11-17-2011, 07:31 PM | #1 |
Member#: 299371
99 legacy outback swap?
Heres the deal, I have a 99 legacy outback ej25 phase ? with a blown head gasket. I'm trying to figure out which route to take with it; do I swap the engine for a USDM EJ25t, or fix both heads and put turbo in myself? (is this possible?)
from what research I have done it seems that I would have to replace the drivetrain if I go with the USDM EJ25t. is this true? any advice would be much appreciated.
11-17-2011, 08:33 PM | #2 |
Member#: 74907
Vehicle:98 cam'd EJ251 Wrx Tranny,slowr than ish |
No need to swap drivetrain. Yank the motor, pull the heads and take them to a machine shop to see if they are still flat. If they need a little machining no big deal. Just make sure to use the correct headgasket, you might have a phase II block under your EJ25D heads. You can only be sure once you pull the heads and see if the pistons pop out of the bore.
~Josh~ |
Similar Threads | ||||
FS/FT : NC: 99 legacy outback, 98 f150, 93 legacy | Confusedami | Private Vehicle 'For Sale' Classifieds | 1 | 04-05-2011 11:36 PM |
will a 99 2.5rs engine bolt into a 99 legacy outback? | IllNastyImpreza | Subaru Conversions | 18 | 06-27-2007 10:26 PM |
WRX / 99 Legacy Outback parts compatibility? | bdo | Service & Maintenance | 1 | 02-01-2003 09:29 PM |
99 Legacy Outback - can't find light bulb | bendorion | General Community | 0 | 11-06-2002 08:14 PM |
Help - 99 Legacy Outback | bendorion | Newbies & FAQs | 0 | 11-06-2002 08:11 PM |
