09-19-2007, 03:22 AM | #1 |
Member#: 159299
Vehicle:1998 Legacy Wagon Green |
factory torque spec for crank pulley bolt?
Would someone with access to the FSM please provide the torque spec for the 2.2L ['95 Legacy] crank pulley bolt?
I understand the Haynes manual specifies 70-80 ft-lbs, but, upon searching the archives and reading a few horror stories about loosening bolts and disintegrating woodruff keys/pulleys/sprockets, I'd like to double check the numbers. When you folks do timing belts, how much torque do you put on the crank bolt? Anybody use blue loctite for good measure? Thanks for your time.
09-19-2007, 10:40 AM | #2 |
Member#: 6486
Vehicle:00 Impreza 2.5 RS Blue Ridge Pearl |
90-94 ft lbs on the 2.2L
130-134 ft lbs on the 2.5L These are from the 2000 model year service manual. |
09-19-2007, 03:58 PM | #3 |
Member#: 137398
E. Canada
Vehicle:2004 Impreza |
Just used some grease before I put my Perrin LCP in and torqued it to 130 ft-lbs.
09-21-2007, 01:45 AM | #4 |
Member#: 159299
Thanks for the quick response.
Torque specs for Cosworth rod bolts for EJ25? | Navid | Built Motor Discussion | 0 | 10-20-2007 10:57 PM |
Torque specs for lightened pulley | PKer | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 11-15-2002 08:57 AM |
Torque spec for uppipe/exhaust bolts? | b16bpower | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 02-27-2002 10:02 PM |
WRX Torque Specs for Exhaust Header Bolts | Neil Wallerstein | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 06-30-2001 01:48 PM |
need torque specs for brake caliper bolts, please | Lou | Technical Forum Archive | 2 | 07-24-2000 04:52 PM |
