Brakes & Suspension Forum sponsored by The Tire Rack |
05-22-2003, 08:49 PM | #1 |
Member#: 37222
Vehicle:2008 335i White |
WRX stuff --> RS
Hey all
i am picking up a brand new 04' impreza 2.5RS tomorrow , i cant wait but i was wondering... my dad has an 03' WRX and he had H&R springs on his car for a little bit before he went with full coilovers, and i was wondering if those springs would fit/work on my RS?? also would there be any advantage if i installed his stock struts instead of my stock RS struts?? one more thing, he bought new front calipers and rotors, would there be an advantage to install his stock calipers/rotors?? well thanx for any info !! -AJ
05-22-2003, 09:40 PM | #2 |
Member#: 11221
Vehicle:2002 2.5 RS Black as Midnight!!! |
As far as I know...only the body changed...not the chasis...so everything should bolt up fine. No difference in which struts u use, as they are the same...if his are already put together with the top hats and everything just use his as its LOTS easier to put a strut assembnly thats put together in.
As for brakes...go for it...you gain about 6" in diameter I believe... Just remember which pads you need when you want to replace them |
05-22-2003, 11:48 PM | #3 |
Member#: 4414
Vehicle:2002 WRX Sedan Midnight Black |
If the 04 RS gets the same new suspension as the WRX, you may want to ride in it a bit before you start upgrading it, The 04 WRX suspension is supposed to be pretty nice, between the 02/03 stock suspension and the SPT/STi kit.
As far as the brakes, his stuff will bolt right up, you're all set there. If you have the new suspension, his struts would be a downgrade Also the rear springs are different on the new WRXs (again, I dunno about the RS) and if you want to use aftermarket springs, you have to use the 02/03 strut tops. |
05-23-2003, 12:49 AM | #4 |
Member#: 11221
thanks for clearing that up Concillian...I didnt realize they changed the suspension for the new body style.
05-23-2003, 07:10 AM | #5 |
Member#: 37222
so using him brakes can be done and will be an upgrade??
and i can use his lowering springs but not with my sturts tops? thanx again, sorry |
RS stuff and 04-05 wrx stuff | The_Black_WRX | MAIC Private Classifieds | 4 | 11-25-2008 08:40 PM |
Feeler:OR: Mostly RS stuff, some WRX stuff | geoffj | NWIC Private Classifieds | 27 | 06-28-2007 10:59 PM |
WRX Stuff To RS Question | SCOOBER | Normally Aspirated with bolt-on Forced Induction Powertrain | 7 | 04-10-2003 02:47 PM |
WRX --> RS swap! | Boost4U | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 21 | 07-20-2002 12:56 AM |
