07-02-2008, 02:34 AM | #1 |
Member#: 171092
TXIC
Vehicle:1993 Impreza 1.8T Black |
bad gas milage
i just finished my ej18t build and now i'm getting bad gas milage before the build i was getting about 320-350 miles to a full tank now i'm getting 125-145 to a full tank. my setup is: ej18 engine, 370cc sf injectors, turbo water pump, blow-through maf, fmic, parallel fuel mod, vf34 turbo set @ 8psi, wrx manifold, 3" tbe, catless up and dp. at first i thought fuel leak but no, then i thought someone is stealing it so i put locking cap and park it i garage still same problem. what else could it be? other than that it runs really well.
07-02-2008, 02:40 AM | #2 |
Member#: 102140
South East
Vehicle:2016 Single Speed or Death |
are you tuned?
07-02-2008, 02:41 AM | #3 |
Member#: 102140
South East
you aren't scaled for those injectors. That is my guess.
07-02-2008, 11:49 AM | #4 |
Member#: 133584
Vehicle:2003 Honda S2000 |
yeah if your not tuned your just sending too much fuel through your injectors because the ecu still thinks they are the stock size
07-02-2008, 12:05 PM | #5 |
Member#: 132130
TXIC
Vehicle:2002 Ford F-150 Graphite Gray |
sounds like its running rich @ cruise..lols.
def scale bak them injeckers! |
07-02-2008, 01:04 PM | #6 |
Member#: 171092
TXIC
lol no tune
no engine management running rich at night when driving hard and i shift i hear a loud pop from the exhaust na dtheres a huge fireball coming out car runs super great and is very reliable just getting the bad gas milage what is a decent em tht is not too pricey? i'm just really happy tht its finaly running again na dthe turbo really made a big difference compaired to the way the car pulls in the non-tubo form ej18 |
07-02-2008, 01:08 PM | #7 |
Member#: 102140
South East
running rich is definitely not as bad as running lean.
get a tune man. running too rich (sounds like it) can cause your car to wash out its cylinder walls and/or destroy your piston rings. |
07-02-2008, 01:16 PM | #8 | ||
Member#: 171092
TXIC
thts true i would rather be running rich than hav a lean problem where its mor damaging to the engine
07-02-2008, 02:35 PM | #9 |
Member#: 132130
TXIC
id just put the stock injectors back in and run 10 lbs with a rrfpr.
or get a emanage blue im running 7 lbs with no em and get 25 mpg, lol |
07-02-2008, 04:19 PM | #10 |
Member#: 111735
Vehicle:97 Impreza L Rust and White |
i got better gas mileage when i went turbo, yihaw.!
07-02-2008, 07:35 PM | #11 |
Member#: 171092
TXIC
just found my stock injectors and they're a little messed up from when i took 'em out of the fuel rails to put in the bigger ones
another question before i went turbo the cel was on and the only code that would come up was the tps sensor. now with the turbo and everything on the car there is no cel at all is that a good thing? i never touched the tps and no more cel. |
07-02-2008, 07:41 PM | #12 |
Member#: 102140
South East
well first of all, I don't think putting the stock injectors back in the car is a good thing, now that you are a turbo setup you are going to use more fuel. If you put the injectors in you might run extremely lean. I say juts go get something to tune your car, and pay someone in TX a little cash to road tune the car.
07-02-2008, 07:53 PM | #13 |
Member#: 171092
TXIC
u mean a tuner here in tx or a fellow impreza owner that has expirence with tunning
07-02-2008, 07:53 PM | #14 |
Member#: 102140
South East
im going to opt for option 2
07-02-2008, 08:12 PM | #15 |
Member#: 171092
TXIC
lol thats what i was thinking i've seen a few scooby's here in town but never see any stopped where we can actually talk they are always on the road driving would a safc be a good choice or just save and get the emanage? the reason i say save is cuz i just finished working on my parents truck and now am low on cash again
07-02-2008, 09:53 PM | #16 |
Member#: 64673
Vehicle:1990 Legacy wagon goes 12.387 @ 116.5 |
Used SMT6 (perfect power) for $250ish....
07-02-2008, 10:46 PM | #17 |
Member#: 157692
Vehicle:2004 WRX "Big Red" |
I would recomend Emanage Ultimate, especially if you are ever planning on going an extra mile to create more power. Allows you to pull timing and adjust AFR a lot better than emanage blue or pp6 or anything. I've been told its worth the extra cash, thats why I'm going to be shelling it out
07-03-2008, 01:50 AM | #18 |
Member#: 102140
South East
http://forums.nasioc.com/forums/show....php?t=1547861
I don't know if he can do it. But they rave about him. |
07-03-2008, 02:03 AM | #19 | |
Member#: 91925
TXIC
Vehicle:2015 WRX STi AWDTuning.com |
07-03-2008, 02:04 AM | #20 |
Member#: 102140
South East
Yes. He is contemplating a piggyback or some kind of ECM
07-03-2008, 02:13 AM | #21 |
Member#: 91925
TXIC
I dont have much experience with the older imprezas but if you could wire in an 02 wrx ecu then it could pretty much be dialed in as if it was on a stand allone. This would probably require some innovation from a wiring perspective, but it would be pretty inexpensive.
I'm suprised the car runs at all with a blow thru MAF and everything ..pretty crazy.. |
07-03-2008, 02:17 AM | #22 |
Member#: 171092
TXIC
i am willing to settle for a blue if ne1 has a good used 1 at a decent price as i dont have very little cash at the moment just for kicks and giggles heres my setup the date is wrong i just took the pics 7/2/08
sorry bout the big pics i dont know how to resize them on photobucket, did u knotice the rear disc conversion? i will post a driving vid tmw i am loading it on u tube right now its just a shot of the dash while i was on the highway. |
07-03-2008, 02:30 AM | #23 |
Member#: 171092
TXIC
here's the vid and if thshadow can help me out that would be a huge helping hand and yes i am on the stock '93 impreza l ecu how hard would it be to wire in the '02 wrx ecu into my car being that i only have 1 cam sensor?
http://s218.photobucket.com/albums/c...t=S5030385.flv Last edited by '93Impreza1.8T; 07-03-2008 at 01:00 PM. |
07-03-2008, 07:55 PM | #24 |
Member#: 36333
Vehicle:98 RS GT30R, closed deck madnes |
07-03-2008, 11:36 PM | #25 |
Member#: 171092
TXIC
Similar Threads | ||||
Bad Gas Milage - Any not so common causes? | aberg12012 | Normally Aspirated Powertrain | 13 | 05-14-2009 12:41 AM |
Bad gas milage/Cel | SubieGenius | Newbies & FAQs | 11 | 09-09-2008 05:02 PM |
Using ODBII to diagnose bad gas milage? | SubaruLover | Normally Aspirated Powertrain | 15 | 04-12-2006 08:44 AM |
Old Fuel filter can cause bad gas milage? | SubaruImpreza_power | Normally Aspirated Powertrain | 0 | 01-12-2006 05:46 PM |
Bad Gas Milage on 97GT???? | georgiamiata | Legacy Forum | 9 | 07-01-2002 04:18 PM |
