I just got it in today and put it on the car. I did check the map on the computer before putting it on the car. In position 1 it said satge 1 map 16 psi peak and afr 11-1. Does that sound right for the utec stage 1. But after installing i checked over everythin and install was good. I started the car and it idled fine from what i could here, then whwen the engine warmed up to operating temp. it started sounding a little more lowpy. I decided to go take it around the block. It pretty much drove like pure hell. Jerking and felt so boggy. I didnt put the boost controller on because the book said i didnt need to unless i was going for more boost than the utec base maps called for. Is it suppose to be on. I do have a blitz nur spec type r on. I didnt think that would matter though. When i put the catback on it didnt even feel like the car had any more power, so i figured it was still close enough to stock for stage 1. Any help would be great. I have read and read and cant figure out what is wrong. Thanks in advance.
shannon
