11-22-2004, 11:49 AM | #1 |
Member#: 11654
Vehicle:2002 WRX Sedan WR Blue |
Fuel Tank Leaking After Fuel Pump Upgrade
Hey,
I did a stage 4 install a couple weeks ago and now my gas tank is leaking. It's pretty slow and only does it when the tank is pretty full or around sharp turn. I've ordered a new gasket for the top of the tank and I'm going to install that in a few minutes but does anyone else have anythin else I should check out? Thanks, Mike
11-22-2004, 04:37 PM | #2 |
Member#: 30277
Vehicle:2002 WRX Japan Specs Platinum Silver Sedan |
I have the EXACT same PROBLEM?
What should I DO? Also, please tell me where to Order a new Gasket for the TOP! Or the Part #... Thank You Soo Much, I tought that I was going KRAZY... |
11-22-2004, 08:01 PM | #3 |
Member#: 52890
I had the same problem when i installed mine. i took everything back out paid close attention to the gasket and everything looked fine. put it back together and all was well. maybe try this it may help
11-22-2004, 10:05 PM | #4 |
Member#: 16779
NESIC
Vehicle:2021 Toyota 4Runner Black |
Yes make sure the rubber nipples on the gasket are actually pulled up through the cover, and not wadded up underneath.
11-22-2004, 10:33 PM | #5 |
Member#: 18446
Vehicle:2002 WRX wagon psm |
Same issue, nipples now in right place, problem gone. |
11-22-2004, 11:01 PM | #6 |
Member#: 31789
Vehicle:Now with 100% more V8 Spec C and 6MT |
I had the same problem. Heres the part # 42060AA040
11-22-2004, 11:55 PM | #7 |
Member#: 69369
a new gasket will fix this. for $7, it should be done right the first time.
11-23-2004, 12:05 AM | #8 |
Member#: 11654
I have the gasket. I had a wire going around back stuck in the gasket and that helped. I'm going to install the new gasket tomorrow.
Thanks, Mike |
11-23-2004, 08:27 AM | #9 |
Member#: 25049
Vehicle:2002 Impreza WRX Sedona Red |
Mine did the same thing. Found out that the gasket had expanded alittle. Put a new one in and have been running for 7 months leak free
11-23-2004, 08:30 AM | #10 |
Member#: 30277
Since I will be doing this with a Friend, like a DIY thing, can you please give me
more info. Ex: What to Do? What to Unscrew. BTW, Where is the Fuel Pump? |
11-28-2004, 08:11 AM | #11 |
Member#: 25049
It's pretty simple. Here's a write up from the Turboxs website.
http://www.turboxs.com/Stage%204%20I...structions.htm |
11-28-2004, 08:36 AM | #12 |
Member#: 23570
NESIC
Vehicle:2002 WRX Sedona Red Pearl |
Fuel gauge misreading after Walbro pump install | sanovichleo | Service & Maintenance | 1 | 08-03-2009 02:52 PM |
Surge tank fuel pump upgrade | OzWRX | Built Motor Discussion | 16 | 03-16-2008 03:51 PM |
Hard to fuel up after fuel pump upgrade ! Any ideas ? | Okeyd57 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 10 | 06-26-2007 04:43 PM |
Fuel tank leaking/need reputable Orlando service place | Shep2112 | Service & Maintenance | 10 | 10-03-2004 05:12 PM |
fuel tank leak | deeseeone | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 09-25-2003 02:38 AM |
