don't need a cripple map, the turbo is out of the car and the car is on stands. Thanks ^^. |
08-12-2007, 08:05 PM | #50 |
Member#: 115511
AKIC
i want to come down in september before snowfall. ill let you know.
help! cel p0134 & p0171, data log inside | thickfacek | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 12-21-2009 07:33 AM |
Data logging gurus, need your help reading log. | vortectoy | AccessPort | 5 | 05-22-2006 01:19 AM |
Data logging a stock ECU motor | xtrred | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 12-22-2005 10:40 PM |
Additional Data Calculations from ECU Logs | IndyRacer | Engine Management & Tuning | 5 | 12-17-2005 07:44 AM |
Some (possibly) good data with 12psi on an EJ22T on stock injectors & ECU | Eric SS | Normally Aspirated with bolt-on Forced Induction Powertrain | 2 | 04-17-2003 03:18 AM |
