09-02-2007, 12:20 AM | #1 |
Member#: 152141
BAIC
Vehicle:2007 WRX exit stg L Pearl |
Will 215/45 R17 fit on 17 x 7.5 rim?
Sorry to put this up here but I did quite a bit of searching and not too much luck in the wheel forum. I found some wheels I like cheap but I can't afford new tires yet. Was wondering if I could put my stock tires on a 7.5 inch wheel. I want to put a 17 x 7.5 +45mm wheel on my wrx. That should work, no?
09-02-2007, 12:22 AM | #2 |
Member#: 92003
SCIC
Vehicle:04 bicycle! |
i've got 225 on 7.5 inch rims so i'm guessing yeah it will fit considering 215mm is larger than 7.5 inches
09-02-2007, 12:26 AM | #3 |
Member#: 152141
BAIC
Thanks. The offset isn't perfect but it seems like you have to spend quite a bit to get the 52mm offset. The best I've seen in the cheaper models is 48mm on a 7" so I'm thinking 45mm on a 7.5 is acceptable.
245/45/r17 fit on a 17x7 rim? is it possible? | stage2?? | Tire & Wheel | 25 | 03-03-2013 10:51 PM |
will p225/45 r17 fit? | newscoobboob | Tire & Wheel | 6 | 02-05-2008 12:15 AM |
Will 225/45-17's fit on 7.0 or 7.5 wide rims? | 99snowhiteRS | Tire & Wheel | 4 | 09-26-2007 09:17 PM |
will 215/45 R17 fit rota torque 17x8 rims?? | Silver_04_WRX_SC | Tire & Wheel | 1 | 01-07-2006 05:36 PM |
245/45/17 on 17 by 7.5 CE28 | jdmej20 | Interior & Exterior Modification | 16 | 12-26-2004 12:21 AM |
