08-11-2008, 10:22 PM | #1 |
Member#: 49610
signs that your turbo is going bad?
it was suggested by someone that my stock turbo on my 03 wrx might be going bad... im cobb stage two if that matters, stock bpv and intake... sometimes the power seems to come and go,and im getting some light smoke at startup from the exhaust... so im curious how i should be able to tell if my turbo is going bad? what are the signs if any? thanks for the help
08-11-2008, 10:41 PM | #2 | |
Member#: 140978
SCIC
Vehicle:02 WRX WRB i-Nertia Dynamics |
If its wearing a white glove....you hosed. |
08-11-2008, 10:42 PM | #3 |
Member#: 172133
NESIC
Vehicle:2003 vfdirty wrx rotten banana |
I would like to know also. Bump this up!!!!!!!!!!!!!
08-12-2008, 01:48 PM | #4 |
Member#: 180857
Vehicle:03 WRX That sexy silverrr |
Also curious here, 03 WRX 65k same symptoms.
08-12-2008, 05:12 PM | #5 |
Member#: 49610
anyone?
08-12-2008, 05:17 PM | #6 |
Member#: 117780
South East
Vehicle:2004 WRX Aspen White |
Either of these would tip me off
08-12-2008, 05:43 PM | #7 |
Member#: 49610
that blows..but more curious about getting the symptoms or help on the issue without taking the turbo off
08-12-2008, 07:35 PM | #8 |
Member#: 186753
Vehicle:2004 Impreza Blue-Grey |
have you been getting a lot of boost surge? or what exactly does your friend notice about the turbo?
08-12-2008, 07:58 PM | #9 | |
Member#: 117548
Vehicle:02 WRX WRB |
08-12-2008, 11:43 PM | #10 |
Member#: 183095
NESIC
Vehicle:2004 WRX Winter Blue |
My tuner instinctively knew that my turbo was on its way out. He said it just wasn't making the power it should at the boost and it wasn't spooling as fast as it should also. The smoking/oil burning/shaft play also gave hints. The easiest thing I imagine would be to check for shaft play if you are getting oil smoke in the exhaust.
how to tell if turbo is going bad? | justincredible | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 52 | 03-27-2013 01:13 AM |
Yet another sign that the Apocalypse is just around the corner... | Strider | Off-Topic | 70 | 05-08-2009 03:49 PM |
Can a turbo gradually go bad, or do they just blow when they are bad? | tacokid789 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 3 | 05-04-2009 07:13 PM |
Signs that the end is near | docwhorocks | Off-Topic | 15 | 03-28-2006 04:19 PM |
The NASIOC Black Ops tour 2k5 sign up thread....(this is a bad idea :lol: ) | daveB | Off-Topic | 208 | 10-12-2005 06:20 PM |
